Video geometric transform
4,273 次查看
saurabh206
Senior Contributor III
Anyone has tried to do geometric transform on Video playback?
I want to do stretch, rotate and tilt the video playback.
Any suggestions from expert group.
Saurabh
标签 (3)
标记 (1)
5 回复数
3,770 次查看
igorpadykov
Hi Saurabh
please check gstreamer scaling examples
GStreamer i.MX6 Pipelines
VPU rotation (it does not support resize)
mxc_vpu_test.out test:
-r <rotation angle> 0, 90, 180, 270
default rotation is disabled (0)
example of usage can be found below:
MPEG4 decode error on imx-6q
IPU resizing examples
ipu-examples release notes - v0.1
3,770 次查看
saurabh206
Thanks for reply,
I want to rotate @ 10 to 15 rotation angle does it possible?
Saurabh
3,769 次查看
igorpadykov
Hi Saurabh
VPU can rotate only 0, 90, 180, or 270.
please check attached document:
SET_ROTATION_ANGLE
3,769 次查看
saurabh206
I know VPU can rotate 0,90,180 or 270.
For my requirement I need to rotate the data after decoding.
Saurabh
3,769 次查看
igorpadykov
Hi Saurabh
the same is for IPU
