When executing the CM7 firmware using the IMX8MP Linux system, the system blocked
1,319件の閲覧回数
Dzen
hi NXP Supports,
I am currently working on developing the firmware for the IMX8MP CM7, but have encountered some issues.
I compiled the hello_world example firmware using MCUpresso for VS Code. When performing the following operation, the system blocked and did not move. there were no logs printed from the debug serial port of A53 either.  please point out where I haven't made the configuration correctly? TKS.
The device tree configuration is as follows:
memory@40000000 {
device_type = "memory";
reg = <0x0 0x40000000 0 0x40000000>;  / * 1GB DDR */
reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
  /* 128MB */
linux,cma {
compatible = "shared-dma-pool";
reusable;
size = <0 0x8000000>;
alloc-ranges = <0 0x40000000 0 0x40000000>;
linux,cma-default;
/* Reserve 16MB for RTOS running on CM7 */
m7_reserved: m7@7E000000 {
no-map;
reg = <0 0x7E000000 0 0x1000000>;
vdev0vring0: vdev0vring0@7D000000 {
reg = <0 0x7D000000 0 0x8000>;
no-map;
vdev0vring1: vdev0vring1@7D008000 {
reg = <0 0x7D008000 0 0x8000>;
no-map;
vdevbuffer: vdevbuffer@7D100000 {
reg = <0 0x7D100000 0 0x100000>;
no-map;
rsc_table: rsc-table@7D0FF000 {
reg = <0 0x7D0FF000 0 0x1000>;
no-map;
imx8mp-cm7 {
compatible = "fsl,imx8mn-cm7";
rsc-da = <0x7D000000>;
clocks = <&clk IMX8MP_CLK_M7_DIV>;
clock-names = "core";
mbox-names = "tx", "rx", "rxdb";
mboxes = <&mu 0 1
  &mu 1 1
  &mu 3 1>;
memory-region = <&m7_reserved>,
<&vdevbuffer>,
<&vdev0vring0>,
<&vdev0vring1>,
<&rsc_table>;
status = "okay";
fsl,startup-delay-ms = <500>;
ラベル(2)
3 返答(返信)
987件の閲覧回数
Dzen
I have been able to run the firmware of CM7 using the sysfs method by sending the command "run prepare_mcore" in the boot process.
However, during the operation of the CM7 firmware, the following errors still occurred. I used the project "boards\evkmimx8mp\demo_apps\hello_world". From the log, it seems to be a problem with the SAI/audio configuration. But I have already deleted the contents related to audio in clock_config.c(attached file), yet the error still occurred. Please tell me if there is anything that was not properly modified?
[ 122.890817] Internal error: synchronous external abort: 0000000096000210 [#1] PREEMPT_RT SMP
[ 122.890822] Modules linked in: fsl_jr_uio caam_jr caamkeyblob_desc caamhash_desc caamalg_desc crypto_engine authenc libdes crct10dif_ce snd_soc_imx_card polyval_ce polyval_generic snd_soc_fsl_micfil snd_soc_fsl_sai snd_soc_fsl_utils imx_pcm_dma snd_soc_tas5805m caam secvio error leds_serial_gpio fuse
[ 122.890866] CPU: 0 PID: 248 Comm: irq/221-sai Not tainted 6.6.36-rt35-lts-next #1
[ 122.890873] Hardware name: NXP i.MX8MPlus EVK board (DT)
[ 122.890875] pstate: 20000005 (nzCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 122.890881] pc : regmap_mmio_read32le+0x8/0x60
[ 122.890891] lr : regmap_mmio_read+0x44/0x70
[ 122.890896] sp : ffff800082fcbcc0
[ 122.890898] x29: ffff800082fcbcc0 x28: 0000000000000000 x27: 0000000000000000
[ 122.890905] x26: ffff8000800f3e90 x25: ffff8000800f198c x24: ffff000005f3b500
[ 122.890913] x23: ffff000005b60000 x22: ffff000005bea400 x21: ffff800082fcbd84
[ 122.890920] x20: 0000000000000008 x19: ffff000005afecc0 x18: ffffffffffffffff
[ 122.890928] x17: 0000000100000100 x16: 000010003d000000 x15: ffff000036d5ac40
[ 122.890935] x14: 00000505d7fc02f4 x13: 00143f3c7cb53818 x12: 0000000000000055
[ 122.890942] x11: 0000000000000001 x10: 0000000000000a10 x9 : ffff800082fcbd30
[ 122.890951] x8 : ffff000008096170 x7 : ffff000036d5a440 x6 : 0000000000143f3c
[ 122.890957] x5 : ffff80008098ce58 x4 : 0000000000000008 x3 : 0000000000000008
[ 122.890964] x2 : ffff80008098d5d8 x1 : 0000000000000008 x0 : ffff800082fb0008
[ 122.890971] Call trace:
[ 122.890974] regmap_mmio_read32le+0x8/0x60
[ 122.890979] _regmap_bus_reg_read+0x70/0xb0
[ 122.890986] _regmap_read+0x60/0xd8
[ 122.890993] regmap_read+0x4c/0x78
[ 122.890998] fsl_sai_isr+0x48/0xec [snd_soc_fsl_sai]
[ 122.891012] irq_forced_thread_fn+0x3c/0xc8
[ 122.891021] irq_thread+0x174/0x23c
[ 122.891028] kthread+0x110/0x114
[ 122.891034] ret_from_fork+0x10/0x20
[ 122.891043] Code: b5000001 d65f03c0 f9400000 8b214000 (b9400000)
[ 122.891048] ---[ end trace 0000000000000000 ]---
[ 122.891051] Kernel panic - not syncing: synchronous external abort: Fatal exception in interrupt
[ 122.891055] SMP: stopping secondary CPUs
[ 122.891062] Kernel Offset: disabled
[ 122.891064] CPU features: 0x0,00000008,00020000,1000421b
[ 122.891068] Memory Limit: none
[ 123.748394] ---[ end Kernel panic - not syncing: synchronous external abort: Fatal exception in interrupt ]---
1,248件の閲覧回数
Manuel_Salas
Hello @Dzen
I hope you are doing very well.
You can try configuring your device tree as the chapter 9.1 i.MX Linux rproc support of the AN5317.
Manuel_Salas_0-1777487647626.pngManuel_Salas_1-1777487671308.pngManuel_Salas_2-1777487713858.pngManuel_Salas_3-1777487727875.png
Same as suggested by @dbaluta .
Salas.
1,274件の閲覧回数
dbaluta
Sending you some pointers until NXP support team will jump in.
Can you try using this tree https://github.com/nxp-imx/linux-imx/tree/lf-6.18.y  and this dts?
https://github.com/nxp-imx/linux-imx/blob/lf-6.18.y/arch/arm64/boot/dts/freescale/imx8mp-evk-rpmsg.d...
%3CLINGO-SUB%20id%3D%22lingo-sub-2357824%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MP%20Linux%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6CM7%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2357824%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81NXP%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E7%9A%86%E6%A7%98%E3%80%81%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81IMX8MP%20CM7%E7%94%A8%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E9%96%8B%E7%99%BA%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EVS%20Code%20%E7%94%A8%E3%81%AE%20MCUpresso%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81hello_world%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%93%8D%E4%BD%9C%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E9%9A%9B%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%80%81%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82A53%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E7%94%A8%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8B%E3%82%89%E3%82%82%E3%83%AD%E3%82%B0%E3%81%AF%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E7%AE%87%E6%89%80%E3%82%92%E6%8C%87%E6%91%98%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9FTKS%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Dzen_0-1777377240626.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Dzen_0-1777377240626.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Dzen_0-1777377240626.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Dzen_0-1777377240626.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383867i7ECA2ADD34B640AF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Dzen_0-1777377240626.png%22%20alt%3D%22Dzen_0-1777377240626.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%3E%3CSPAN%3E%E3%83%A1%E3%83%A2%E3%83%AA%4040000000%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edevice_type%20%3D%20%22memory%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x0%200x40000000%200%200x40000000%26gt%3B%3B%20%2F%20*%201GB%20DDR%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BA%88%E7%B4%84%E3%83%A1%E3%83%A2%E3%83%AA%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23address-cells%20%3D%20%26lt%3B2%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23size-cells%20%3D%20%26lt%3B2%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%AF%84%E5%9B%B2%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F*%20128MB%20*%2F%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Elinux%E3%80%81cma%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompatible%20%3D%20%22shared-dma-pool%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%86%8D%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%20%26lt%3B0%200x8000000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ealloc-ranges%20%3D%20%26lt%3B0%200x40000000%200%200x40000000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Elinux%E3%80%81cma-default%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20CM7%E4%B8%8A%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8BRTOS%E7%94%A8%E3%81%AB16MB%E3%82%92%E4%BA%88%E7%B4%84%E3%81%99%E3%82%8B%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Em7_reserved%3A%20m7%407E000000%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%B0%E5%9B%B3%E3%81%AA%E3%81%97%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0%200x7E000000%200%200x1000000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Evdev0vring0%3A%20vdev0vring0%407D000000%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0%200x7D000000%200%200x8000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%B0%E5%9B%B3%E3%81%AA%E3%81%97%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Evdev0vring1%3A%20vdev0vring1%407D008000%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0%200x7D008000%200%200x8000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%B0%E5%9B%B3%E3%81%AA%E3%81%97%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Evdevbuffer%3A%20vdevbuffer%407D100000%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompatible%20%3D%20%22shared-dma-pool%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0%200x7D100000%200%200x100000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%B0%E5%9B%B3%E3%81%AA%E3%81%97%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ersc_table%3A%20rsc-table%407D0FF000%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0%200x7D0FF000%200%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%B0%E5%9B%B3%E3%81%AA%E3%81%97%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eimx8mp-cm7%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompatible%20%3D%20%22fsl%2Cimx8mn-cm7%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ersc-da%20%3D%20%26lt%3B0x7D000000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_M7_DIV%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%90%8D%20%3D%20%22core%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Embox-names%20%3D%20%22tx%22%2C%20%22rx%22%2C%20%22rxdb%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emboxes%20%3D%20%26lt%3B%CE%BC%200%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%CE%BC%201%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%CE%BC%203%201%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%A1%E3%83%A2%E3%83%AA%E9%A0%98%E5%9F%9F%20%3D%20%26lt%3B%26amp%3Bm7_reserved%26gt%3B%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%26amp%3Bvdevbuffer%26gt%3B%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%26amp%3Bvdev0vring0%26gt%3B%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%26amp%3Bvdev0vring1%26gt%3B%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%26amp%3Brsc_table%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Efsl%E3%80%81%E8%B5%B7%E5%8B%95%E9%81%85%E5%BB%B6ms%20%3D%20%26lt%3B500%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2357824%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358269%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20When%20executing%20the%20CM7%20firmware%20using%20the%20IMX8MP%20Linux%20system%2C%20the%20system%20blocked%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358269%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%81%E3%83%BC%E3%83%A0%E3%81%8C%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%81%BE%E3%81%A7%E3%81%AE%E9%96%93%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%83%92%E3%83%B3%E3%83%88%E3%82%92%E3%81%8A%E9%80%81%E3%82%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%83%84%E3%83%AA%E3%83%BC%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Ftree%2Flf-6.18.y%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%88https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Ftree%2Flf-6.18.y%3C%2FA%3E%20%EF%BC%89%E3%81%A8%E3%81%93%E3%81%AEdts%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.18.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp-evk-rpmsg.dts%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.18.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp-evk-rpmsg.dts%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20When%20executing%20the%20CM7%20firmware%20using%20the%20IMX8MP%20Linux%20system%2C%20the%20system%20blocked%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262200%22%20target%3D%22_blank%22%3E%40Dzen%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%85%83%E6%B0%97%E3%81%A7%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN5317.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN5317%3C%2FA%3E%20%E3%81%AE%E7%AC%AC%3CSTRONG%3E%209.1%20%E7%AB%A0%20i.MX%20Linux%20rproc%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%20%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Manuel_Salas_0-1777487647626.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Manuel_Salas_0-1777487647626.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Manuel_Salas_0-1777487647626.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384043i42B27F0E13AA46A7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Manuel_Salas_0-1777487647626.png%22%20alt%3D%22Manuel_Salas_0-1777487647626.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Manuel_Salas_1-1777487671308.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Manuel_Salas_1-1777487671308.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Manuel_Salas_1-1777487671308.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384044iDEDC87AAA098E234%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Manuel_Salas_1-1777487671308.png%22%20alt%3D%22Manuel_Salas_1-1777487671308.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Manuel_Salas_2-1777487713858.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Manuel_Salas_2-1777487713858.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Manuel_Salas_2-1777487713858.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384045i3DD5D392DFA43EEF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Manuel_Salas_2-1777487713858.png%22%20alt%3D%22Manuel_Salas_2-1777487713858.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Manuel_Salas_3-1777487727875.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Manuel_Salas_3-1777487727875.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Manuel_Salas_3-1777487727875.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384046iCF034DC4E1D44337%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Manuel_Salas_3-1777487727875.png%22%20alt%3D%22Manuel_Salas_3-1777487727875.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F161047%22%20target%3D%22_blank%22%3E%40dbaluta%3C%2FA%3E%E3%81%95%E3%82%93%E3%81%8C%E6%8F%90%E6%A1%88%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%A9%E3%82%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2362698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20When%20executing%20the%20CM7%20firmware%20using%20the%20IMX8MP%20Linux%20system%2C%20the%20system%20blocked%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2362698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%A7%E3%80%8Crun%20prepare_mcore%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81sysfs%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6CM7%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81CM7%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%8B%95%E4%BD%9C%E4%B8%AD%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AF%E3%80%8Cboards%5Cevkmimx8mp%5Cdemo_apps%5Chello_world%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AD%E3%82%B0%E3%82%92%E8%A6%8B%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81SAI%2F%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81clock_config.c(%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB)%E5%86%85%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E9%96%A2%E9%80%A3%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%81%AF%E6%97%A2%E3%81%AB%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%89%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BD%95%E3%81%8B%E9%81%A9%E5%88%87%E3%81%AB%E4%BF%AE%E6%AD%A3%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E7%AE%87%E6%89%80%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CBR%20%2F%3E%3CP%3E%5B%20122.890817%5D%20%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E5%90%8C%E6%9C%9F%E5%A4%96%E9%83%A8%E3%82%A2%E3%83%9C%E3%83%BC%E3%83%88%3A%200000000096000210%20%5B%231%5D%20PREEMPT_RT%20SMP%3CBR%20%2F%3E%20%5B%20122.890822%5D%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3A%20fsl_jr_uio%20caam_jr%20caamkeyblob_desc%20caamhash_desc%20caamalg_desc%20crypto_engine%20authenc%20libdes%20crct10dif_ce%20snd_soc_imx_card%20polyval_ce%20polyval_generic%20snd_soc_fsl_micfil%20snd_soc_fsl_sai%20snd_soc_fsl_utils%20imx_pcm_dma%20snd_soc_tas5805m%20caam%20secvio%20error%20leds_serial_gpio%20fuse%3CBR%20%2F%3E%20%5B%20122.890866%5D%20CPU%3A%200%20PID%3A%20248%20Comm%3A%20irq%2F221-sai%20%E6%B1%9A%E6%9F%93%E3%81%AA%E3%81%97%206.6.36-rt35-lts-next%231%3CBR%20%2F%3E%20%5B%20122.890873%5D%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E5%90%8D%3A%20NXP%20i.MX8MPlus%20EVK%20%E3%83%9C%E3%83%BC%E3%83%89%20(DT)%3CBR%20%2F%3E%20%5B%20122.890875%5D%20pstate%3A%2020000005%20(nzCv%20daif%20-PAN%20-UAO%20-TCO%20-DIT%20-SSBS%20BTYPE%3D--)%3CBR%20%2F%3E%20%5B%20122.890881%5D%20pc%20%3A%20regmap_mmio_read32le%2B0x8%2F0x60%3CBR%20%2F%3E%20%5B%20122.890891%5D%20lr%20%3A%20regmap_mmio_read%2B0x44%2F0x70%3CBR%20%2F%3E%20%5B%20122.890896%5D%20sp%20%3A%20ffff800082fcbcc0%3CBR%20%2F%3E%20%5B%20122.890898%5D%20x29%3A%20ffff800082fcbcc0%20x28%3A%200000000000000000%20x27%3A%200000000000000000%3CBR%20%2F%3E%20%5B%20122.890905%5D%20x26%3A%20ffff8000800f3e90%20x25%3A%20ffff8000800f198c%20x24%3A%20ffff000005f3b500%3CBR%20%2F%3E%20%5B%20122.890913%5D%20x23%3A%20ffff000005b60000%20x22%3A%20ffff000005bea400%20x21%3A%20ffff800082fcbd84%3CBR%20%2F%3E%20%5B%20122.890920%5D%20x20%3A%200000000000000008%20x19%3A%20ffff000005afecc0%20x18%3A%20ffffffffffffffff%3CBR%20%2F%3E%20%5B%20122.890928%5D%20x17%3A%200000000100000100%20x16%3A%20000010003d000000%20x15%3A%20ffff000036d5ac40%3CBR%20%2F%3E%20%5B%20122.890935%5D%20x14%3A%2000000505d7fc02f4%20x13%3A%2000143f3c7cb53818%20x12%3A%200000000000000055%3CBR%20%2F%3E%20%5B%20122.890942%5D%20x11%3A%200000000000000001%20x10%3A%200000000000000a10%20x9%20%3A%20ffff800082fcbd30%3CBR%20%2F%3E%20%5B%20122.890951%5D%20x8%20%3A%20ffff000008096170%20x7%20%3A%20ffff000036d5a440%20x6%20%3A%200000000000143f3c%3CBR%20%2F%3E%20%5B%20122.890957%5D%20x5%20%3A%20ffff80008098ce58%20x4%20%3A%200000000000000008%20x3%20%3A%200000000000000008%3CBR%20%2F%3E%20%5B%20122.890964%5D%20x2%20%3A%20ffff80008098d5d8%20x1%20%3A%200000000000000008%20x0%20%3A%20ffff800082fb0008%3CBR%20%2F%3E%20%5B%20122.890971%5D%E9%80%9A%E8%A9%B1%E8%BF%BD%E8%B7%A1%3A%3CBR%20%2F%3E%20%5B%20122.890974%5D%20regmap_mmio_read32le%2B0x8%2F0x60%3CBR%20%2F%3E%20%5B%20122.890979%5D%20_regmap_bus_reg_read%2B0x70%2F0xb0%3CBR%20%2F%3E%20%5B%20122.890986%5D%20_regmap_read%2B0x60%2F0xd8%3CBR%20%2F%3E%20%5B%20122.890993%5D%20regmap_read%2B0x4c%2F0x78%3CBR%20%2F%3E%20%5B%20122.890998%5D%20fsl_sai_isr%2B0x48%2F0xec%20%5Bsnd_soc_fsl_sai%5D%3CBR%20%2F%3E%20%5B%20122.891012%5D%20irq_forced_thread_fn%2B0x3c%2F0xc8%3CBR%20%2F%3E%20%5B%20122.891021%5D%20irq_thread%2B0x174%2F0x23c%3CBR%20%2F%3E%20%5B%20122.891028%5D%20kthread%2B0x110%2F0x114%3CBR%20%2F%3E%20%5B%20122.891034%5D%20ret_from_fork%2B0x10%2F0x20%3CBR%20%2F%3E%20%5B%20122.891043%5D%20%E3%82%B3%E3%83%BC%E3%83%89%3A%20b5000001%20d65f03c0%20f9400000%208b214000%20(b9400000)%3CBR%20%2F%3E%20%5B%20122.891048%5D%20---%5B%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E7%B5%82%E4%BA%86%200000000000000000%20%5D---%3CBR%20%2F%3E%20%5B%20122.891051%5D%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%91%E3%83%8B%E3%83%83%E3%82%AF%20-%20%E5%90%8C%E6%9C%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E5%90%8C%E6%9C%9F%E5%A4%96%E9%83%A8%E3%82%A2%E3%83%9C%E3%83%BC%E3%83%88%3A%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%A7%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E4%BE%8B%E5%A4%96%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B122.891055%5D%20SMP%3A%20%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AACPU%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%20122.891062%5D%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3A%20%E7%84%A1%E5%8A%B9%3CBR%20%2F%3E%5B%20122.891064%5D%20CPU%E6%A9%9F%E8%83%BD%3A%200x0%2C00000008%2C00020000%2C1000421b%3CBR%20%2F%3E%20%5B%20122.891068%5D%20%E3%83%A1%E3%83%A2%E3%83%AA%E5%88%B6%E9%99%90%3A%20%E3%81%AA%E3%81%97%3CBR%20%2F%3E%5B%20123.748394%5D%20---%5B%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%91%E3%83%8B%E3%83%83%E3%82%AF%E7%B5%82%E4%BA%86%20-%20%E5%90%8C%E6%9C%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E5%90%8C%E6%9C%9F%E5%A4%96%E9%83%A8%E3%82%A2%E3%83%9C%E3%83%BC%E3%83%88%3A%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%A7%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E4%BE%8B%E5%A4%96%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%5D---%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E
