When executing the CM7 firmware using the IMX8MP Linux system, the system blocked
1,323 次查看
Dzen
hi NXP Supports,
I am currently working on developing the firmware for the IMX8MP CM7, but have encountered some issues.
I compiled the hello_world example firmware using MCUpresso for VS Code. When performing the following operation, the system blocked and did not move. there were no logs printed from the debug serial port of A53 either.  please point out where I haven't made the configuration correctly? TKS.
The device tree configuration is as follows:
memory@40000000 {
device_type = "memory";
reg = <0x0 0x40000000 0 0x40000000>;  / * 1GB DDR */
reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
  /* 128MB */
linux,cma {
compatible = "shared-dma-pool";
reusable;
size = <0 0x8000000>;
alloc-ranges = <0 0x40000000 0 0x40000000>;
linux,cma-default;
/* Reserve 16MB for RTOS running on CM7 */
m7_reserved: m7@7E000000 {
no-map;
reg = <0 0x7E000000 0 0x1000000>;
vdev0vring0: vdev0vring0@7D000000 {
reg = <0 0x7D000000 0 0x8000>;
no-map;
vdev0vring1: vdev0vring1@7D008000 {
reg = <0 0x7D008000 0 0x8000>;
no-map;
vdevbuffer: vdevbuffer@7D100000 {
reg = <0 0x7D100000 0 0x100000>;
no-map;
rsc_table: rsc-table@7D0FF000 {
reg = <0 0x7D0FF000 0 0x1000>;
no-map;
imx8mp-cm7 {
compatible = "fsl,imx8mn-cm7";
rsc-da = <0x7D000000>;
clocks = <&clk IMX8MP_CLK_M7_DIV>;
clock-names = "core";
mbox-names = "tx", "rx", "rxdb";
mboxes = <&mu 0 1
  &mu 1 1
  &mu 3 1>;
memory-region = <&m7_reserved>,
<&vdevbuffer>,
<&vdev0vring0>,
<&vdev0vring1>,
<&rsc_table>;
status = "okay";
fsl,startup-delay-ms = <500>;
标签 (2)
991 次查看
Dzen
I have been able to run the firmware of CM7 using the sysfs method by sending the command "run prepare_mcore" in the boot process.
However, during the operation of the CM7 firmware, the following errors still occurred. I used the project "boards\evkmimx8mp\demo_apps\hello_world". From the log, it seems to be a problem with the SAI/audio configuration. But I have already deleted the contents related to audio in clock_config.c(attached file), yet the error still occurred. Please tell me if there is anything that was not properly modified?
[ 122.890817] Internal error: synchronous external abort: 0000000096000210 [#1] PREEMPT_RT SMP
[ 122.890822] Modules linked in: fsl_jr_uio caam_jr caamkeyblob_desc caamhash_desc caamalg_desc crypto_engine authenc libdes crct10dif_ce snd_soc_imx_card polyval_ce polyval_generic snd_soc_fsl_micfil snd_soc_fsl_sai snd_soc_fsl_utils imx_pcm_dma snd_soc_tas5805m caam secvio error leds_serial_gpio fuse
[ 122.890866] CPU: 0 PID: 248 Comm: irq/221-sai Not tainted 6.6.36-rt35-lts-next #1
[ 122.890873] Hardware name: NXP i.MX8MPlus EVK board (DT)
[ 122.890875] pstate: 20000005 (nzCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 122.890881] pc : regmap_mmio_read32le+0x8/0x60
[ 122.890891] lr : regmap_mmio_read+0x44/0x70
[ 122.890896] sp : ffff800082fcbcc0
[ 122.890898] x29: ffff800082fcbcc0 x28: 0000000000000000 x27: 0000000000000000
[ 122.890905] x26: ffff8000800f3e90 x25: ffff8000800f198c x24: ffff000005f3b500
[ 122.890913] x23: ffff000005b60000 x22: ffff000005bea400 x21: ffff800082fcbd84
[ 122.890920] x20: 0000000000000008 x19: ffff000005afecc0 x18: ffffffffffffffff
[ 122.890928] x17: 0000000100000100 x16: 000010003d000000 x15: ffff000036d5ac40
[ 122.890935] x14: 00000505d7fc02f4 x13: 00143f3c7cb53818 x12: 0000000000000055
[ 122.890942] x11: 0000000000000001 x10: 0000000000000a10 x9 : ffff800082fcbd30
[ 122.890951] x8 : ffff000008096170 x7 : ffff000036d5a440 x6 : 0000000000143f3c
[ 122.890957] x5 : ffff80008098ce58 x4 : 0000000000000008 x3 : 0000000000000008
[ 122.890964] x2 : ffff80008098d5d8 x1 : 0000000000000008 x0 : ffff800082fb0008
[ 122.890971] Call trace:
[ 122.890974] regmap_mmio_read32le+0x8/0x60
[ 122.890979] _regmap_bus_reg_read+0x70/0xb0
[ 122.890986] _regmap_read+0x60/0xd8
[ 122.890993] regmap_read+0x4c/0x78
[ 122.890998] fsl_sai_isr+0x48/0xec [snd_soc_fsl_sai]
[ 122.891012] irq_forced_thread_fn+0x3c/0xc8
[ 122.891021] irq_thread+0x174/0x23c
[ 122.891028] kthread+0x110/0x114
[ 122.891034] ret_from_fork+0x10/0x20
[ 122.891043] Code: b5000001 d65f03c0 f9400000 8b214000 (b9400000)
[ 122.891048] ---[ end trace 0000000000000000 ]---
[ 122.891051] Kernel panic - not syncing: synchronous external abort: Fatal exception in interrupt
[ 122.891055] SMP: stopping secondary CPUs
[ 122.891062] Kernel Offset: disabled
[ 122.891064] CPU features: 0x0,00000008,00020000,1000421b
[ 122.891068] Memory Limit: none
[ 123.748394] ---[ end Kernel panic - not syncing: synchronous external abort: Fatal exception in interrupt ]---
1,252 次查看
Manuel_Salas
Hello @Dzen
I hope you are doing very well.
You can try configuring your device tree as the chapter 9.1 i.MX Linux rproc support of the AN5317.
Manuel_Salas_0-1777487647626.pngManuel_Salas_1-1777487671308.pngManuel_Salas_2-1777487713858.pngManuel_Salas_3-1777487727875.png
Same as suggested by @dbaluta .
Salas.
1,278 次查看
dbaluta
Sending you some pointers until NXP support team will jump in.
Can you try using this tree https://github.com/nxp-imx/linux-imx/tree/lf-6.18.y  and this dts?
https://github.com/nxp-imx/linux-imx/blob/lf-6.18.y/arch/arm64/boot/dts/freescale/imx8mp-evk-rpmsg.d...
%3CLINGO-SUB%20id%3D%22lingo-sub-2357824%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20IMX8MP%20Linux%20%E7%B3%BB%E7%BB%9F%E6%89%A7%E8%A1%8C%20CM7%20%E5%9B%BA%E4%BB%B6%E6%97%B6%EF%BC%8C%E7%B3%BB%E7%BB%9F%E4%BC%9A%E9%98%BB%E6%AD%A2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2357824%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%20NXP%20%E6%94%AF%E6%8C%81%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E4%B8%BA%20IMX8MP%20CM7%20%E5%BC%80%E5%8F%91%E5%9B%BA%E4%BB%B6%EF%BC%8C%E4%BD%86%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%20MCUpresso%20for%20VS%20Code%20%E7%BC%96%E8%AF%91%E4%BA%86%20hello_world%20%E7%A4%BA%E4%BE%8B%E5%9B%BA%E4%BB%B6%E3%80%82%E6%89%A7%E8%A1%8C%E4%BB%A5%E4%B8%8B%E6%93%8D%E4%BD%9C%E6%97%B6%EF%BC%8C%E7%B3%BB%E7%BB%9F%E5%8F%97%E9%98%BB%EF%BC%8C%E6%97%A0%E6%B3%95%E7%A7%BB%E5%8A%A8%E3%80%82A53%20%E7%9A%84%E8%B0%83%E8%AF%95%E4%B8%B2%E8%A1%8C%E7%AB%AF%E5%8F%A3%E4%B9%9F%E6%B2%A1%E6%9C%89%E6%89%93%E5%8D%B0%E6%97%A5%E5%BF%97%E3%80%82%20%E8%AF%B7%E6%8C%87%E5%87%BA%E6%88%91%E5%93%AA%E9%87%8C%E6%B2%A1%E6%9C%89%E6%AD%A3%E7%A1%AE%E9%85%8D%E7%BD%AE%EF%BC%9FTKS.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Dzen_0-1777377240626.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Dzen_0-1777377240626.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Dzen_0-1777377240626.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Dzen_0-1777377240626.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383867i7ECA2ADD34B640AF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Dzen_0-1777377240626.png%22%20alt%3D%22Dzen_0-1777377240626.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%AE%BE%E5%A4%87%E6%A0%91%E9%85%8D%E7%BD%AE%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CDIV%3E%3CSPAN%3E%E5%86%85%E5%AD%98%4040000000%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edevice_type%20%3D%22%E5%86%85%E5%AD%98%22%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%26lt%3B0x0%200x40000000%200%200x40000000%26gt%3B%3B%20%2F%20*%201GB%20DDR%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%A2%84%E7%95%99%E5%86%85%E5%AD%98%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23address-cells%20%3D%26lt%3B2%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23size-cells%20%3D%26lt%3B2%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%8C%83%E5%9B%B4%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%2F*%20128MB%20*%2F%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Elinux%2Ccma%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompatible%20%3D%22shared-dma-pool%22%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%8F%AF%E9%87%8D%E5%A4%8D%E4%BD%BF%E7%94%A8%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Esize%20%3D%26lt%3B0%200x8000000%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ealloc-ranges%20%3D%26lt%3B0%200x40000000%200%200x40000000%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Elinux%2Ccma-default%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20%E4%B8%BA%E5%9C%A8%20CM7%20%E4%B8%8A%E8%BF%90%E8%A1%8C%E7%9A%84%20RTOS%20%E9%A2%84%E7%95%99%2016MB%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Em7_reserved%3A%20m7%407E000000%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%97%A0%E5%9C%B0%E5%9B%BE%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%26lt%3B0%200x7E000000%200%200x1000000%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Evdev0vring0%3A%20vdev0vring0%407D000000%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%26lt%3B0%200x7D000000%200%200x8000%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%97%A0%E5%9C%B0%E5%9B%BE%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Evdev0vring1%3A%20vdev0vring1%407D008000%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%26lt%3B0%200x7D008000%200%200x8000%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%97%A0%E5%9C%B0%E5%9B%BE%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Evdevbuffer%3A%20vdevbuffer%407D100000%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompatible%20%3D%22shared-dma-pool%22%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%26lt%3B0%200x7D100000%200%200x100000%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%97%A0%E5%9C%B0%E5%9B%BE%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ersc_table%3A%20rsc-table%407D0FF000%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%26lt%3B0%200x7D0FF000%200%200x1000%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%97%A0%E5%9C%B0%E5%9B%BE%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EIMX8MP-CM7%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%85%BC%E5%AE%B9%20%3D%22FSL%2Cimx8mn-cm7%22%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ersc-da%20%3D%26lt%3B0x7D000000%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eclocks%20%3D%26lt%3B%26amp%3B%20clk%20IMX8MP_CLK_M7_DIV%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eclock-names%20%3D%22core%22%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Embox-names%20%3D%22tx%22%2C%22rx%22%2C%22rxdb%22%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emboxes%20%3D%26lt%3B%26amp%3B%20mu%200%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%CE%BC%201%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%CE%BC%203%201%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ememory-region%20%3D%26lt%3B%26amp%3B%20m7_reserved%26gt%3B%20%E3%80%81%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%26amp%3Bvdevbuffer%26gt%3B%20%E3%80%81%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%26amp%3Bvdev0vring0%26gt%3B%20%E3%80%81%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%26amp%3Bvdev0vring1%26gt%3B%20%E3%80%81%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%26amp%3Brsc_table%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Estatus%20%3D%22okay%22%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Efsl%EF%BC%8Cstartup-delay-ms%20%3D%26lt%3B500%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2357824%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358269%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20When%20executing%20the%20CM7%20firmware%20using%20the%20IMX8MP%20Linux%20system%2C%20the%20system%20blocked%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358269%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6%E6%94%AF%E6%8C%81%E5%9B%A2%E9%98%9F%E4%BB%8B%E5%85%A5%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%88%91%E4%BB%AC%E4%BC%9A%E7%BB%99%E6%82%A8%E4%B8%80%E4%BA%9B%E5%BB%BA%E8%AE%AE%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E6%AD%A4%E6%A0%91%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Ftree%2Flf-6.18.y%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Ftree%2Flf-6.18.y%3C%2FA%3E%E5%92%8C%E6%AD%A4%20dts%20%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.18.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp-evk-rpmsg.dts%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.18.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp-evk-rpmsg.dts%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20When%20executing%20the%20CM7%20firmware%20using%20the%20IMX8MP%20Linux%20system%2C%20the%20system%20blocked%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262200%22%20target%3D%22_blank%22%3E%40Dzen%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E4%BD%A0%E4%B8%80%E5%88%87%E9%83%BD%E5%A5%BD%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%B0%86%E8%AE%BE%E5%A4%87%E6%A0%91%E9%85%8D%E7%BD%AE%E4%B8%BA%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN5317.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20AN5317%3C%2FA%3E%20%E7%AC%AC%209.1%3CSTRONG%3E%20%E7%AB%A0%20i.MX%20Linux%20rproc%20%E6%94%AF%E6%8C%81%3C%2FSTRONG%3E%20%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Manuel_Salas_0-1777487647626.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Manuel_Salas_0-1777487647626.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Manuel_Salas_0-1777487647626.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384043i42B27F0E13AA46A7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Manuel_Salas_0-1777487647626.png%22%20alt%3D%22Manuel_Salas_0-1777487647626.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Manuel_Salas_1-1777487671308.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Manuel_Salas_1-1777487671308.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Manuel_Salas_1-1777487671308.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384044iDEDC87AAA098E234%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Manuel_Salas_1-1777487671308.png%22%20alt%3D%22Manuel_Salas_1-1777487671308.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Manuel_Salas_2-1777487713858.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Manuel_Salas_2-1777487713858.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Manuel_Salas_2-1777487713858.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384045i3DD5D392DFA43EEF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Manuel_Salas_2-1777487713858.png%22%20alt%3D%22Manuel_Salas_2-1777487713858.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Manuel_Salas_3-1777487727875.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Manuel_Salas_3-1777487727875.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Manuel_Salas_3-1777487727875.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384046iCF034DC4E1D44337%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Manuel_Salas_3-1777487727875.png%22%20alt%3D%22Manuel_Salas_3-1777487727875.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%B8%8E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F161047%22%20target%3D%22_blank%22%3E%40dbaluta%3C%2FA%3E%E7%9A%84%E5%BB%BA%E8%AE%AE%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%90%A8%E6%8B%89%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2362698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20When%20executing%20the%20CM7%20firmware%20using%20the%20IMX8MP%20Linux%20system%2C%20the%20system%20blocked%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2362698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%81%20%3C%2FP%3E%3CP%3E%E9%80%9A%E8%BF%87%E5%9C%A8%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%E4%B8%AD%E5%8F%91%E9%80%81%E5%91%BD%E4%BB%A4%20%22%20run%20prepare_mcore%20%22%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E8%83%BD%E5%A4%9F%E4%BD%BF%E7%94%A8%20sysfs%20%E6%96%B9%E6%B3%95%E8%BF%90%E8%A1%8C%20CM7%20%E7%9A%84%E5%9B%BA%E4%BB%B6%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E5%9C%A8%20CM7%20%E5%9B%BA%E4%BB%B6%E8%BF%90%E8%A1%8C%E6%9C%9F%E9%97%B4%EF%BC%8C%E4%BB%8D%E5%87%BA%E7%8E%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%E9%A1%B9%E7%9B%AE%20%22%20boards%5C%20evkmimx8mp%5C%20demo_apps%5C%20hello_world%20%22%E3%80%82%E4%BB%8E%E6%97%A5%E5%BF%97%E6%9D%A5%E7%9C%8B%EF%BC%8C%E4%BC%BC%E4%B9%8E%E6%98%AF%20SAI%2F%E9%9F%B3%E9%A2%91%E9%85%8D%E7%BD%AE%E5%87%BA%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%E4%BD%86%E6%88%91%E5%B7%B2%E7%BB%8F%E5%88%A0%E9%99%A4%E4%BA%86%20clock_config.c%20%E4%B8%AD%E4%B8%8E%E9%9F%B3%E9%A2%91%E6%9C%89%E5%85%B3%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%88%E8%A7%81%E9%99%84%E4%BB%B6%EF%BC%89%E3%80%82%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%E4%BD%86%E9%94%99%E8%AF%AF%E4%BB%8D%E7%84%B6%E5%8F%91%E7%94%9F%E3%80%82%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%EF%BC%8C%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%80%E4%B9%88%E5%9C%B0%E6%96%B9%E4%BF%AE%E6%94%B9%E4%B8%8D%E5%BD%93%EF%BC%9F%3C%2FP%3E%3CBLOCKQUOTE%3E%3CBR%20%2F%3E%3CP%3E%5B122.890817%5D%20%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%EF%BC%9A%E5%90%8C%E6%AD%A5%E5%A4%96%E9%83%A8%E4%B8%AD%E6%AD%A2%EF%BC%9A0000000096000210%20%5B%231%5D%20PREEMPT_RT%20SMP%3CBR%20%2F%3E%5B%20122.890822%5D%20%E9%93%BE%E6%8E%A5%E7%9A%84%E6%A8%A1%E5%9D%97%EF%BC%9Afsl_jr_uio%20caam_jr%20caamkeyblob_desc%20caamhash_desc%20caamalg_desc%20crypto_engine%20authenc%20libdes%20crct10dif_ce%20snd_soc_imx_card%20polyval_ce%20polyval_generic%20snd_soc_fsl_micfil%20snd_soc_fsl_sai%20snd_soc_fsl_utils%20imx_pcm_dma%20snd_soc_tas5805m%20caam%20secvio%20error%20leds_serial_gpio%20%E7%86%94%E4%B8%9D%3CBR%20%2F%3E%5B%20122.890866%5D%20CPU%EF%BC%9A0%20PID%EF%BC%9A248%20%E9%80%9A%E4%BF%A1%EF%BC%9Airq%2F221-sai%20%E6%9C%AA%E5%8F%97%E6%B1%A1%E6%9F%93%206.6.36-rt35-lts-next%231%20%3CBR%20%2F%3E%20%5B122.890873%5D%20%E7%A1%AC%E4%BB%B6%E5%90%8D%E7%A7%B0%EF%BC%9A%E6%81%A9%E6%99%BA%E6%B5%A6%20i.mx8mPlus%20EVK%20%E6%9D%BF%20(DT)%20%5B122.890875%5D%20pstate%EF%BC%9A2000005%20(nzCV%20daif-PAN-UAO-TCO-DIT-SSBS%20BTYPE%3D--)%20%3CBR%20%2F%3E%20%5B122.890881%5D%20pc%EF%BC%9Aregmap_mmio_read32le%2B0x8%2F0x60%20%5B122.890881%5D%20pc%EF%BC%9Aregmap_mmio_read32le%2B0x8%2F0x60%20%5B122.890881%5D%20pc%EF%BC%9Aregmap_mmio_read32le%2B0x8%2F0x60%20%5B122.890881%5D%20pc%EF%BC%9A891%5D%20lr%EF%BC%9Aregmap_mmio_read%2B0x44%2F0x70%20%5B122.890896%5D%20sp%EF%BC%9Afff800082fccc0%20%5B122.890898%5D%20x29%EF%BC%9Afff800082fccc0%20x28%EF%BC%9A00000000000000%20x27%EF%BC%9A00000000000000%20%3CBR%20%2F%3E%20%5B122.890905%5D%20x26%EF%BC%9Afff8000800f3ee90%20x25%EF%BC%9Affff8000800f198c%20x24%EF%BC%9Afff000005f3b500%20%5B122.890913%5D%20x23%EF%BC%9Affff000005b60000%20x22%EF%BC%9Afff000005bea400%20x%20%3CBR%20%2F%3E%2021%EF%BC%9Afff800082fcbd84%20%5B122.890920%5D%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Ex20%EF%BC%9A0000000000000008%20x19%EF%BC%9Affff000005afecc0%20x18%EF%BC%9Afffffffffffffff%20%3CBR%20%2F%3E%20%5B122.890928%5D%20x17%EF%BC%9A00000001000000%20x16%EF%BC%9A000010003d000000%20x15%EF%BC%9Affff000036d5ac40%20%5B122.890935%5D%20x14%EF%BC%9A00000505d7fc02f4%20x13%EF%BC%9A00143f3f4%20c7cb53818%20x12%3A00000000000055%20%5B122.890942%5D%20x11%3A00000000000001%20x10%3A000000000000a10%20x9%3A%20ffff800082fcbd30%20%5B122.890951%5D%20x8%3A%20ffff000008096170%20x7%3A%20fff00000036d5a440%20x6%3A00000000143f3c%20%5B122.890951%5D%20x7%3A%20fff00000036d5a440%20x6%3A00000000143f3c%20%5B122.890951%5D%20x7%3A%20fff00000036d5a440%20x6%3A00000000143f3c%20%3CBR%20%2F%3E%20%5B122.890951%5D%20890957%5D%20x5%EF%BC%9Affff80008098ce58%20x4%EF%BC%9A00000000000008%20x3%EF%BC%9A00000000000008%20%5B122.890964%5D%20x2%EF%BC%9Affff80008098d5d8%20x1%EF%BC%9A00000000000008%20x0%EF%BC%9Afff800082%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Efb0008%20%5B122.890971%5D%20%3CBR%20%2F%3E%E9%80%9A%E8%AF%9D%E8%BF%BD%E8%B8%AA%EF%BC%9A%3CBR%20%2F%3E%5B122.890974%5D%20regmap_mmio_read32le%2B0x8%2F0x60%3CBR%20%2F%3E%5B122.890979%5D%20_regmap_%E6%80%BB%E7%BA%BF_reg_read%2B0x70%2F0xb0%3CBR%20%2F%3E%5B122.890986%5D%20_regmap_read%2B0x60%2F0xd8%3CBR%20%2F%3E%5B122.890993%5D%20regmap_read%2B0x4c%2F0x78%3CBR%20%2F%3E%5B122.890998%5D%20fsl_sai_isr%2B0x48%2F0xec%20%5Bsnd_soc_fsl_sai%5D%3CBR%20%2F%3E%5B122.891012%5D%20irq_forced_thread_fn%2B0x3c%2F0xc8%3CBR%20%2F%3E%5B122.891021%5D%20irq_thread%2B0x174%2F0x23c%3CBR%20%2F%3E%5B122.891028%5D%20kthread%2B0x110%2F0x114%3CBR%20%2F%3E%5B122.891034%5D%20ret_from_fork%2B0x10%2F0x20%3CBR%20%2F%3E%5B122.891043%5D%20%E4%BB%A3%E7%A0%81%EF%BC%9Ab5000001%20d65f03c0%20f9400000%208b214000%20(b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x0%2C00000008%2C00020000%2C1000421b%3CBR%20%2F%3E%5B122.891068%5D%20%E5%86%85%E5%AD%98%E9%99%90%E5%88%B6%EF%BC%9A%E6%97%A0%3CBR%20%2F%3E%5B123.748394%5D%20---%5B%20%E7%BB%93%E6%9D%9F%E5%86%85%E6%A0%B8%E6%81%90%E6%85%8C%20-%20%E6%97%A0%E6%B3%95%E5%90%8C%E6%AD%A5%EF%BC%9A%E5%90%8C%E6%AD%A5%E5%A4%96%E9%83%A8%E4%B8%AD%E6%AD%A2%EF%BC%9A%E4%B8%AD%E6%96%AD%E5%87%BA%E7%8E%B0%E8%87%B4%E5%91%BD%E5%BC%82%E5%B8%B8%20%5D---%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E
