Unable to update APP container software version for i.MX95 FlexSPI boot image
270 次查看
arun16598
Hello Experts,
I'm working on the i.MX95 platform and enabling rollback protection using ROLLBACK_INDEX_IN_CONTAINER.
I introduced the following variable in my local.conf:
export ROLLBACK_INDEX_IN_CONTAINER = "1"
This value is propagated through the build, and the build log confirms that mkimage_imx8 is invoked with "1"
When building an eMMC boot image, parsing the generated image shows the container software version updated correctly.
 if [ 1 ]; then \
./../mkimage_imx8 -soc IMX9 -cntr_version 2 -sw_version 1 -c \
-ap bl31.bin a55 0x8A200000 \
-ap u-boot-hash.bin a55 0x90200000 \
-ap tee.bin a55 0x8C000000 \
-out u-boot-atf-container.img; \
However, when building the FlexSPI boot image (imx-boot-imx95-19x19-verdin-fspi.bin-flash_a55_flexspi), parsing the image still reports the default SW version
./mkimage_imx8 -soc IMX9 -parse imx-boot-imx95-19x19-verdin-fspi.bin-flash_a55_flexspi
SOC: IMX9
Input container binary to be parsed: imx-boot-imx95-19x19-verdin-fspi.bin-flash_a55_flexspi
*          APP CONTAINER 1          *
        Length: 0X320 (800)
           Tag: 0X87
       Version: 0X2
         Flags: 0X10
    Num images: 6
  Fuse version: 0
    SW version: 0X0
Sig blk offset: 0X310
I noticed an interesting thing in iMX95/soc.mak as there is no sw_version included during the build for flash_a55_flexspi
flash_a55_flexspi: $(MKIMG) $(AHAB_IMG) $(MCU_IMG) $(SPL_A55_IMG) $(OEI_IMG_M33) fcb.bin u-boot-atf-container.img
        ./$(MKIMG) -soc IMX9 -cntr_version $(CTNR_VERSION) $(XSPI_FAST_HASH) -dev flexspi -append $(AHAB_IMG) -c $(OEI_OPT_M33) -msel $(MSEL) \
                   -m33 $(MCU_IMG) 0 $(MCU_TCM_ADDR) \
                   -ap $(SPL_A55_IMG) a55 $(SPL_LOAD_ADDR_M33_VIEW) $(V2X_DUMMY) -fcb fcb.bin $(FCB_LOAD_ADDR) -out flash.bin
        $(call append_container,u-boot-atf-container.img,1)
        $(call append_fcb)
My questions are:
  1. Is ROLLBACK_INDEX_IN_CONTAINER expected to update the software version for FlexSPI boot images?
  2. Does the FlexSPI image follow a different container generation flow where the rollback index/software version must be configured separately?
  3. Is this a known limitation or issue in the i.MX95 imx-mkimage build flow?
If anyone has successfully enabled ROLLBACK_INDEX_IN_CONTAINER for FlexSPI boot images on i.MX95, could you please share the expected flow or any additional configuration required?
Thanks in advance!
Arun Kumar
162 次查看
Zhiming_Liu
Hi @arun16598
The FlexSPI image is not another variant of the AHAB format, but it employs a combined process of first generating the boot container, then appending the U-Boot/ATF container. Your -sw_version 1 is set on u-boot-atf-container.img; however, the APP container containing SM/M33, OEI, SPL, and FCB—which flash_a55_flexspi creates first—does not pass the -sw_version option, so that container still displays SW version: 0. ROLLBACK_INDEX_IN_CONTAINER is used to generate the secondary U-Boot/ATF APP container, but it is not passed to the primary APP container created by flash_a55_flexspi. If the same software version is required for the first FlexSPI APP container, -sw_version $(ROLLBACK_INDEX_IN_CONTAINER) must also be added to the mkimage_imx8 invocation in flash_a55_flexspi.
If the goal is true AHAB anti-rollback enforcement, the key settings to verify and configure are fuse_version and -fuse_version, not just sw_version. The SPSDK’s i.MX95 anti-rollback example clearly states that OEM anti-rollback uses the fuse_version specified in the AHAB container YAML, and the version is subsequently submitted via the ELE’s OEM_FW_FUSE commit process.
Zhiming
%3CLINGO-SUB%20id%3D%22lingo-sub-2395039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A0%E6%B3%95%E6%9B%B4%E6%96%B0%20i.MX95%20FlexSPI%20%E5%90%AF%E5%8A%A8%E6%98%A0%E5%83%8F%E7%9A%84%20APP%20%E5%AE%B9%E5%99%A8%E8%BD%AF%E4%BB%B6%E7%89%88%E6%9C%AC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%90%84%E4%BD%8D%E4%B8%93%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20i.MX95%20%E5%B9%B3%E5%8F%B0%EF%BC%8C%E5%B9%B6%E5%90%AF%E7%94%A8%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3EROLLBACK_INDEX_IN_CONTAINER%20%E7%9A%84%3C%2FSPAN%3E%3C%2FSTRONG%3E%E5%9B%9E%E6%BB%9A%E4%BF%9D%E6%8A%A4%E5%8A%9F%E8%83%BD%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%E6%88%91%E5%9C%A8%3CSPAN%3Elocal.conf%3C%2FSPAN%3E%3CSPAN%3E%E6%96%87%E4%BB%B6%E4%B8%AD%E5%BC%95%E5%85%A5%E4%BA%86%E4%BB%A5%E4%B8%8B%E5%8F%98%E9%87%8F%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%3Eexport%20ROLLBACK_INDEX_IN_CONTAINER%20%3D%20%221%22%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E8%AF%A5%E5%80%BC%E4%BC%9A%E5%9C%A8%E6%95%B4%E4%B8%AA%E6%9E%84%E5%BB%BA%E8%BF%87%E7%A8%8B%E4%B8%AD%E4%BC%A0%E9%80%92%EF%BC%8C%E6%9E%84%E5%BB%BA%E6%97%A5%E5%BF%97%E8%AF%81%E5%AE%9E%3C%2FSPAN%3E%3CSPAN%3Emkimage_imx8%3C%2FSPAN%3E%3CSPAN%3E%E8%A2%AB%E8%B0%83%E7%94%A8%E6%97%B6%E4%BD%BF%E7%94%A8%E4%BA%86%E2%80%9C1%E2%80%9D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%9E%84%E5%BB%BA%3CSTRONG%3EeMMC%20%E5%90%AF%E5%8A%A8%E6%98%A0%E5%83%8F%3C%2FSTRONG%3E%E6%97%B6%EF%BC%8C%E8%A7%A3%E6%9E%90%E7%94%9F%E6%88%90%E7%9A%84%E9%95%9C%E5%83%8F%E6%98%BE%E7%A4%BA%E5%AE%B9%E5%99%A8%E8%BD%AF%E4%BB%B6%E7%89%88%E6%9C%AC%E5%B7%B2%E6%AD%A3%E7%A1%AE%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%26nbsp%3Bif%20%5B%201%20%5D%3B%20then%20%5C%3CBR%20%2F%3E.%2F..%2Fmkimage_imx8%20-soc%20IMX9%20-cntr_version%202%20%3CSTRONG%3E-sw_version%201%3C%2FSTRONG%3E%20-c%20%5C%3CBR%20%2F%3E-ap%20bl31.bin%20a55%200x8A200000%20%5C%3CBR%20%2F%3E-ap%20u-boot-hash.bin%20a55%200x90200000%20%5C%3CBR%20%2F%3E-ap%20tee.bin%20a55%200x8C000000%20%5C%3CBR%20%2F%3E-out%20u-boot-atf-container.img%3B%20%5C%3C%2FPRE%3E%3CP%20class%3D%22%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E7%84%B6%E8%80%8C%EF%BC%8C%E5%9C%A8%E6%9E%84%E5%BB%BA%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3EFlexSPI%20%E5%90%AF%E5%8A%A8%E9%95%9C%E5%83%8F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3Eimx-boot-imx95-19x19-verdin-fspi.bin-flash_a55_flexspi%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%E6%97%B6%EF%BC%8C%E8%A7%A3%E6%9E%90%E8%AF%A5%E9%95%9C%E5%83%8F%E4%BB%8D%E7%84%B6%E6%8A%A5%E5%91%8A%E9%BB%98%E8%AE%A4%E7%9A%84%E8%BD%AF%E4%BB%B6%E7%89%88%E6%9C%AC%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-css%22%3E%3CCODE%20translate%3D%22no%22%3E.%2Fmkimage_imx8%20-soc%20IMX9%20-parse%20imx-boot-imx95-19x19-verdin-fspi.bin-flash_a55_flexspi%0ASOC%3A%20IMX9%0AInput%20container%20binary%20to%20be%20parsed%3A%20imx-boot-imx95-19x19-verdin-fspi.bin-flash_a55_flexspi%0A%0A*********************************%0A*%09%09%09%09*%0A*%20%20%20%20%20%20%20%20%20%20APP%20CONTAINER%201%20%20%20%20%20%20%20%20%20%20*%0A*%09%09%09%09*%0A*********************************%0A%0A%20%20%20%20%20%20%20%20Length%3A%200X320%20(800)%0A%20%20%20%20%20%20%20%20%20%20%20Tag%3A%200X87%0A%20%20%20%20%20%20%20Version%3A%200X2%0A%20%20%20%20%20%20%20%20%20Flags%3A%200X10%0A%20%20%20%20Num%20images%3A%206%0A%20%20Fuse%20version%3A%200%0A%20%20%20%20SW%20version%3A%200X0%0ASig%20blk%20offset%3A%200X310%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E5%9C%A8%20iMX95%2Fsoc.mak%20%E4%B8%AD%E6%B3%A8%E6%84%8F%E5%88%B0%E4%B8%80%E4%B8%AA%E6%9C%89%E8%B6%A3%E7%9A%84%E5%9C%B0%E6%96%B9%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%9C%A8%E6%9E%84%E5%BB%BA%20flash_a55_flexspi%20%E6%97%B6%E6%B2%A1%E6%9C%89%E5%8C%85%E5%90%AB%20sw_version%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Eflash_a55_flexspi%3A%20%24(MKIMG)%20%24(AHAB_IMG)%20%24(MCU_IMG)%20%24(SPL_A55_IMG)%20%24(OEI_IMG_M33)%20fcb.bin%20u-boot-atf-container.img%0A%20%20%20%20%20%20%20%20.%2F%24(MKIMG)%20-soc%20IMX9%20-cntr_version%20%24(CTNR_VERSION)%20%24(XSPI_FAST_HASH)%20-dev%20flexspi%20-append%20%24(AHAB_IMG)%20-c%20%24(OEI_OPT_M33)%20-msel%20%24(MSEL)%20%5C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20-m33%20%24(MCU_IMG)%200%20%24(MCU_TCM_ADDR)%20%5C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20-ap%20%24(SPL_A55_IMG)%20a55%20%24(SPL_LOAD_ADDR_M33_VIEW)%20%24(V2X_DUMMY)%20-fcb%20fcb.bin%20%24(FCB_LOAD_ADDR)%20-out%20flash.bin%0A%20%20%20%20%20%20%20%20%24(call%20append_container%2Cu-boot-atf-container.img%2C1)%0A%20%20%20%20%20%20%20%20%24(call%20append_fcb)%3C%2FCODE%3E%3C%2FPRE%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CSPAN%3EROLLBACK_INDEX_IN_CONTAINER%3C%2FSPAN%3E%3CSPAN%3E%E6%98%AF%E5%90%A6%3C%2FSPAN%3E%3CSPAN%3E%E9%A2%84%E6%9C%9F%E4%BC%9A%E6%9B%B4%E6%96%B0%20FlexSPI%20%E5%90%AF%E5%8A%A8%E6%98%A0%E5%83%8F%E7%9A%84%E8%BD%AF%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EFlexSPI%20%E9%95%9C%E5%83%8F%E6%98%AF%E5%90%A6%E9%81%B5%E5%BE%AA%E4%B8%8D%E5%90%8C%E7%9A%84%E5%AE%B9%E5%99%A8%E7%94%9F%E6%88%90%E6%B5%81%E7%A8%8B%EF%BC%8C%E9%9C%80%E8%A6%81%E5%8D%95%E7%8B%AC%E9%85%8D%E7%BD%AE%E5%9B%9E%E6%BB%9A%E7%B4%A2%E5%BC%95%2F%E8%BD%AF%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E8%BF%99%E6%98%AF%20i.MX95%20%3CSPAN%3Eimx-mkimage%3C%2FSPAN%3E%3CSPAN%3E%E7%89%88%E6%9C%AC%E6%B5%81%E7%A8%8B%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%AD%E5%B7%B2%E7%9F%A5%E7%9A%84%E9%99%90%E5%88%B6%E6%88%96%E9%97%AE%E9%A2%98%E5%90%97%3C%2FSPAN%3E%EF%BC%9F%3C%2FLI%3E%3C%2FOL%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%E6%9C%89%E4%BA%BA%E5%B7%B2%E6%88%90%E5%8A%9F%E5%9C%A8%20i.MX95%20%E4%B8%8A%E4%B8%BA%20FlexSPI%20%E5%90%AF%E5%8A%A8%E6%98%A0%E5%83%8F%E5%90%AF%E7%94%A8%3C%2FSPAN%3E%3CSPAN%3EROLLBACK_INDEX_IN_CONTAINER%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%8C%E8%83%BD%E5%90%A6%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%8B%E9%A2%84%E6%9C%9F%E6%B5%81%E7%A8%8B%E6%88%96%E6%89%80%E9%9C%80%E7%9A%84%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E9%85%8D%E7%BD%AE%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%98%BF%E4%BC%A6%C2%B7%E5%BA%93%E9%A9%AC%E5%B0%94%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2396941%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20update%20APP%20container%20software%20version%20for%20i.MX95%20FlexSPI%20boot%20image%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2396941%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264405%22%20target%3D%22_blank%22%3E%40arun16598%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3EFlexSPI%20%E9%95%9C%E5%83%8F%E4%B8%8D%E6%98%AF%20AHAB%20%E6%A0%BC%E5%BC%8F%E7%9A%84%E5%8F%A6%E4%B8%80%E7%A7%8D%E5%8F%98%E4%BD%93%EF%BC%8C%E8%80%8C%E6%98%AF%E9%87%87%E7%94%A8%E4%BA%86%E4%B8%80%E7%A7%8D%E7%BB%84%E5%90%88%E8%BF%87%E7%A8%8B%EF%BC%8C%E5%8D%B3%E5%85%88%E7%94%9F%E6%88%90%E5%BC%95%E5%AF%BC%E5%AE%B9%E5%99%A8%EF%BC%8C%E7%84%B6%E5%90%8E%E9%99%84%E5%8A%A0%20U-Boot%2FATF%20%E5%AE%B9%E5%99%A8%E3%80%82%E6%82%A8%E7%9A%84%3CSTRONG%3E-sw_version%201%3C%2FSTRONG%3E%E5%B7%B2%E5%9C%A8%3CSTRONG%3Eu-boot-atf-container.img%3C%2FSTRONG%3E%E4%B8%8A%E8%AE%BE%E7%BD%AE%EF%BC%9B%E4%BD%86%E6%98%AF%EF%BC%8C%E5%8C%85%E5%90%AB%20SM%2FM33%E3%80%81OEI%E3%80%81SPL%20%E5%92%8C%20FCB%20%E7%9A%84%20APP%20%E5%AE%B9%E5%99%A8%EF%BC%88%20%3CSTRONG%3Eflash_a55_flexspi%3C%2FSTRONG%3E%E9%A6%96%E5%85%88%E5%88%9B%E5%BB%BA%EF%BC%89%E6%B2%A1%E6%9C%89%E4%BC%A0%E9%80%92%3CSTRONG%3E-sw_version%3C%2FSTRONG%3E%E9%80%89%E9%A1%B9%EF%BC%8C%E5%9B%A0%E6%AD%A4%E8%AF%A5%E5%AE%B9%E5%99%A8%E4%BB%8D%E7%84%B6%E6%98%BE%E7%A4%BA%3CSTRONG%3ESW%20%E7%89%88%E6%9C%AC%EF%BC%9A0%E3%80%82ROLLBACK_INDEX_IN_CONTAINER%3C%2FSTRONG%3E%E7%94%A8%E4%BA%8E%E7%94%9F%E6%88%90%E8%BE%85%E5%8A%A9%20U-Boot%2FATF%20APP%20%E5%AE%B9%E5%99%A8%EF%BC%8C%E4%BD%86%E5%AE%83%E6%B2%A1%E6%9C%89%E4%BC%A0%E9%80%92%E7%BB%99%3CSTRONG%3Eflash_a55_flexspi%3C%2FSTRONG%3E%E5%88%9B%E5%BB%BA%E7%9A%84%E4%B8%BB%20APP%20%E5%AE%B9%E5%99%A8%E3%80%82%E5%A6%82%E6%9E%9C%E7%AC%AC%E4%B8%80%E4%B8%AA%20FlexSPI%20APP%20%E5%AE%B9%E5%99%A8%E9%9C%80%E8%A6%81%E7%9B%B8%E5%90%8C%E7%9A%84%E8%BD%AF%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%8C%E5%88%99%E8%BF%98%E5%BF%85%E9%A1%BB%E5%B0%86%3CSTRONG%3E-sw_version%3C%2FSTRONG%3E%20%3CSTRONG%3E%24(ROLLBACK_INDEX_IN_CONTAINER)%3C%2FSTRONG%3E%E6%B7%BB%E5%8A%A0%E5%88%B0%3CSTRONG%3Eflash_a55_flexspi%3C%2FSTRONG%3E%E4%B8%AD%E7%9A%84%20mkimage_imx8%20%E8%B0%83%E7%94%A8%E4%B8%AD%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E7%9B%AE%E6%A0%87%E6%98%AF%E7%9C%9F%E6%AD%A3%E5%AE%9E%E7%8E%B0%20AHAB%20%E9%98%B2%E5%9B%9E%E6%BB%9A%E5%BC%BA%E5%88%B6%E6%89%A7%E8%A1%8C%EF%BC%8C%E5%88%99%E9%9C%80%E8%A6%81%E9%AA%8C%E8%AF%81%E5%92%8C%E9%85%8D%E7%BD%AE%E7%9A%84%E5%85%B3%E9%94%AE%E8%AE%BE%E7%BD%AE%E6%98%AF%3CSTRONG%3Efuse_version%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3E-fuse_version%3C%2FSTRONG%3E%20%EF%BC%8C%E8%80%8C%E4%B8%8D%E4%BB%85%E4%BB%85%E6%98%AF%3CSTRONG%3Esw_version%3C%2FSTRONG%3E%20%E3%80%82S%20%3CA%20href%3D%22https%3A%2F%2Fspsdk.readthedocs.io%2Fen%2Fv3.9.0%2Fexamples%2Fahab%2Fimx95%2Fimx95_anti_rollback_protection.html%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EPSDK%20%E7%9A%84%20i.MX95%20%E9%98%B2%E5%9B%9E%E6%BB%9A%E7%A4%BA%E4%BE%8B%3C%2FA%3E%E6%98%8E%E7%A1%AE%E6%8C%87%E5%87%BA%EF%BC%8COEM%20%E9%98%B2%E5%9B%9E%E6%BB%9A%E4%BD%BF%E7%94%A8%20AHAB%20%E5%AE%B9%E5%99%A8%20YAML%20%E4%B8%AD%E6%8C%87%E5%AE%9A%E7%9A%84%3CSTRONG%3Efuse_version%3C%2FSTRONG%3E%20%EF%BC%8C%E7%84%B6%E5%90%8E%E9%80%9A%E8%BF%87%20ELE%20%E7%9A%84%3CSTRONG%3EOEM_FW_FUSE%3C%2FSTRONG%3E%E6%8F%90%E4%BA%A4%E8%BF%87%E7%A8%8B%E6%8F%90%E4%BA%A4%E8%AF%A5%E7%89%88%E6%9C%AC%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E
