Ublox wifi firmware loading error on imx8qm
2,965 次查看
vinothkumars
Senior Contributor IV
Hi All,
I got the following error while trying to bringup new wifi chip for imx8qm custom platform,
[ 3.998471] mwifiex_sdio mmc2:0001:1: Direct firmware load for mrvl/sd8987_uapsta.bin failed with error -2
[ 4.073840] mwifiex_sdio mmc2:0001:1: Falling back to sysfs fallback for: mrvl/sd8987_uapsta.bin
Will you please tell me how to build and add this file sd8987_uapsta.bin .
Vinothkumar Sekar
标记 (3)
4 回复数
2,953 次查看
Hi Vinothkumar
for wifi firmware loading issues may be helpful to look at UM11447
Wi-Fi Subsystem Linux Porting Guide – User manual
2,950 次查看
vinothkumars
Hi @igorpadykov  thank you for the reply,
Not able to access the link,
Your userId does not have sufficient privilege to proceed with download.
Vinothkumar Sekar
2,946 次查看
suggest to obtain it through local marketing office.
Other useful documentation    NXP Wi-Fi Driver Features and Release Notes
2,937 次查看
vinothkumars
Thank you Igor,
If it possible please provide the following file, I unable to download it,
SD-WLAN-SD-BT-8987-U16-MMC-W16.68.10.p139-16.16.10.p139-C4X16687-MGPL.zip
Vinothkumar Sekar
