Uart hardware flow control with gps module
4,005 次查看
chenhoa
Hi Freescale,
We are using UART2 on imx6 with hardware flow control to communicate with gps module.
The hardware pin connection now is:
MX6Q_PAD_SD3_DAT4__UART2_RXD ----------- GPS TXD
MX6Q_PAD_SD3_DAT5__UART2_TXD ----------- GPS RXD
MX6Q_PAD_SD3_CLK__UART2_RTS  ----------- GPS CTS
MX6Q_PAD_SD3_CMD__UART2_CTS  ----------- GPS RTS
But as we read in imx6 ref manual and some web pages, should the connection be as below?
UART2_CTS ----------- GPS CTS
UART2_RTS ----------- GPS RTS
Is that right? If that is right, can we config the uart pins by software as below to handle this?
MX6Q_PAD_SD3_CLK__UART2_CTS  ----------- GPS CTS
MX6Q_PAD_SD3_CMD__UART2_RTS  ----------- GPS RTS
Thanks and best regard.
5 回复数
3,086 次查看
chenhoa
Hi all,
Somebody help me solve it, please?
3,086 次查看
alejandrolozan1
I believe the information found in this document How to enable BT on board imx6q_sabresd RevC. can be very helpful.
Alejandro
3,086 次查看
chenhoa
Hi Alejandro,
Thanks for your answer,
From your link, I can see that the hardware for uart should be. But is there any software solution to workaround my issue as my first post:
Can we config the uart pins by software as below to handle this?
Chen.
3,086 次查看
chenhoa
Hi Alejandro,
Can you help me to workaround it by software?
Thanks.
Chen.
3,086 次查看
alejandrolozan1
Hi Chen,
You may tray to change the mode DCE or DTE.
This can be changed in UARTx_UFCR register.
I have not tried this yet, please let me know how it goes.
Alejandro
