Using GPT on i.MX8MM
eugenferarunxp
Can GPT be used on the A53 of the i.MX8M Mini? Is there an App Note on how to enable GPT as a node in the .dts file of an i.MX8M Mini platform, including the path to the node?
Any pointers would be greatly appreciated!
Thanks.
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
I didn't found any application that works with GPT but the drivers do exist, this is the driver.
You can also start with devmem as this post.
