Verifying images in HAB in Linux or OPTEE
nicholash
Hi, I'm trying to work on an update procedure on an IMX6UL that checks to see if an image will pass the HAB check before updating the images. I'm having trouble accessing the boot ROM from OPTEE so I need to re-implement the authentication function in as a TA in OPTEE or failing that as a regular Linux application, similar to the uboot command hab_auth_img. Is there any code available for this? Is there a way to make the CST do this?
Labels (2)
nicholash
Hi, is there any solution this? This seems like a fairly common use case that will stop people bricking their devices.
Yuri
  I've sent You directly some considerations.
Yuri
lijiangning
We also have the requirement to perform kernel signature verification within OP-TEE. Could you provide the methodology and an implementation (code) for this?
thanks
gcornacchia
Hi Yuri,
I'm trying to use hab checking function for imxull in kernel userspace is there any implementation?
Can you share your considerations?
What I would like to achive is a signature checking
thank you
Yuri
@gcornacchia
  There is no the hab checking in  userspace.
Yuri.
%3CLINGO-SUB%20id%3D%22lingo-sub-1029061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EVerifying%20images%20in%20HAB%20in%20Linux%20or%20OPTEE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1029061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20I'm%20trying%20to%20work%20on%20an%20update%20procedure%20on%20an%20IMX6UL%20that%20checks%20to%20see%20if%20an%20image%20will%20pass%20the%20HAB%20check%20before%20updating%20the%20images.%20I'm%20having%20trouble%20accessing%20the%20boot%20ROM%20from%20OPTEE%20so%20I%20need%20to%20re-implement%20the%20authentication%20function%20in%20as%20a%20TA%20in%20OPTEE%20or%20failing%20that%20as%20a%20regular%20Linux%20application%2C%20similar%20to%20the%20uboot%20command%20hab_auth_img.%20Is%20there%20any%20code%20available%20for%20this%3F%20Is%20there%20a%20way%20to%20make%20the%20CST%20do%20this%3F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1029061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6UL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ESecurity%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2169623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Verifying%20images%20in%20HAB%20in%20Linux%20or%20OPTEE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2169623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWe%20also%20have%20the%20requirement%20to%20perform%20kernel%20signature%20verification%20within%20OP-TEE.%20Could%20you%20provide%20the%20methodology%20and%20an%20implementation%20(code)%20for%20this%3F%3C%2FP%3E%3CP%3Ethanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1232735%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Verifying%20images%20in%20HAB%20in%20Linux%20or%20OPTEE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1232735%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F183308%22%20target%3D%22_blank%22%3E%40gcornacchia%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3EHello%2C%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%20There%20is%20no%20the%26nbsp%3B%3CSPAN%3Ehab%20checking%20in%26nbsp%3B%20userspace.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ERegards%2C%3CBR%20%2F%3EYuri.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1231901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Verifying%20images%20in%20HAB%20in%20Linux%20or%20OPTEE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1231901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Yuri%2C%3C%2FP%3E%3CP%3EI'm%20trying%20to%20use%20hab%20checking%20function%20for%20imxull%20in%20kernel%20userspace%20is%20there%20any%20implementation%3F%3C%2FP%3E%3CP%3ECan%20you%20share%20your%20considerations%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EWhat%20I%20would%20like%20to%20achive%20is%20a%20signature%20checking%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ethank%20you%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1029063%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Verifying%20images%20in%20HAB%20in%20Linux%20or%20OPTEE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1029063%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EHello%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20I've%20sent%20You%20directly%20some%20considerations.%20%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EHave%20a%20great%20day%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EYuri%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E-------------------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3ENote%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1029062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Verifying%20images%20in%20HAB%20in%20Linux%20or%20OPTEE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1029062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20is%20there%20any%20solution%20this%3F%20This%20seems%20like%20a%20fairly%20common%20use%20case%20that%20will%20stop%20people%20bricking%20their%20devices.%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
