Uboot Adaptations for OPTEE
dhruvg2302
Hey All,
I want to understand the U-boot changes which needs to be done to make latest version of OPTEE works on imx6 boards.
Thanks!
Harvey021
Hi @dhruvg2302
In theory, the old uboot can be configured with the latest optee, not sure what version your uboot is. Our bsp should have optee it seems from version 4.14. You can tell us when you encounter specific problems.
If you do not consider the uboot version, you can refer to this chapter of the porting guide, Configuring OP-TEE, or the default yocto bsp already exists.
Harvey
