Hi.
Obviously, Xserver not runing.
Boot log:
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 3.10.53+g496fbe0 (eugene@imx) (gcc version 4.8.2 (GCC) ) #144 SMP PREEMPT Sun Apr 26 22:54:32 EEST 2015
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX6 Quad/DualLite (Device Tree), model: Freescale i.MX6 DualLite/Solo SABRE Automotive Board
cma: CMA: reserved 32 MiB at 1e000000
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 8 pages/cpu @809c7000 s8960 r8192 d15616 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
Kernel command line: console=ttymxc0,115200 nosmp root=/dev/nfs ip=192.168.0.102 nfsroot=192.168.0.100:/home/eugene/fsl-release-bsp/build/tmp/work/imx6solosabreauto-poky-linux-gnueabi/fsl-image-qt5/1.0-r0/rootfs,v3,tcp video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off mxc_hdmi.only_cea=1 fbmem=32M vmalloc=192M
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 256MB = 256MB total
Memory: 219004k/219004k available, 43140k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0x90800000 - 0xff000000 (1768 MB)
lowmem : 0x80000000 - 0x90000000 ( 256 MB)
pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
.text : 0x80008000 - 0x806cb0d8 (6925 kB)
.init : 0x806cc000 - 0x80711300 ( 277 kB)
.data : 0x80712000 - 0x8074d460 ( 238 kB)
.bss : 0x8074d460 - 0x807b395c ( 410 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Preemptible hierarchical RCU implementation.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
NR_IRQS:16 nr_irqs:16 16
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32050000, Cache size: 524288 B
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
CPU identified as i.MX6DL, silicon rev 1.1
Console: colour dummy device 80x30
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x80517290 - 0x805172e8
Brought up 1 CPUs
SMP: Total of 1 processors activated (1581.05 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
pinctrl core: initialized pinctrl subsystem
regulator-dummy: no parameters
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
Use WDOG1 as reset source
syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
vdd1p1: 800 <--> 1375 mV at 1125 mV
vdd3p0: 2800 <--> 3150 mV at 3000 mV
vdd2p5: 2000 <--> 2750 mV at 2425 mV
cpu: 725 <--> 1450 mV at 1150 mV
vddpu: 725 <--> 1450 mV
vddsoc: 725 <--> 1450 mV at 1175 mV
syscon 20e0000.iomuxc-gpr: regmap [mem 0x020e0000-0x020e0037] registered
syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6dl-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
bio: create slab <bio-0> at 0
mxs-dma 110000.dma-apbh: initialized
cs42888_supply: 3300 mV
vio1: 3300 mV
vio2: 3300 mV
vd: 3300 mV
va: 5000 mV
usb_h1_vbus: 5000 mV
usb_otg_vbus: 5000 mV
3P3V: 3300 mV
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c i2c-0: IMX I2C adapter registered
i2c i2c-1: IMX I2C adapter registered
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
Advanced Linux Sound Architecture Driver Initialized.
pureg-dummy: no parameters
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
Bus freq driver module loaded
futex hash table entries: 256 (order: 2, 16384 bytes)
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.22)
msgmni has been set to 491
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
mxc_sdc_fb fb.18: mxcfb_probe enter
mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0x1a:0xa0:0xc1
fbcvt: 1920x1080@60: CVT Name - 2.073M9
mxc_sdc_fb fb.18: di_pixfmt:0x33424752, bpp:0x20, di:1, ipu:0
mxc_sdc_fb fb.18: registered mxc display driver hdmi
mxc_sdc_fb fb.18: allocated fb @ paddr=0x8A17B8EC, size=8294400.
imx-ipuv3 2400000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
Console: switching to colour frame buffer device 240x67
mxc_sdc_fb fb.18: allocated fb @ paddr=0x8A17BCEC, size=460800.
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: initialized
imx-sdma 20ec000.sdma: loaded firmware 1.1
pfuze100-regulator 0-0008: unrecognized pfuze chip ID!
pfuze100-regulator: probe of 0-0008 failed with error -5
Serial: IMX driver
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
console [ttymxc0] enabled
serial: Freescale lpuart driver
imx sema4 driver is registered.
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
nand: device found, Manufacturer ID: 0x01, Chip ID: 0xf1
nand: AMD/Spansion S34ML01G100TFI00 1G 3.3V 8-bit
nand: 128MiB, SLC, page size: 2048, OOB size: 64
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
gpmi-nand 112000.gpmi-nand: driver registered.
CAN device driver interface
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ci_hdrc ci_hdrc.1: doesn't support gadget
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
i2c /dev entries driver
cpuidle: using governor ladder
cpuidle: using governor menu
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc2: no vqmmc regulator found
mmc2: no vmmc regulator found
mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
galcore: clk_get vg clock failed, disable vg!
Galcore version 5.0.11.25762
mmc2: host does not support reading read-only switch. assuming write-enable.
mmc2: new high speed SDHC card at address aaaa
mmcblk2: mmc2:aaaa SU04G 3.69 GiB
mmcblk2: p1 p2
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
mxc_asrc 2034000.asrc: mxc_asrc registered
mxc_vpu 2040000.vpu: VPU initialized
usbhid: USB HID core driver
fsl-asrc-p2p asrc_p2p.4: init pcm dma failed
NET: Registered protocol family 26
TCP: cubic registered
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
usb_otg_vbus: disabling
regulator-dummy: disabling
imx mcc test is registered.
snvs_rtc 20cc034.snvs-rtc-lp: setting system clock to 1970-01-01 00:00:00 UTC (0)
fec 2188000.ethernet eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=2188000.ethernet:01, irq=-1)
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
usb 1-1: new high-speed USB device number 2 using ci_hdrc
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 3 ports detected
libphy: 2188000.ethernet:01 - Link is Up - 100/Full
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
IP-Config: Guessing netmask 255.255.255.0
IP-Config: Complete:
device=eth0, hwaddr=00:01:02:03:04:05, ipaddr=192.168.0.102, mask=255.255.255.0, gw=255.255.255.255
host=192.168.0.102, domain=, nis-domain=(none)
bootserver=255.255.255.255, rootserver=192.168.0.100, rootpath=
ALSA device list:
No soundcards found.
VFS: Mounted root (nfs filesystem) readonly on device 0:11.
devtmpfs: mounted
Freeing unused kernel memory: 276K (806cc000 - 80711000)
INIT: version 2.88 booting
Starting udev
udevd[74]: starting version 182
Starting Bootlog daemon: bootlogd: cannot allocate pseudo tty: No such file or directory
bootlogd.
ALSA: Restoring mixer settings...
/usr/sbin/alsactl: load_state:1729: No soundcards found...
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
Mon Mar 23 18:29:00 UTC 2015
INIT: Entering runlevel: 5
Configuring network interfaces... ifup skipped for nfsroot interface eth0
run-parts: /etc/network/if-pre-up.d/nfsroot exited with return code 1
Starting Xserver
Starting system message bus: dbus.
Starting Connection Manager
Starting Dropbear SSH server: dropbear.
Starting rpcbind daemon...mxc_sdc_fb fb.18: allocated fb @ paddr=0x8A17B8EC, size=16727040.
mxc_sdc_fb fb.18: Unable to allocate framebuffer memory
detected fb_set_par error, error code: -12
done.
creating NFS state directory: done
starting statd: done
Starting advanced power management daemon: No APM support in kernel
(failed.)
NFS daemon support not enabled in kernel
Starting syslogd/klogd: done
* Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon [ ok ]
Starting Telephony daemon
Starting Linux NFC daemon
Starting OProfileUI server
Running local boot scripts (/etc/rc.local).
Stopping Bootlog daemon: bootlogd.
Poky (Yocto Project Reference Distro) 1.6.2 imx6solosabreauto /dev/ttymxc0
imx6solosabreauto login: startx
Password:
Login incorrect
imx6solosabreauto login: root
root@imx6solosabreauto:~# startx
hostname: imx6solosabreauto: Unknown host
xauth: file /home/root/.serverauth.655 does not exist
X.Org X Server 1.16.1
Release Date: 2014-09-21
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.16.0-30-generic x86_64
Current Operating System: Linux imx6solosabreauto 3.10.53+g496fbe0 #144 SMP PREEMPT Sun Apr 26 22:54:32 EEST 2015 armv7l
Build Date: 23 March 2015 01:33:52AM
Current version of pixman: 0.32.4
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Mar 23 18:29:29 2015
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(EE)
(EE) Backtrace:
(EE)
(EE) Segmentation fault at address 0x18
(EE)
Fatal server error:
(EE) Caught signal 11 (Segmentation fault). Server aborting
(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
xinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: server error
Here are the contents of the xorg.0.log:
root@imx6solosabreauto:/var/log# cat Xorg.0.log
[1206353.497]
[1206353.497] X Protocol Version 11, Revision 0
[1206353.497] Build Operating System: Linux 3.16.0-30-generic x86_64
[1206353.497] Current Operating System: Linux imx6solosabreauto 3.10.53+g496fbe0 #144 SMP PREEMPT Sun Apr 26 22:54:32 EEST 2015 armv7l
[1206353.497] Kernel command line: console=ttymxc0,115200 nosmp root=/dev/nfs ip=192.168.0.102 nfsroot=192.168.0.100:/home/eugene/fsl-release-bsp/build/tmp/work/imx6solosabreauto-poky-linux-gnueabi/fsl-image-qt5/1.0-r0/rootfs,v3,tcp video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off mxc_hdmi.only_cea=1 fbmem=28M vmalloc=192M
[1206353.497] Build Date: 23 March 2015 01:33:52AM
[1206353.498]
[1206353.498] Current version of pixman: 0.32.4
[1206353.498] Before reporting problems, check http://wiki.x.org
[1206353.498] Markers: (--) probed, (**) from config file, (==) default setting,
[1206353.499] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Mar 23 18:31:35 2015
[1206353.507] (==) Using config file: "/etc/X11/xorg.conf"
[1206353.507] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[1206353.508] (==) ServerLayout "Single Layout"
[1206353.509] (**) |-->Screen "HDMI Screen" (0)
[1206353.509] (**) | |-->Monitor "HDMI Monitor"
[1206353.509] (**) | |-->Device "HDMI"
[1206353.509] (**) Option "BlankTime" "0"
[1206353.509] (**) Option "StandbyTime" "0"
[1206353.510] (**) Option "SuspendTime" "0"
[1206353.510] (**) Option "OffTime" "0"
[1206353.510] (==) Automatically adding devices
[1206353.510] (==) Automatically enabling devices
[1206353.510] (==) Automatically adding GPU devices
[1206353.514] (WW) The directory "/usr/share/fonts/X11/TTF/" does not exist.
[1206353.514] Entry deleted from font path.
[1206353.514] (WW) The directory "/usr/share/fonts/X11/OTF/" does not exist.
[1206353.514] (WW) The directory "/usr/share/fonts/X11/Type1/" does not exist.
[1206353.519] (==) FontPath set to:
/usr/share/fonts/X11/misc/,
/usr/share/fonts/X11/100dpi/,
/usr/share/fonts/X11/75dpi/
[1206353.519] (==) ModulePath set to "/usr/lib/xorg/modules"
[1206353.519] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[1206353.519] (II) Loader magic: 0x1b3a20
[1206353.519] (II) Module ABI versions:
[1206353.519] X.Org ANSI C Emulation: 0.4
[1206353.519] X.Org Video Driver: 18.0
[1206353.519] X.Org XInput driver : 21.0
[1206353.519] X.Org Server Extension : 8.0
[1206353.537] (EE) systemd-logind: failed to get session: The name org.freedesktop.login1 was not provided by any .service files
[1206353.538] (II) xfree86: Adding drm device (/dev/dri/card0)
[1206353.539] (II) no primary bus or device found
[1206353.539] falling back to /sys/devices/platform/Vivante GCCore/drm/card0
[1206353.539] (II) LoadModule: "glx"
[1206353.544] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[1206353.572] (II) Module glx: vendor="X.Org Foundation"
[1206353.572] compiled for 1.16.1, module version = 1.0.0
[1206353.572] ABI class: X.Org Server Extension, version 8.0
[1206353.572] (==) AIGLX enabled
[1206353.572] (II) LoadModule: "vivante"
[1206353.577] (II) Loading /usr/lib/xorg/modules/drivers/vivante_drv.so
[1206353.580] (II) Module vivante: vendor="X.Org Foundation"
[1206353.580] compiled for 1.16.1, module version = 1.0.0
[1206353.580] Module class: X.Org Video Driver
[1206353.580] ABI class: X.Org Video Driver, version 18.0
[1206353.580] (II) VIVANTE: driver for vivante fb: VivanteGC500, VivanteGC2100,
VivanteGCCORE
[1206353.581] (--) using VT number 3
[1206353.619] (WW) Falling back to old probe method for vivante
[1206353.619] (II) Loading sub module "fbdevhw"
[1206353.619] (II) LoadModule: "fbdevhw"
[1206353.621] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[1206353.624] (II) Module fbdevhw: vendor="X.Org Foundation"
[1206353.624] compiled for 1.16.1, module version = 0.0.2
[1206353.624] ABI class: X.Org Video Driver, version 18.0
[1206353.625] (II) VIVANTE(0): using default device
[1206353.625] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[1206353.626] (II) VIVANTE(0): Device preferred mode 'fb0':S:1920x1080p-60
[1206353.626] (II) VIVANTE(0): Creating default Display subsection in Screen section
"HDMI Screen" for depth/fbbpp 24/32
[1206353.626] (==) VIVANTE(0): Depth 24, (==) framebuffer bpp 32
[1206353.626] (==) VIVANTE(0): RGB weight 888
[1206353.626] (==) VIVANTE(0): Default visual is TrueColor
[1206353.626] (==) VIVANTE(0): Using gamma correction (1.0, 1.0, 1.0)
[1206353.626] (**) VIVANTE(0): Option "fbdev" "/dev/fb0"
[1206353.626] (II) VIVANTE(0): checking modes against framebuffer device...
[1206353.626] (II) VIVANTE(0): checking modes against monitor...
[1206353.626] (II) VIVANTE(0): Use built in mode (bpp 32)
[1206353.626] (--) VIVANTE(0): Virtual size is 0x0 (pitch 0)
[1206353.626] (==) VIVANTE(0): DPI set to (96, 96)
[1206353.626] (II) Loading sub module "fb"
[1206353.626] (II) LoadModule: "fb"
[1206353.628] (II) Loading /usr/lib/xorg/modules/libfb.so
[1206353.631] (II) Module fb: vendor="X.Org Foundation"
[1206353.631] compiled for 1.16.1, module version = 1.0.0
[1206353.631] ABI class: X.Org ANSI C Emulation, version 0.4
[1206353.631] (II) Loading sub module "exa"
[1206353.631] (II) LoadModule: "exa"
[1206353.634] (II) Loading /usr/lib/xorg/modules/libexa.so
[1206353.636] (II) Module exa: vendor="X.Org Foundation"
[1206353.636] compiled for 1.16.1, module version = 2.6.0
[1206353.636] ABI class: X.Org Video Driver, version 18.0
[1206353.654] (WW) VIVANTE(0): unable to support largest resolution (Cannot allocate memory)(II) VIVANTE(0): FBDevPreInit: adjust display width 0
[1206353.654] (**) VIVANTE(0): PreInit done
[1206353.654] (EE)
[1206353.654] (EE) Backtrace:
[1206353.654] (EE)
[1206353.654] (EE) Segmentation fault at address 0x18
[1206353.655] (EE)
Fatal server error:
[1206353.655] (EE) Caught signal 11 (Segmentation fault). Server aborting
[1206353.655] (EE)
[1206353.655] (EE)
for help.
[1206353.655] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[1206353.655] (EE)
[1206353.806] (EE) Server terminated with error (1). Closing log file.
In my board 256MB memory. I change CMA to 64MB.
This is my first processor, the first Linux which I set.
Look forward to any ideas!
