VPU decoder VPU_DEC_NO_ENOUGH_BUF
4,552件の閲覧回数
Tarek
Senior Contributor I
I'm playing live stream from a remote camera using the VPU Wrapper for decoding and IPU mxc_ipu dev for display. The video runs smoothly for about 3 to 4 minutes then VPU_DecDecodeBuf() starts returning
VPU_DEC_INPUT_USED,
VPU_DEC_OUTPUT_NODIS,
VPU_DEC_NO_ENOUGH_BUF then the video stops.
I've double checked that all the allocated video buffers are cleared once displayed by calling VPU_DecOutFrameDisplayed().
When I enabled VPU debugging I get the following messages:
1_repeatFrame: 0,interlacedFrame: 0, indexFrameRangemap: 0, progressiveFrame: 0, topFieldFirst: 0
aspect ratio: format: 0, ratio: 0x1, InWidth: 640, InHeight: 480
return Q16Ratio: 0x10000, [OutWidth,OutHeight]=[65536, 65536]
one decoded frame: start: 0x18D76ACA, end: 0x18D797C1
VpuAccumulateConsumedBytes: size: 11511, type: 2
last end: 0x18D76ACA, start: 0x18D76ACA, buf start: 0x18C00000, buf end: 0x18F00000, stuff size: 0
indexFrameDisplay=2
frame : (P)
VpuGetOutput: Ref frame 1
VpuCheckDeadLoop: total_dec_size: 0, total_dec_loop: 0, total_null_loop: 1
calling vpu_DecGetBitstreamBuffer()
Wr: 0x18D8CD08, Rd: 0x18D79A00, space: 3065079
calling vpu_DecUpdateBitstreamBuffer(): 2997
nSpace: 3062082, filled : 83646
===================vpu_DecStartOneFrame: chunkSize: 0, search: 0
calling vpu_DecStartOneFrame(): 0, skipmode: 0
while: calling vpu_WaitForInt(500)
VPU_DecOutFrameDisplayed: calling vpu_DecClrDispFlag(): 2
calling vpu_DecGetOutputInfo()
calling vpu_DecGetOutputInfo(), indexFrmDec: 0, return indexFrmDis: 3, type: 0, success: 0x1, errMB: 0, consumed: 78793
fieldSequence: 0, vc1_repeatFrame: 0,interlacedFrame: 0, indexFrameRangemap: 0, progressiveFrame: 0, topFieldFirst: 0
one decoded frame: start: 0x18D797C1, end: 0x18D8CB8A
VpuAccumulateConsumedBytes: size: 78793, type: 2
last end: 0x18D797C1, start: 0x18D797C1, buf start: 0x18C00000, buf end: 0x18F00000, stuff size: 0
indexFrameDisplay=3
frame : (P)
VPU_DecOutFrameDisplayed: calling vpu_DecClrDispFlag(): 3
Wr: 0x18D8D8BD, Rd: 0x18D8CE00, space: 3140930
calling vpu_DecUpdateBitstreamBuffer(): 3217
nSpace: 3137713, filled : 8015
calling vpu_DecGetOutputInfo(), indexFrmDec: -1, return indexFrmDis: -3, type: 0, success: 0x1, errMB: 0, consumed: 78793
TSE: no enough frame buffer and return one output frame
Wr: 0x18D8E54E, Rd: 0x18D8CE00, space: 3137713
calling vpu_DecUpdateBitstreamBuffer(): 3009
nSpace: 3134704, filled : 11024
VpuCheckDeadLoop: total_dec_size: 3217, total_dec_loop: 1, total_null_loop: 2
Wr: 0x18D8F10F, Rd: 0x18D8CE00, space: 3134704
calling vpu_DecUpdateBitstreamBuffer(): 3225
nSpace: 3131479, filled : 14249
why the decoder is not using the available buffers and how should I retrieve the normal video stream display without restarting the process?
Note: I'm running BSP12.08 on Nitrogen Board and using Poky distribution Yocto build system.
ラベル(2)
5 返答(返信)
3,594件の閲覧回数
anishkhanna
hi, can you please provide the application you are using?
3,594件の閲覧回数
Tarek
Hi Anish,
I moved away from using the VPU API's as it's too complicated and proven to be unreliable "at least for my purpose!"
Gstreamer is more reliable for handling the decoding and save me a lot of headache but it's very limited in it's display capabilities.
I'm trying to learn OpenGL to use it for display while gstreamer for decoding I hope this will work.
In my opinion Freescale is not providing enough examples on how to use the i.MX6 platform. My application is simply playing multiple video stream and a GUI! There should be a similar example provided by Freescale but there isn't one:smileysad:
3,594件の閲覧回数
anishkhanna
Thanks Tarek El-Sherbiny for your information :smileyhappy:
3,594件の閲覧回数
Yongxin
Hi, can you let me know the chip related with this question?
3,594件の閲覧回数
Tarek
Chip is i.MX6Q
