UUU tool Error : Fail Failure open usb device
已解决
跳至解决方案
6,854 次查看
sunile
I am currently using the IMX93 EVK. My objective is to flash the bootloader 'imx-boot.bin/flash.bin' to the eMMC. To accomplish this, I attempted to use the UUU tool.
Here are the steps I followed to flash the bootloaders:
  • Connected the USB cable to USB1 port for flashing.
  • Changed the mode pins using SW1301 to 1100.
  • Powered on the board, and observed the USB device displayed on the UUU command.
C:\UUU>uuu.exe -lsusb
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.5.21-0-g1f42172
Connected Known USB Devices
Path Chip Pro Vid Pid BcdVersion
4:134 MX93 SDPS: 0x1FC9 0x014E 0x0001​
  • Flashed the binary using the UUU tool: 'uuu.exe -v -b emmc ./imx-boot'. During flashing I get "Fail Failure open usb device".
C:\UUU>uuu.exe -v -b emmc ./imx-boot
Build in config:
        Pctl     Chip            Vid     Pid     BcdVersion
        SDPS:    MX8QXP          0x1fc9  0x012f  [0x0002..0xffff]
        SDPS:    MX8QM           0x1fc9  0x0129  [0x0002..0xffff]
        SDPS:    MX8DXL          0x1fc9  0x0147
        SDPS:    MX28            0x15a2  0x004f
        SDPS:    MX815           0x1fc9  0x013e
        SDPS:    MX865           0x1fc9  0x0146
        SDPS:    MX8ULP          0x1fc9  0x014a
        SDPS:    MX8ULP          0x1fc9  0x014b
        SDPS:    MX93            0x1fc9  0x014e
        SDP:     MX7D            0x15a2  0x0076
        SDP:     MX6Q            0x15a2  0x0054
        SDP:     MX6D            0x15a2  0x0061
        SDP:     MX6SL           0x15a2  0x0063
        SDP:     MX6SX           0x15a2  0x0071
        SDP:     MX6UL           0x15a2  0x007d
        SDP:     MX6ULL          0x15a2  0x0080
        SDP:     MX6SLL          0x1fc9  0x0128
        SDP:     MX7ULP          0x1fc9  0x0126
        SDP:     MXRT106X        0x1fc9  0x0135
        SDP:     MX8MM           0x1fc9  0x0134
        SDP:     MX8MQ           0x1fc9  0x012b
        SDPU:    SPL             0x0525  0xb4a4  [0x0000..0x04ff]
        SDPV:    SPL1            0x0525  0xb4a4  [0x0500..0x9998]
        SDPV:    SPL1            0x1fc9  0x0151  [0x0500..0x9998]
        SDPU:    SPL             0x0525  0xb4a4  [0x9999..0x9999]
        SDPU:    SPL             0x3016  0x1001  [0x0000..0x04ff]
        SDPV:    SPL1            0x3016  0x1001  [0x0500..0x9998]
        FBK:                     0x066f  0x9afe
        FBK:                     0x066f  0x9bff
        FBK:                     0x1fc9  0x0153
        FB:                      0x0525  0xa4a5
        FB:                      0x18d1  0x0d02
        FB:                      0x3016  0x0001
        FB:                      0x1fc9  0x0152
        FB:                      0x0483  0x0afb
Run built-in script:
uuu_version 1.2.39
# @_flash.bin            | bootloader
# @_image   [_flash.bin] | image burn to emmc, default is the same as bootloader
# This command will be run when i.MX6/7 i.MX8MM, i.MX8MQ
SDP: boot -f ./imx-boot
# This command will be run when ROM support stream mode
# i.MX8QXP, i.MX8QM
SDPS: boot -f ./imx-boot
# These commands will be run when use SPL and will be skipped if no spl
# SDPU will be deprecated. please use SDPV instead of SDPU
SDPU: delay 1000
SDPU: write -f ./imx-boot -offset 0x57c00
SDPU: jump
# if (SPL support SDPV)
SDPV: delay 1000
SDPV: write -f ./imx-boot -skipspl
SDPV: jump
FB: ucmd setenv fastboot_dev mmc
FB: ucmd setenv mmcdev ${emmc_dev}
FB: ucmd mmc dev ${emmc_dev}
FB: flash bootloader ./imx-boot
FB: ucmd if env exists emmc_ack; then ; else setenv emmc_ack 0; fi;
FB: ucmd mmc partconf ${emmc_dev} ${emmc_ack} 1 0
FB: Done
Wait for Known USB Device Appear...
New USB Device Attached at 4:134
4:134>Start Cmd:SDPS: boot -f ./imx-boot
100%4:134>Okay (2.631s)
New USB Device Attached at 6:134
6:134>Fail Failure open usb device(4.984s)​
I'm not sure why this error as occurred, Please let me know if I'm missing anything during flashing.
Thanks in advance
1 解答
6,784 次查看
sunile
I have installed UUU tool on Ubuntu machine and I'm able to flash the bootloaders image using UUU
Best Regards
在原帖中查看解决方案
3 回复数
6,785 次查看
sunile
Best Regards
6,825 次查看
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
You could move to latest BSP, UUU and silicon.
Could you send a SOM picture?
I tried with A1 silicon, with PD connected, USB1 J401 connected to PC and power SW OFF. Then turn power SW ON.
> uuu -lsusb
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.5.165-0-g7347a80
        2:4      MX93    SDPS:   0x1FC9 0x014E   0x0001
LF_v6.6.3-1.0.0_images_IMX93EVK> uuu -v -b emmc .\imx-boot-imx93-11x11-lpddr4x-evk-sd.bin-flash_singleboot
Build in config:
        SDPS:    MX95            0x1fc9  0x015d
        FBK:                     0x066f  0x9afe
        FBK:                     0x066f  0x9bff
        FBK:                     0x1fc9  0x0153
        FB:                      0x0525  0xa4a5
        FB:                      0x18d1  0x0d02
        FB:                      0x3016  0x0001
        FB:                      0x1fc9  0x0152
        FB:                      0x0483  0x0afb
uuu_version 1.2.39
SDP: boot -f .\imx-boot-imx93-11x11-lpddr4x-evk-sd.bin-flash_singleboot
# i.MX8QXP, i.MX8QM
SDPS: boot -f .\imx-boot-imx93-11x11-lpddr4x-evk-sd.bin-flash_singleboot
SDPU: delay 1000
SDPU: write -f .\imx-boot-imx93-11x11-lpddr4x-evk-sd.bin-flash_singleboot -offset 0x57c00
SDPU: jump
SDPV: delay 1000
SDPV: write -f .\imx-boot-imx93-11x11-lpddr4x-evk-sd.bin-flash_singleboot -skipspl
SDPV: jump
FB: flash bootloader .\imx-boot-imx93-11x11-lpddr4x-evk-sd.bin-flash_singleboot
FB: Done
New USB Device Attached at 2:4
2:4>Start Cmd:SDPS: boot -f .\imx-boot-imx93-11x11-lpddr4x-evk-sd.bin-flash_singleboot
100%2:4>Okay (3.144s)
2:4>Start Cmd:FB: ucmd setenv fastboot_dev mmc
2:4>Okay (0.12s)
2:4>Start Cmd:FB: ucmd setenv mmcdev ${emmc_dev}
2:4>Okay (0.088s)
2:4>Start Cmd:FB: ucmd mmc dev ${emmc_dev}
2:4>Okay (0.043s)
2:4>Start Cmd:FB: flash bootloader .\imx-boot-imx93-11x11-lpddr4x-evk-sd.bin-flash_singleboot
0x200000002:4>Okay (0.174s)
2:4>Start Cmd:FB: ucmd if env exists emmc_ack; then ; else setenv emmc_ack 0; fi;
2:4>Okay (0.004s)
2:4>Start Cmd:FB: ucmd mmc partconf ${emmc_dev} ${emmc_ack} 1 0
2:4>Okay (0.004s)
2:4>Start Cmd:FB: Done
2:4>Okay (0s)
Check that my UUU version is 1.5.165 and my filesystem LF_v6.6.3-1.0.0_images_IMX93EVK prebuilt, do you succeed in these conditions?
6,793 次查看
sunile
Thank you for your message. I tried to upgrade the UUU tool to version 1.5.165 and used prebuilt images from LF_v6.6.3-1.0.0. Still I see the same error.
I noticed that during your flashing process, you are not using switch SW1301. If I neglect to set SW1301 to 1100, I am unable to detect the device.
I have also attached the SOM picture, PFA.
%3CLINGO-SUB%20id%3D%22lingo-sub-1849042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUUU%20%E5%B7%A5%E5%85%B7%E9%94%99%E8%AF%AF%EF%BC%9A%E5%A4%B1%E8%B4%A5%EF%BC%8C%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%20USB%20%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1849042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20IMX93%20EVK%E3%80%82%E6%88%91%E7%9A%84%E7%9B%AE%E6%A0%87%E6%98%AF%E5%B0%86%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E2%80%9Cimx-boot.bin%2Fflash.bin%E2%80%9D%E5%88%B7%E5%85%A5%20eMMC%E3%80%82%E4%B8%BA%E4%BA%86%E5%AE%9E%E7%8E%B0%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20UUU%20%E5%B7%A5%E5%85%B7%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E5%88%B7%E6%96%B0%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E6%89%80%E9%81%B5%E5%BE%AA%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%B0%86%20USB%20%E7%BA%BF%E8%BF%9E%E6%8E%A5%E5%88%B0%20USB1%20%E7%AB%AF%E5%8F%A3%E8%BF%9B%E8%A1%8C%E5%88%B7%E6%9C%BA%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%B0%86%E4%BD%BF%E7%94%A8%20SW1301%20%E7%9A%84%E6%A8%A1%E5%BC%8F%E5%BC%95%E8%84%9A%E6%9B%B4%E6%94%B9%E4%B8%BA%201100%E3%80%82%3C%2FLI%3E%3CLI%3E%E7%BB%99%E5%BC%80%E5%8F%91%E6%9D%BF%E4%BE%9B%E7%94%B5%EF%BC%8C%E8%A7%82%E5%AF%9FUUU%E5%91%BD%E4%BB%A4%E4%B8%8A%E6%98%BE%E7%A4%BA%E7%9A%84USB%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EC%3A%5CUUU%26gt%3Buuu.exe%20-lsusb%0Auuu%20(Universal%20Update%20Utility)%20for%20nxp%20imx%20chips%20--%20libuuu_1.5.21-0-g1f42172%0A%0AConnected%20Known%20USB%20Devices%0APath%20Chip%20Pro%20Vid%20Pid%20BcdVersion%0A%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0A4%3A134%20MX93%20SDPS%3A%200x1FC9%200x014E%200x0001%E2%80%8B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CUL%3E%3CLI%3E%E4%BD%BF%E7%94%A8%20UUU%20%E5%B7%A5%E5%85%B7%E5%88%B7%E6%96%B0%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%9A%E2%80%9Cuuu.exe%20-v%20-b%20emmc%20.%2Fimx-boot%E2%80%9D%E3%80%82%E5%9C%A8%E9%97%AA%E7%83%81%E6%9C%9F%E9%97%B4%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%E2%80%9C%E6%89%93%E5%BC%80%20USB%20%E8%AE%BE%E5%A4%87%E5%A4%B1%E8%B4%A5%E2%80%9D%E7%9A%84%E6%B6%88%E6%81%AF%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EC%3A%5CUUU%26gt%3Buuu.exe%20-v%20-b%20emmc%20.%2Fimx-boot%0Auuu%20(Universal%20Update%20Utility)%20for%20nxp%20imx%20chips%20--%20libuuu_1.5.21-0-g1f42172%0A%0ABuild%20in%20config%3A%0A%20%20%20%20%20%20%20%20Pctl%20%20%20%20%20Chip%20%20%20%20%20%20%20%20%20%20%20%20Vid%20%20%20%20%20Pid%20%20%20%20%20BcdVersion%0A%20%20%20%20%20%20%20%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX8QXP%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x012f%20%20%5B0x0002..0xffff%5D%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX8QM%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0129%20%20%5B0x0002..0xffff%5D%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX8DXL%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0147%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX28%20%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x004f%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX815%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x013e%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX865%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0146%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX8ULP%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x014a%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX8ULP%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x014b%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX93%20%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x014e%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX7D%20%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x0076%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6Q%20%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x0054%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6D%20%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x0061%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6SL%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x0063%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6SX%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x0071%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6UL%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x007d%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6ULL%20%20%20%20%20%20%20%20%20%200x15a2%20%200x0080%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6SLL%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0128%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX7ULP%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0126%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MXRT106X%20%20%20%20%20%20%20%200x1fc9%20%200x0135%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX8MM%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0134%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX8MQ%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x012b%0A%20%20%20%20%20%20%20%20SDPU%3A%20%20%20%20SPL%20%20%20%20%20%20%20%20%20%20%20%20%200x0525%20%200xb4a4%20%20%5B0x0000..0x04ff%5D%0A%20%20%20%20%20%20%20%20SDPV%3A%20%20%20%20SPL1%20%20%20%20%20%20%20%20%20%20%20%200x0525%20%200xb4a4%20%20%5B0x0500..0x9998%5D%0A%20%20%20%20%20%20%20%20SDPV%3A%20%20%20%20SPL1%20%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0151%20%20%5B0x0500..0x9998%5D%0A%20%20%20%20%20%20%20%20SDPU%3A%20%20%20%20SPL%20%20%20%20%20%20%20%20%20%20%20%20%200x0525%20%200xb4a4%20%20%5B0x9999..0x9999%5D%0A%20%20%20%20%20%20%20%20SDPU%3A%20%20%20%20SPL%20%20%20%20%20%20%20%20%20%20%20%20%200x3016%20%200x1001%20%20%5B0x0000..0x04ff%5D%0A%20%20%20%20%20%20%20%20SDPV%3A%20%20%20%20SPL1%20%20%20%20%20%20%20%20%20%20%20%200x3016%20%200x1001%20%20%5B0x0500..0x9998%5D%0A%20%20%20%20%20%20%20%20FBK%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x066f%20%200x9afe%0A%20%20%20%20%20%20%20%20FBK%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x066f%20%200x9bff%0A%20%20%20%20%20%20%20%20FBK%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0153%0A%20%20%20%20%20%20%20%20FB%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x0525%20%200xa4a5%0A%20%20%20%20%20%20%20%20FB%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x18d1%20%200x0d02%0A%20%20%20%20%20%20%20%20FB%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x3016%20%200x0001%0A%20%20%20%20%20%20%20%20FB%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0152%0A%20%20%20%20%20%20%20%20FB%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x0483%20%200x0afb%0A%0ARun%20built-in%20script%3A%0A%0Auuu_version%201.2.39%0A%0A%23%20%40_flash.bin%20%20%20%20%20%20%20%20%20%20%20%20%7C%20bootloader%0A%23%20%40_image%20%20%20%5B_flash.bin%5D%20%7C%20image%20burn%20to%20emmc%2C%20default%20is%20the%20same%20as%20bootloader%0A%0A%23%20This%20command%20will%20be%20run%20when%20i.MX6%2F7%20i.MX8MM%2C%20i.MX8MQ%0ASDP%3A%20boot%20-f%20.%2Fimx-boot%0A%0A%23%20This%20command%20will%20be%20run%20when%20ROM%20support%20stream%20mode%0A%23%20i.MX8QXP%2C%20i.MX8QM%0ASDPS%3A%20boot%20-f%20.%2Fimx-boot%0A%0A%23%20These%20commands%20will%20be%20run%20when%20use%20SPL%20and%20will%20be%20skipped%20if%20no%20spl%0A%23%20SDPU%20will%20be%20deprecated.%20please%20use%20SDPV%20instead%20of%20SDPU%0A%23%20%7B%0ASDPU%3A%20delay%201000%0ASDPU%3A%20write%20-f%20.%2Fimx-boot%20-offset%200x57c00%0ASDPU%3A%20jump%0A%23%20%7D%0A%0A%23%20These%20commands%20will%20be%20run%20when%20use%20SPL%20and%20will%20be%20skipped%20if%20no%20spl%0A%23%20if%20(SPL%20support%20SDPV)%0A%23%20%7B%0ASDPV%3A%20delay%201000%0ASDPV%3A%20write%20-f%20.%2Fimx-boot%20-skipspl%0ASDPV%3A%20jump%0A%23%20%7D%0A%0AFB%3A%20ucmd%20setenv%20fastboot_dev%20mmc%0AFB%3A%20ucmd%20setenv%20mmcdev%20%24%7Bemmc_dev%7D%0AFB%3A%20ucmd%20mmc%20dev%20%24%7Bemmc_dev%7D%0AFB%3A%20flash%20bootloader%20.%2Fimx-boot%0AFB%3A%20ucmd%20if%20env%20exists%20emmc_ack%3B%20then%20%3B%20else%20setenv%20emmc_ack%200%3B%20fi%3B%0AFB%3A%20ucmd%20mmc%20partconf%20%24%7Bemmc_dev%7D%20%24%7Bemmc_ack%7D%201%200%0AFB%3A%20Done%0A%0A%0AWait%20for%20Known%20USB%20Device%20Appear...%0ANew%20USB%20Device%20Attached%20at%204%3A134%0A4%3A134%26gt%3BStart%20Cmd%3ASDPS%3A%20boot%20-f%20.%2Fimx-boot%0A100%254%3A134%26gt%3BOkay%20(2.631s)%0ANew%20USB%20Device%20Attached%20at%206%3A134%0A6%3A134%26gt%3BFail%20Failure%20open%20usb%20device(4.984s)%E2%80%8B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E5%8F%91%E7%94%9F%E6%AD%A4%E9%94%99%E8%AF%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E5%9C%A8%E9%97%AA%E7%83%81%E8%BF%87%E7%A8%8B%E4%B8%AD%E9%81%97%E6%BC%8F%E4%BA%86%E4%BB%BB%E4%BD%95%E4%B8%9C%E8%A5%BF%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E8%87%B4%E8%B0%A2%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1850559%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AUUU%20%E5%B7%A5%E5%85%B7%E9%94%99%E8%AF%AF%EF%BC%9A%E5%A4%B1%E8%B4%A5%EF%BC%8C%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%20USB%20%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1850559%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%9C%A8%20Ubuntu%20%E6%9C%BA%E5%99%A8%E4%B8%8A%E5%AE%89%E8%A3%85%E4%BA%86%20UUU%20%E5%B7%A5%E5%85%B7%EF%BC%8C%E5%B9%B6%E4%B8%94%E8%83%BD%E5%A4%9F%E4%BD%BF%E7%94%A8%20UUU%20%E5%88%B7%E6%96%B0%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E6%98%A0%E5%83%8F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1849694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AUUU%20%E5%B7%A5%E5%85%B7%E9%94%99%E8%AF%AF%EF%BC%9A%E5%A4%B1%E8%B4%A5%EF%BC%8C%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%20USB%20%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1849694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%95%99%E8%A8%80%E3%80%82%E6%88%91%E5%B0%9D%E8%AF%95%E5%B0%86%20UUU%20%E5%B7%A5%E5%85%B7%E5%8D%87%E7%BA%A7%E5%88%B0%E7%89%88%E6%9C%AC%201.5.165%20%E5%B9%B6%E4%BD%BF%E7%94%A8%20LF_v6.6.3-1.0.0%20%E7%9A%84%E9%A2%84%E6%9E%84%E5%BB%BA%E5%9B%BE%E5%83%8F%E3%80%82%E6%88%91%E4%BB%8D%E7%84%B6%E7%9C%8B%E5%88%B0%E5%90%8C%E6%A0%B7%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%EF%BC%8C%E5%9C%A8%E6%82%A8%E7%9A%84%E9%97%AA%E7%83%81%E8%BF%87%E7%A8%8B%E4%B8%AD%EF%BC%8C%E6%82%A8%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%E5%BC%80%E5%85%B3%20SW1301%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E5%BF%98%E8%AE%B0%E5%B0%86%20SW1301%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%201100%EF%BC%8C%E6%88%91%E5%B0%86%E6%97%A0%E6%B3%95%E6%A3%80%E6%B5%8B%E5%88%B0%E8%AF%A5%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EC%3A%5CUUU%26gt%3Buuu.exe%20-lsusb%0Auuu%20(Universal%20Update%20Utility)%20for%20nxp%20imx%20chips%20--%20libuuu_1.5.165-0-g7347a80%0A%0AConnected%20Known%20USB%20Devices%0A%20%20%20%20%20%20%20%20Path%20%20%20%20%20Chip%20%20%20%20Pro%20%20%20%20%20Vid%20%20%20%20%20Pid%20%20%20%20%20BcdVersion%0A%20%20%20%20%20%20%20%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0A%0A%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E6%88%91%E8%BF%98%E9%99%84%E4%B8%8A%E4%BA%86%20SOM%20%E5%9B%BE%E7%89%87%E3%80%81PFA%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1849360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AUUU%20%E5%B7%A5%E5%85%B7%E9%94%99%E8%AF%AF%EF%BC%9A%E5%A4%B1%E8%B4%A5%EF%BC%8C%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%20USB%20%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1849360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%AF%B9%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%E4%BA%A7%E5%93%81%E7%9A%84%E5%85%B3%E6%B3%A8%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%BD%AC%E5%90%91%E6%9C%80%E6%96%B0%E7%9A%84%20BSP%E3%80%81UUU%20%E5%92%8C%E7%A1%85%E7%89%87%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E8%83%BD%E5%8F%91%E4%B8%80%E5%BC%A0%20SOM%20%E5%9B%BE%E7%89%87%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20A1%20%E7%A1%85%EF%BC%8C%E8%BF%9E%E6%8E%A5%20PD%EF%BC%8C%E5%B0%86%20USB1%20J401%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20PC%EF%BC%8C%E5%B9%B6%E5%B0%86%E7%94%B5%E6%BA%90%20SW%20%E5%85%B3%E9%97%AD%E3%80%82%E7%84%B6%E5%90%8E%E6%89%93%E5%BC%80%E7%94%B5%E6%BA%90%E5%BC%80%E5%85%B3%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%26gt%3B%20uuu%20-lsusb%0Auuu%20(Universal%20Update%20Utility)%20for%20nxp%20imx%20chips%20--%20libuuu_1.5.165-0-g7347a80%0A%0AConnected%20Known%20USB%20Devices%0A%20%20%20%20%20%20%20%20Path%20%20%20%20%20Chip%20%20%20%20Pro%20%20%20%20%20Vid%20%20%20%20%20Pid%20%20%20%20%20BcdVersion%0A%20%20%20%20%20%20%20%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0A%20%20%20%20%20%20%20%202%3A4%20%20%20%20%20%20MX93%20%20%20%20SDPS%3A%20%20%200x1FC9%200x014E%20%20%200x0001%0A%0A%0ALF_v6.6.3-1.0.0_images_IMX93EVK%26gt%3B%20uuu%20-v%20-b%20emmc%20.%5Cimx-boot-imx93-11x11-lpddr4x-evk-sd.bin-flash_singleboot%0Auuu%20(Universal%20Update%20Utility)%20for%20nxp%20imx%20chips%20--%20libuuu_1.5.165-0-g7347a80%0A%0ABuild%20in%20config%3A%0A%20%20%20%20%20%20%20%20Pctl%20%20%20%20%20Chip%20%20%20%20%20%20%20%20%20%20%20%20Vid%20%20%20%20%20Pid%20%20%20%20%20BcdVersion%0A%20%20%20%20%20%20%20%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX8QXP%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x012f%20%20%5B0x0002..0xffff%5D%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX8QM%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0129%20%20%5B0x0002..0xffff%5D%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX8DXL%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0147%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX28%20%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x004f%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX815%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x013e%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX865%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0146%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX8ULP%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x014a%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX8ULP%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x014b%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX93%20%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x014e%0A%20%20%20%20%20%20%20%20SDPS%3A%20%20%20%20MX95%20%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x015d%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX7D%20%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x0076%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6Q%20%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x0054%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6D%20%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x0061%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6SL%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x0063%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6SX%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x0071%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6UL%20%20%20%20%20%20%20%20%20%20%200x15a2%20%200x007d%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6ULL%20%20%20%20%20%20%20%20%20%200x15a2%20%200x0080%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX6SLL%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0128%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX7ULP%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0126%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MXRT106X%20%20%20%20%20%20%20%200x1fc9%20%200x0135%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX8MM%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0134%0A%20%20%20%20%20%20%20%20SDP%3A%20%20%20%20%20MX8MQ%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x012b%0A%20%20%20%20%20%20%20%20SDPU%3A%20%20%20%20SPL%20%20%20%20%20%20%20%20%20%20%20%20%200x0525%20%200xb4a4%20%20%5B0x0000..0x04ff%5D%0A%20%20%20%20%20%20%20%20SDPV%3A%20%20%20%20SPL1%20%20%20%20%20%20%20%20%20%20%20%200x0525%20%200xb4a4%20%20%5B0x0500..0x9998%5D%0A%20%20%20%20%20%20%20%20SDPV%3A%20%20%20%20SPL1%20%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0151%20%20%5B0x0500..0x9998%5D%0A%20%20%20%20%20%20%20%20SDPU%3A%20%20%20%20SPL%20%20%20%20%20%20%20%20%20%20%20%20%200x0525%20%200xb4a4%20%20%5B0x9999..0x9999%5D%0A%20%20%20%20%20%20%20%20SDPU%3A%20%20%20%20SPL%20%20%20%20%20%20%20%20%20%20%20%20%200x3016%20%200x1001%20%20%5B0x0000..0x04ff%5D%0A%20%20%20%20%20%20%20%20SDPV%3A%20%20%20%20SPL1%20%20%20%20%20%20%20%20%20%20%20%200x3016%20%200x1001%20%20%5B0x0500..0x9998%5D%0A%20%20%20%20%20%20%20%20FBK%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x066f%20%200x9afe%0A%20%20%20%20%20%20%20%20FBK%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x066f%20%200x9bff%0A%20%20%20%20%20%20%20%20FBK%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0153%0A%20%20%20%20%20%20%20%20FB%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x0525%20%200xa4a5%0A%20%20%20%20%20%20%20%20FB%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x18d1%20%200x0d02%0A%20%20%20%20%20%20%20%20FB%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x3016%20%200x0001%0A%20%20%20%20%20%20%20%20FB%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x1fc9%20%200x0152%0A%20%20%20%20%20%20%20%20FB%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x0483%20%200x0afb%0A%0ARun%20built-in%20script%3A%0A%0Auuu_version%201.2.39%0A%0A%23%20%40_flash.bin%20%20%20%20%20%20%20%20%20%20%20%20%7C%20bootloader%0A%23%20%40_image%20%20%20%5B_flash.bin%5D%20%7C%20image%20burn%20to%20emmc%2C%20default%20is%20the%20same%20as%20bootloader%0A%0A%23%20This%20command%20will%20be%20run%20when%20i.MX6%2F7%20i.MX8MM%2C%20i.MX8MQ%0ASDP%3A%20boot%20-f%20.%5Cimx-boot-imx93-11x11-lpddr4x-evk-sd.bin-flash_singleboot%0A%0A%23%20This%20command%20will%20be%20run%20when%20ROM%20support%20stream%20mode%0A%23%20i.MX8QXP%2C%20i.MX8QM%0ASDPS%3A%20boot%20-f%20.%5Cimx-boot-imx93-11x11-lpddr4x-evk-sd.bin-flash_singleboot%0A%0A%23%20These%20commands%20will%20be%20run%20when%20use%20SPL%20and%20will%20be%20skipped%20if%20no%20spl%0A%23%20SDPU%20will%20be%20deprecated.%20please%20use%20SDPV%20instead%20of%20SDPU%0A%23%20%7B%0ASDPU%3A%20delay%201000%0ASDPU%3A%20write%20-f%20.%5Cimx-boot-imx93-11x11-lpddr4x-evk-sd.bin-flash_singleboot%20-offset%200x57c00%0ASDPU%3A%20jump%0A%23%20%7D%0A%0A%23%20These%20commands%20will%20be%20run%20when%20use%20SPL%20and%20will%20be%20skipped%20if%20no%20spl%0A%23%20if%20(SPL%20support%20SDPV)%0A%23%20%7B%0ASDPV%3A%20delay%201000%0ASDPV%3A%20write%20-f%20.%5Cimx-boot-imx93-11x11-lpddr4x-evk-sd.bin-flash_singleboot%20-skipspl%0ASDPV%3A%20jump%0A%23%20%7D%0A%0AFB%3A%20ucmd%20setenv%20fastboot_dev%20mmc%0AFB%3A%20ucmd%20setenv%20mmcdev%20%24%7Bemmc_dev%7D%0AFB%3A%20ucmd%20mmc%20dev%20%24%7Bemmc_dev%7D%0AFB%3A%20flash%20bootloader%20.%5Cimx-boot-imx93-11x11-lpddr4x-evk-sd.bin-flash_singleboot%0AFB%3A%20ucmd%20if%20env%20exists%20emmc_ack%3B%20then%20%3B%20else%20setenv%20emmc_ack%200%3B%20fi%3B%0AFB%3A%20ucmd%20mmc%20partconf%20%24%7Bemmc_dev%7D%20%24%7Bemmc_ack%7D%201%200%0AFB%3A%20Done%0A%0A%0AWait%20for%20Known%20USB%20Device%20Appear...%0ANew%20USB%20Device%20Attached%20at%202%3A4%0A2%3A4%26gt%3BStart%20Cmd%3ASDPS%3A%20boot%20-f%20.%5Cimx-boot-imx93-11x11-lpddr4x-evk-sd.bin-flash_singleboot%0A100%252%3A4%26gt%3BOkay%20(3.144s)%0ANew%20USB%20Device%20Attached%20at%202%3A4%0A2%3A4%26gt%3BStart%20Cmd%3AFB%3A%20ucmd%20setenv%20fastboot_dev%20mmc%0A2%3A4%26gt%3BOkay%20(0.12s)%0A2%3A4%26gt%3BStart%20Cmd%3AFB%3A%20ucmd%20setenv%20mmcdev%20%24%7Bemmc_dev%7D%0A2%3A4%26gt%3BOkay%20(0.088s)%0A2%3A4%26gt%3BStart%20Cmd%3AFB%3A%20ucmd%20mmc%20dev%20%24%7Bemmc_dev%7D%0A2%3A4%26gt%3BOkay%20(0.043s)%0A2%3A4%26gt%3BStart%20Cmd%3AFB%3A%20flash%20bootloader%20.%5Cimx-boot-imx93-11x11-lpddr4x-evk-sd.bin-flash_singleboot%0A0x200000002%3A4%26gt%3BOkay%20(0.174s)%0A2%3A4%26gt%3BStart%20Cmd%3AFB%3A%20ucmd%20if%20env%20exists%20emmc_ack%3B%20then%20%3B%20else%20setenv%20emmc_ack%200%3B%20fi%3B%0A2%3A4%26gt%3BOkay%20(0.004s)%0A2%3A4%26gt%3BStart%20Cmd%3AFB%3A%20ucmd%20mmc%20partconf%20%24%7Bemmc_dev%7D%20%24%7Bemmc_ack%7D%201%200%0A2%3A4%26gt%3BOkay%20(0.004s)%0A2%3A4%26gt%3BStart%20Cmd%3AFB%3A%20Done%0A2%3A4%26gt%3BOkay%20(0s)%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E6%A3%80%E6%9F%A5%E6%88%91%E7%9A%84%20UUU%20%E7%89%88%E6%9C%AC%E6%98%AF%E5%90%A6%E4%B8%BA%201.5.165%20%E5%B9%B6%E4%B8%94%E6%88%91%E7%9A%84%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20LF_v6.6.3-1.0.0_images_IMX93EVK%20%E6%98%AF%E5%90%A6%E9%A2%84%E5%85%88%E6%9E%84%E5%BB%BA%EF%BC%8C%E5%9C%A8%E8%BF%99%E4%BA%9B%E6%9D%A1%E4%BB%B6%E4%B8%8B%E6%82%A8%E6%98%AF%E5%90%A6%E6%88%90%E5%8A%9F%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E
