USB init failed: -22
434件の閲覧回数
ap3415
Hi ,
I have been trying to flash my wic.b2z image to an emmc using uuc tool through a usb port.While flashing an USB init failed: -22 error occured.I am using an imx8mp porcessor.
Run bootcmd_mfg: run mfgtool_args;if iminfo ${initrd_addr}; then if test ${tee} = yes; then bootm ${tee_addr} ${initrd_addr} ${fdt_addr}; else booti ${loadaddr} ${initrd_addr} ${fdt_addr}; fi; else echo "Run fastboot ..."; fastboot 0; fi;
Hit any key to stop autoboot: 0
## Checking Image at 43800000 ...
Unknown image format!
Run fastboot ...
u-boot=>
3 返答(返信)
332件の閲覧回数
Oswalag
Please try again flashing the last pre-build image (Linux 6.18.20_2.0.0) and the last version of the uuu tool.
Regards.
391件の閲覧回数
Oswalag
Please share the complete process and the boot config of your board to analyze what can cause the issue.
386件の閲覧回数
ap3415
U-Boot SPL 2024.04-lf_v2024.04+g6c4545203d1+p0 (Nov 15 2024 - 04:02:13 +0000)
DDRINFO: start DRAM init
DDRINFO: DRAM rate 4000MTS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
SEC0:  RNG instantiated
Normal Boot
Trying to boot from BOOTROM
Boot Stage: USB boot
Find img info 0x48022fa0, size 1064
Need continue download 1024
NOTICE:  Do not release JR0 to NS as it can be used by HAB
NOTICE:  BL31: v2.10.0  (release):automotive-15.0.0_1.1.0
NOTICE:  BL31: Built : 08:52:12, Nov  4 2024
U-Boot 2024.04-lf_v2024.04+g6c4545203d1+p0 (Nov 15 2024 - 04:02:13 +0000)
CPU:   i.MX8MP Lite[4] rev1.1 1600 MHz (running at 1200 MHz)
CPU:   Industrial temperature grade (-40C to 105C) at 35C
Reset cause: POR
Model: NXP i.MX8MPlus LPDDR4 EVK board
DRAM:  6 GiB
tcpc_init: Can't find device id=0x50
setup_typec: tcpc port2 init failed, err=-19
setup_typec: tcpc port1 init failed, err=-19
Core:  284 devices, 36 uclasses, devicetree: separate
MMC:   FSL_SDHC: 1, FSL_SDHC: 2
Loading Environment from nowhere... OK
[*]-Video Link 0adv7535_mipi2hdmi adv7535@3d: Can't find cec device id=0x3c
fail to probe panel device adv7535@3d
fail to get display timings
probe video device failed, ret -19
        [0] lcd-controller@32e80000, video
        [1] mipi_dsi@32e60000, video_bridge
        [2] adv7535@3d, panel
In:    serial
Out:   serial
Err:   serial
MMC: no card present
Detect USB boot. Will enter fastboot mode!
Net:   Could not get PHY for FEC0: addr 1
eth1: ethernet@30bf0000 [PRIME]
Fastboot: Normal
Boot from USB for mfgtools
*** Warning - Use default environment for                                mfgtools
, using default environment
Run fastboot ...
u-boot=>
%3CLINGO-SUB%20id%3D%22lingo-sub-2412396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUSB%E5%88%9D%E6%9C%9F%E5%8C%96%E5%A4%B1%E6%95%97%3A%20-22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2412396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3EUSB%E3%83%9D%E3%83%BC%E3%83%88%E7%B5%8C%E7%94%B1%E3%81%A7uuc%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6wic.b2z%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92eMMC%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%82%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E4%B8%AD%E3%81%ABUSB%E5%88%9D%E6%9C%9F%E5%8C%96%E5%A4%B1%E6%95%97%EF%BC%9A-22%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82imx8mp%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ebootcmd_mfg%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3A%20mfgtool_args%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82iminfo%20%E3%81%8C%24%7Binitrd_addr%7D%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81test%20%E3%81%8C%24%7Btee%7D%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81bootm%20%E3%81%8C%24%7Btee_addr%7D%20%24%7Binitrd_addr%7D%20%24%7Bfdt_addr%7D%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81booti%20%E3%81%8C%24%7Bloadaddr%7D%20%24%7Binitrd_addr%7D%20%24%7Bfdt_addr%7D%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81fi%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81echo%20%22fastboot%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99...%22%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82fastboot%200%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82fi%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%200%3C%2FP%3E%3CP%3E%23%23%2043800000%20%E7%95%AA%E5%9C%B0%E3%81%AE%E7%94%BB%E5%83%8F%E3%82%92%E7%A2%BA%E8%AA%8D%E4%B8%AD...%3CBR%20%2F%3E%E4%B8%8D%E6%98%8E%E3%81%AA%E7%94%BB%E5%83%8F%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%EF%BC%81%3CBR%20%2F%3Efastboot%E3%82%92%E5%AE%9F%E8%A1%8C...%3CBR%20%2F%3E%20USB%E5%88%9D%E6%9C%9F%E5%8C%96%E5%A4%B1%E6%95%97%3A%20-22%3CBR%20%2F%3E%20u-boot%3D%26gt%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2412396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%20%7C%20i.MX%208QuadMax%E2%80%AF(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2412779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20USB%20init%20failed%3A%20-22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2412779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3C%2FP%3E%0A%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%82%92%E5%88%86%E6%9E%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E8%B5%B7%E5%8B%95%E8%A8%AD%E5%AE%9A%E3%81%A8%E5%85%A8%E9%81%8E%E7%A8%8B%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2412906%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20USB%20init%20failed%3A%20-22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2412906%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3EU-Boot%20SPL%202024.04-lf_v2024.04%2Bg6c4545203d1%2Bp0(2024%E5%B9%B411%E6%9C%8815%E6%97%A5%20-%2004%3A02%3A13%20%2B0000)%3CBR%20%2F%3EDDRINFO%3A%20DRAM%20init%E3%82%92%E8%B5%B7%E5%8B%95%3CBR%20%2F%3EDDRINFO%3ADRAM%E3%83%AC%E3%83%BC%E3%83%884000MTS%3CBR%20%2F%3EDDRINFO%3Addrphy%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%AE%8C%E4%BA%86%3CBR%20%2F%3EDDRINFO%3A%20ddrmix%E8%A8%AD%E5%AE%9A%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%E7%AC%AC0%E7%AF%80%3ARNG%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E5%8C%96%3CBR%20%2F%3E%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%E3%83%96%E3%83%BC%E3%83%88%3CBR%20%2F%3EBOOTROM%E3%81%8B%E3%82%89%E3%81%AE%E8%B5%B7%E5%8B%95%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E8%B5%B7%E5%8B%95%E6%AE%B5%E9%9A%8E%3AUSB%E8%B5%B7%E5%8B%95%3CBR%20%2F%3Eimg%20info%200x48022fa0%E3%80%81%E3%82%B5%E3%82%A4%E3%82%BA1064%E3%82%92%E6%8E%A2%E3%81%9B%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%82%92%E7%B6%9A%E3%81%91%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%201024%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%3AJR0%E3%81%AFHAB%E3%81%A7%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%81%AE%E3%81%A7NS%E3%81%AB%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CBR%20%2F%3E%E9%80%9A%E7%9F%A5%3ABL31%3A%20v2.10.0(%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9)%3A%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%96-15.0.0_1.1.0%3CBR%20%2F%3E%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%EF%BC%9ABL31%EF%BC%9A%E8%A3%BD%E9%80%A0%E6%97%A5%E6%99%82%EF%BC%9A2024%E5%B9%B411%E6%9C%884%E6%97%A5%2008%3A52%3A12%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20U-Boot%202024.04-lf_v2024.04%2Bg6c4545203d1%2Bp0(2024%E5%B9%B411%E6%9C%8815%E6%97%A5%20-%2004%3A02%3A13%20%2B0000)%3CBR%20%2F%3E%3CBR%20%2F%3ECPU%3Ai.MX8MP%20Lite%5B4%5D%20rev1.1%201600%20MHz(1200%20MHz%E3%81%A7%E5%8B%95%E4%BD%9C)%3CBR%20%2F%3ECPU%3A%E3%82%A4%E3%83%B3%E3%83%80%E3%82%B9%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E6%B8%A9%E5%BA%A6%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89(-40%C2%B0C%E3%81%8B%E3%82%89105%C2%B0C)%E3%81%A735%C2%B0C%E3%81%AB%E5%AF%BE%E5%BF%9C%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%8E%9F%E5%9B%A0%3APOR(POR)%3CBR%20%2F%3E%E3%83%A2%E3%83%87%E3%83%AB%3ANXP%20i.MX8MPlus%20LPDDR4%20EVK%E3%83%9C%E3%83%BC%E3%83%89%3CBR%20%2F%3EDRAM%3A6%20GiB%3CBR%20%2F%3Etcpc_init%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9ID%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%3D0x50%3CBR%20%2F%3Esetup_typec%3A%20tcpc%20port2%20init%20%E5%A4%B1%E6%95%97%E3%80%81err%3D-19%3CBR%20%2F%3Etcpc_init%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9ID%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%3D0x50%3CBR%20%2F%3Esetup_typec%3A%20tcpc%20port1%20init%20%E5%A4%B1%E6%95%97%E3%80%81err%3D-19%3CBR%20%2F%3E%E3%82%B3%E3%82%A2%3A284%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%8136%20u%E3%82%AF%E3%83%A9%E3%82%B9%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%3A%E5%88%A5%E3%80%85%3CBR%20%2F%3EMMC%3A%20FSL_SDHC%3A%201%2C%20FSL_SDHC%3A%202%3CBR%20%2F%3E%E3%81%A9%E3%81%93%E3%81%8B%E3%82%89%E3%81%A8%E3%82%82%E3%81%AA%E3%81%8F%E7%92%B0%E5%A2%83%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80...%E4%BA%86%E8%A7%A3%3CBR%20%2F%3E%5B*%5D-%E3%83%93%E3%83%87%E3%82%AA%E3%83%AA%E3%83%B3%E3%82%AF0adv7535_mipi2hdmi%20adv7535%403d%3Acec%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9ID%3D0x3c%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E5%A4%B1%E6%95%97%20%E3%83%91%E3%83%8D%E3%83%AB%E8%A3%85%E7%BD%AEadv7535%403d%3CBR%20%2F%3E%E8%A1%A8%E7%A4%BA%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%8C%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E6%98%A0%E5%83%8F%E8%A3%85%E7%BD%AE%E6%95%85%E9%9A%9C%E3%80%81%E9%80%80%E4%BD%8D-19%3CBR%20%2F%3E%3CBR%20%2F%3E%5B0%5D%20LCD-controller%4032e80000%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%3CBR%20%2F%3E%5B1%5D%20mipi_dsi%4032e60000%E3%80%81video_bridge%3CBR%20%2F%3E%5B2%5D%20adv7535%403d%E3%80%81%E3%83%91%E3%83%8D%E3%83%AB%3CBR%20%2F%3Eadv7535_mipi2hdmi%20adv7535%403d%3A%20cec%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9ID%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%3D0x3c%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E5%A4%B1%E6%95%97%20%E3%83%91%E3%83%8D%E3%83%AB%E8%A3%85%E7%BD%AEadv7535%403d%3CBR%20%2F%3E%E8%A1%A8%E7%A4%BA%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%8C%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E6%98%A0%E5%83%8F%E8%A3%85%E7%BD%AE%E6%95%85%E9%9A%9C%E3%80%81%E9%80%80%E4%BD%8D-19%3CBR%20%2F%3E%E5%87%BA%E6%BC%94%3A%E9%80%A3%E7%B6%9A%E3%83%89%E3%83%A9%E3%83%9E%3CBR%20%2F%3E%E7%B5%82%E4%BA%86%3A%E9%80%A3%E7%B6%9A%E3%83%89%E3%83%A9%E3%83%9E%3CBR%20%2F%3E%E3%81%88%E3%81%A3%E3%81%A8%3A%E9%80%A3%E7%B6%9A%3CBR%20%2F%3E%E7%AC%AC0%E7%AF%80%3ARNG%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E5%8C%96%3CBR%20%2F%3EMMC%3A%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AF%E6%8F%90%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3EUSB%E8%B5%B7%E5%8B%95%E6%A4%9C%E5%87%BA%E3%80%82Fastboot%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B!%3CBR%20%2F%3E%E3%83%8D%E3%83%83%E3%83%88%3AFEC0%E3%81%AEPHY%E3%81%8C%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3Aaddr%201%3CBR%20%2F%3EFEC0%3A%20addr%201%E3%81%AEPHY%E3%81%8C%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3Eeth1%3Aethernet%4030bf0000%E3%80%90%E3%83%97%E3%83%A9%E3%82%A4%E3%83%A0%E3%80%91%3CBR%20%2F%3E%E9%80%9F%E6%94%BB%3A%E9%80%9A%E5%B8%B8%3CBR%20%2F%3Emfgtools%E3%81%AEUSB%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%20-%20mfgtools%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E7%92%B0%E5%A2%83%E3%82%92%E3%81%94%E5%88%A9%E7%94%A8%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CBR%20%2F%3E%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E7%92%B0%E5%A2%83%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%AE%9F%E8%A1%8Cbootcmd_mfg%3A%E5%AE%9F%E8%A1%8Cmfgtool_args%3B%E3%82%82%E3%81%97%E6%83%85%E5%A0%B1%E3%81%8C%20%24%7Binitrd_addr%7D%E3%81%AA%E3%82%89%3B%E3%82%82%E3%81%97%E3%83%86%E3%82%B9%E3%83%88%E3%81%AA%E3%82%89%20%24%7Btee%7D%20%3D%E3%81%AF%E3%81%84%3B%E6%AC%A1%E3%81%ABbootm%20%24%7Btee_addr%7D%20%24%7Binitrd_addr%7D%20%24%7Bfdt_addr%7D%3B%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0booti%20%24%7Bloadaddr%7D%20%24%7Binitrd_addr%7D%20%24%7Bfdt_addr%7D%3Bfi%3B%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%82%A8%E3%82%B3%E3%83%BC%E3%80%8CRun%20fastboot%20...%22%3B%E3%83%95%E3%82%A1%E3%82%B9%E3%83%88%E3%83%96%E3%83%BC%E3%83%880%3BFI%3B%3CBR%20%2F%3E%E3%81%A9%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%82%82%E3%82%AA%E3%83%BC%E3%83%88%E3%83%96%E3%83%BC%E3%83%88%E3%82%92%E6%AD%A2%E3%82%81%E3%82%8B%3A0%3CBR%20%2F%3E%3CBR%20%2F%3E%23%23%2043800000%E3%81%A7%E7%94%BB%E5%83%8F%E7%A2%BA%E8%AA%8D%E4%B8%AD...%3CBR%20%2F%3E%E4%B8%8D%E6%98%8E%E3%81%AA%E7%94%BB%E5%83%8F%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88!%3CBR%20%2F%3Efastboot%E3%82%92%E5%AE%9F%E8%A1%8C...%3CBR%20%2F%3E%20USB%E5%88%9D%E6%9C%9F%E5%8C%96%E5%A4%B1%E6%95%97%3A%20-22%3CBR%20%2F%3E%20u-boot%3D%26gt%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20USB%20init%20failed%3A%20-22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E5%BE%8C%E3%81%AE%E3%83%97%E3%83%AA%E3%83%93%E3%83%AB%E3%83%89%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fembedded-software%2Fi-mx-software%2Fembedded-linux-for-i-mx-applications-processors%3AIMXLINUX%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FA%3E(%3CSTRONG%3ELinux%206.18.20_2.0.0%3C%2FSTRONG%3E)%E3%81%A8%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fmfgtools%2Freleases%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Euuu%3C%2FA%3E%20%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E6%9C%80%E7%B5%82%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E5%86%8D%E5%BA%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%95%AC%E5%85%B7%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
