When I add sd peripheral and freeRtos, the generated code not compile.
1,514 次查看
Yerih
I'm using i.MXRT1052 mcu with Expresso IDE.
SDK version is 2.12.0.
It's because the os abstraction doens't merge with freeRTOS abstraction, so thats files come into conflict.
Check the image
1,505 次查看
jingpan
Hi @Yerih ,
There is  sdio_freertos example in SDK_2_12_0_MIMXRT1050-EVK\boards\evkmimxrt1050\driver\sdio. You can refer to it.
Jing
