Uboot UMS flashing
Uboot UMS flashing
3,688 次查看
Tanu_1827
I am using iMX8DXL processor, UMS(USB Mass Storage) flashing is enabled in u boot and working as expected like partitions are get mounted in Linux pc ubuntu.
My question is this ums flasing is works in windows? if yes means how?
7 回复数
3,647 次查看
Tanu_1827
Hello @Manuel_Salas
Flashed uboot ums enabled software and board is booting, stop at uboot
Once command is executed successfully, eMMC partition 1 and 2 will get mounted to the ubuntu PC
In Ubuntu PC working as expected.
In windows is possible to flash through ums and can we see mounted partition in windows PC?
3,613 次查看
Manuel_Salas
Hello @Tanu_1827
Yes, I tested by my side and tehre is not problem, the operating system (Windows or Linux) will detect the board as USB Mass Storage.
Best regards.
Salas.
3,558 次查看
Tanushree
hello @Manuel_Salas
Yes its detected as a USB. but in our case the partition is in ext4 filesystem which is not compatible on windows. its asking for a format the disk.
Tanushree
3,552 次查看
Manuel_Salas
Hello @Tanushree
Of course Windows does not support EXT4 natively, you can install a driver for Windows called Ext2Fsd that will read and write EXT4 or a tool called Ext2Read.
I hope this can helps.
Best regards.
Salas.
3,471 次查看
Tanushree
UMS utility on Windows is blocked by a read-only mounted partition, when we use Ext2Fsd tool
3,395 次查看
Manuel_Salas
3,665 次查看
Manuel_Salas
Hello @Tanu_1827
Could you please share the steps that you did to reproduce it in Linux and Windows PC host?
Best regards.
Salas.
