Wait for Known USB Device Appear...
2,142件の閲覧回数
Ahelion
Hi all,
I have this : https://www.nxp.com/design/development-boards/i-mx-evaluation-and-development-boards/i-mx-8m-plus-ev...
I tried to flash an android on a sd card as mention in the documents and just get this:
"Wait for Known USB Device Appear... at path /dev/ttyUSB6"
I am on Linux Ubuntu 22.04.
Anybody know what the issue could be? other post did not help,
Boot switches set to 0001 as described,
command is:
sudo ./uuu_imx_android_flash.sh -f imx8mp -a -e -D ./  -t sd  -d mipi-panel -usb /dev/ttyUSB6
I think it is USB6 because this is where the UART was comming from.
Br , Mircea
タグ(1)
2,126件の閲覧回数
Chavira
Hi @Ahelion!
Thank you for contacting NXP Support!
To flash your EVK board you have to connect the USB C (PORT1) of your board to the host computer and then turn on the board with the sw4 in download mode.
I recommend reading the Android Quick Start guide to understand how to flash your board
https://www.nxp.com/docs/en/quick-reference-guide/ANDROID_QUICK_START_GUIDE.pdf
Best Regards!
Chavira
