Unable to run su from Android app on Android Pie
nxpsri
I'm seeing this error :
    Caused by: android.view.InflateException: Binary XML file line #23: Binary XML file line #21: Error inflating class fragment
     Caused by: android.view.InflateException: Binary XML file line #21: Error inflating class fragment
     Caused by: java.io.IOException: Cannot run program "/system/xbin/su": error=13, Permission denied
for code:
    override fun onCreateView(
        inflater: LayoutInflater, container: ViewGroup?,
        savedInstanceState: Bundle?
    ): View? {
        _binding = FragmentFirstBinding.inflate(inflater, container, false)
         Runtime.getRuntime().exec("/system/xbin/su")
         Runtime.getRuntime().exec("/system/bin/ifconfig eth0 up")
        return binding.root
despite providing:
    <uses-permission android:name="android.permission.ACCESS_SUPERUSER"/>
    <uses-permission android:name="android.permission.FACTORY_TEST"
AND running:
adb shell setenforce 0
What else can I try to get "su" working from within the app? I need that to disable/enable Ethernet interface. On the rooted device, I'm able to run su from the shell without any problem.
