I am trying to get the MCIMX-LVDS1 working with the QSB ultimately I would need to get it working with Android, but for now I would be happy to see it working with the Linux BSP.
I was able to get the MCIMX-LVDS1 to display the video however I have not got the touch interface working. If anyone has please let me know.
Hey people! I am in trouble trying to connect a custom LVDS display made by SAMSUNG to imx53qsb on the J9 (LVDS) connector (LCD Model: LT101NT02):
Here is my steps:
- Configuring a WSVGA resolution on mx53_loco.c as (watch the last entry of the array):
static struct fb_videomode video_modes[] = {
/* NTSC TV output */
"TV-NTSC", 60, 720, 480, 74074,
122, 15,
18, 26,
1, 1,
FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT,
FB_VMODE_INTERLACED,
0,},
/* PAL TV output */
"TV-PAL", 50, 720, 576, 74074,
132, 11,
22, 26,
1, 1,
FB_VMODE_INTERLACED | FB_VMODE_ODD_FLD_FIRST,
0,},
/* 1080i50 TV output */
"1080I50", 50, 1920, 1080, 13468,
192, 527,
20, 24,
1, 1,
0,},
/* 1080i60 TV output */
"1080I60", 60, 1920, 1080, 13468,
192, 87,
20, 24,
1, 1,
0,},
/* 800x480 @ 57 Hz , pixel clk @ 27MHz */
"CLAA-WVGA", 57, 800, 480, 37037, 40, 60, 10, 10, 20, 10,
FB_SYNC_CLK_LAT_FALL,
FB_VMODE_NONINTERLACED,
0,},
/* 800x480 @ 60 Hz , pixel clk @ 32MHz */
"SEIKO-WVGA", 60, 800, 480, 29850, 89, 164, 23, 10, 10, 10,
0,},
"XGA", 60, 1024, 768, 15385,
220, 40,
21, 7,
60, 10,
0,
0,},
/* 720p30 TV output */
"720P30", 30, 1280, 720, 13468,
260, 1759,
25, 4,
1, 1,
0,},
"720P60", 60, 1280, 720, 13468,
260, 109,
25, 4,
1, 1,
0,},
/* VGA 1280x1024 108M pixel clk output */
"SXGA", 60, 1280, 1024, 9259,
48, 248,
1, 38,
112, 3,
0,
0,},
/* 1600x1200 @ 60 Hz 162M pixel clk*/
"UXGA", 60, 1600, 1200, 6172,
304, 64,
1, 46,
192, 3,
FB_SYNC_HOR_HIGH_ACT|FB_SYNC_VERT_HIGH_ACT,
0,},
/* 1080p24 TV output */
"1080P24", 24, 1920, 1080, 13468,
192, 637,
38, 6,
1, 1,
0,},
/* 1080p25 TV output */
"1080P25", 25, 1920, 1080, 13468,
192, 527,
38, 6,
1, 1,
0,},
/* 1080p30 TV output */
"1080P30", 30, 1920, 1080, 13468,
192, 87,
38, 6,
1, 1,
0,},
"1080P60", 60, 1920, 1080, 7692,
100, 40,
30, 3,
10, 2,
0,
0,},
/* 1024x600 WSVGA @ 60 Hz, running @ 54.2Mhz pixclock
* Vertical Total: BackPorch + VSYNC + DATA + FrontPorch =
* 6 + 30 + 600 + 37 ----> 673
* Horizontal Total: BackPorch + HSYNC + DATA + FrontPorch =
* 125 + 126 + 1024 + 125 ----> 1400 */
.name = "WSVGA",
.refresh = 60,
.xres = 1024,
.yres = 600,
.pixclock = 18450,
.left_margin = 125,
.right_margin = 125,
.upper_margin = 6,
.lower_margin = 37,
.hsync_len = 126,
.vsync_len = 30,
.sync = 0,
.vmode = FB_VMODE_NONINTERLACED,
.flag = 0,
- Change the fb_data array as:
static struct mxc_fb_platform_data fb_data[] = {
#if 0
.interface_pix_fmt = IPU_PIX_FMT_RGB565,
.mode_str = "CLAA-WVGA",
.mode = video_modes,
.num_modes = ARRAY_SIZE(video_modes),
.interface_pix_fmt = IPU_PIX_FMT_BGR24,
.mode_str = "XGA",
#endif
.interface_pix_fmt = IPU_PIX_FMT_RGB666,
.mode_str = "WSVGA",
.interface_pix_fmt = IPU_PIX_FMT_LVDS666,
So both resolutions are IDENTICAL (I suppose), (note the RGB666 and LVDS666 on the interface_pix_format field...). then recompile the kernel with:
./ltib -p kernel -m scbuild
then changed the cmdline options in the bootloader as:
console=ttymxc0,115200 video=mxcdi0fb:LVDS666,WSVGA di0_primary video=mxcdi1fb:RGB666,WSVGA video=mxcdi2fb:RGB666,WSVGA root=/dev/nfs ip=192.168.143.173 nfsroot=192.168.143.6:/tftpboot/nfs-IMX53
,v3,tcp noinitrd
So the connector J9 (LVDS0 == DI0?) should have valid timings for a such display
Plug the cable on the J9 connector using 3 channels LVDS plus PWM for contrast and LCD_BLT_EN Lines connected tothe LVDS Panel pins named: PWM and LCD_BL.
Powering the backlight VLED unit with the correct Voltage using a Voltage Generator with 2A of MAX CURRENT.
But I do not see anything on the screen. Nothing.
Now here is the logs of fbset:
root@freescale ~$ fbset -fb /dev/fb0
mode "1024x600-58"
# D: 54.201 MHz, H: 38.715 kHz, V: 57.526 Hz
geometry 1024 600 1024 1800 16
timings 18450 125 125 6 37 126 30
accel false
rgba 5/11,6/5,5/0,0/0
endmode
root@freescale ~$ fbset -fb /dev/fb1
mode "1024x600-58"
accel false
endmode
root@freescale ~$ fbset -fb /dev/fb2
mode "240x320-60"
# D: 4.608 MHz, H: 19.200 kHz, V: 60.000 Hz
geometry 240 320 240 960 16
timings 217013 0 0 0 0 0 0
accel false
endmode
What I am doing wrong?
I verified it also with Freescale support.
Yes it's multi touch and yes LVDS interface cable is shipped with touch screen.
Thanks for your support.
I think it is mentor embedded inflexion ui that does not support the multitouch...
The 10.1" display (aka Hannstar) has a capacitative touchscreen and does support Multi-touch. You will need to include a driver for the controller (EGalax) in the BSP, see my earlier post on this thread.
Has anyone tried MCIMX-LVDS1 10.1'' if it supports multi touch ? HW Reference manual of QSB does not mention capacitive touch and only mentions about resisitive touch (single touch interface).
Tugrul
Update: when i type in $cat /dev/input/event1 and i touch the screen I see my console responding. So the touchscreen is working and the driver also. How do I couple the screen to my inflexion ui?
kind regards
Lieven
Lieven said:
Hello
I also have this problem. Upon reading through this topic I can not figure out what I have to do. I'm running the inflexion ui demo on an imx53 start board with the LVDS 10.1 touchscreen. Everything is running ok, only the touch interface is not working. I included the drivers while building my ltib, but I don't know what to do next to solve this. I'm a newbie on this issue so i hope someone is so kind to guid me through the process.
thanks in advance
Lieven
Hello
thanks in advance
Lieven
http://www.imxdev.org/wiki/index.php?title=IMX51_Ubuntu_USB_TS
See my previous answer (above) and read:
http://www.imxdev.org/wiki/index.php?title=IMX51_Ubuntu_TS_lucid
I have been able to get the touch screen working in Android using Adeneo's BSP
1: Edit the file i.MX53-QSB-Android-Gingerbread-Release4.0/src/kernel_imx/arch/arm/configs/imx5_android_defconfig change "#CONFIG_TOUCHSCREEN_EGALAX is not set" to "CONFIG_TOUCHSCREEN_EGALAX=y"
2: Recompile the kernel making sure to remove i.MX53-QSB-Android-Gingerbread-Release4.0/src/kernel/.config
3: Burn the new image
4: using uboot # setenv bootargs_android 'setenv bootargs ${bootargs} init=/init androidboot.console=ttymxc0 video=mxcdi0fb:RGB666,XGA di0_primary ldb=di0'
5: # saveenv
6: reboot
Do you know if this display supports true color (rgb24) mode?
Yuri
Hi Alan,
Thanks for the continuous help on this matter.
Let me tyy and explain a little bit on what I am trying to do.
We develop a QT application that should run on a bare bone Linux system, with no X environment, using the 10.1'' LVDS screen. Our QT build is configured to use tslib. Is there a way to use the touch screen without having to install and use Xserver and X environment ?
Chen
I understand. However, I didn't find any use of this configuration value within the kernel source that included in L2.6.35_11.01.00_ER_source.tar.gz. Do I have to get the driver from another source ?
Chen
@chen
I modified the configuration file directly. I did not use the configurator.
I am trying to configure the touch screen with 2.6.35 Linux kernel, but it seems that CONFIG_TOUCHSCREEN_EGALAX is not one of the option when I looked in Linux menu config (Device Drivers --> Input device Support -> touchscreen support.
Any idea ?
Chen
Yep. It worked for me after following your instructions. Thanks!!!
5: # saveenv
6: reboot
