USB init failed: -22
ap3415
Hi ,
I have been trying to flash my wic.b2z image to an emmc using uuc tool through a usb port.While flashing an USB init failed: -22 error occured.I am using an imx8mp porcessor.
Run bootcmd_mfg: run mfgtool_args;if iminfo ${initrd_addr}; then if test ${tee} = yes; then bootm ${tee_addr} ${initrd_addr} ${fdt_addr}; else booti ${loadaddr} ${initrd_addr} ${fdt_addr}; fi; else echo "Run fastboot ..."; fastboot 0; fi;
Hit any key to stop autoboot: 0
## Checking Image at 43800000 ...
Unknown image format!
Run fastboot ...
u-boot=>
Oswalag
Please try again flashing the last pre-build image (Linux 6.18.20_2.0.0) and the last version of the uuu tool.
Regards.
Oswalag
Please share the complete process and the boot config of your board to analyze what can cause the issue.
ap3415
U-Boot SPL 2024.04-lf_v2024.04+g6c4545203d1+p0 (Nov 15 2024 - 04:02:13 +0000)
DDRINFO: start DRAM init
DDRINFO: DRAM rate 4000MTS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
SEC0:  RNG instantiated
Normal Boot
Trying to boot from BOOTROM
Boot Stage: USB boot
Find img info 0x48022fa0, size 1064
Need continue download 1024
NOTICE:  Do not release JR0 to NS as it can be used by HAB
NOTICE:  BL31: v2.10.0  (release):automotive-15.0.0_1.1.0
NOTICE:  BL31: Built : 08:52:12, Nov  4 2024
U-Boot 2024.04-lf_v2024.04+g6c4545203d1+p0 (Nov 15 2024 - 04:02:13 +0000)
CPU:   i.MX8MP Lite[4] rev1.1 1600 MHz (running at 1200 MHz)
CPU:   Industrial temperature grade (-40C to 105C) at 35C
Reset cause: POR
Model: NXP i.MX8MPlus LPDDR4 EVK board
DRAM:  6 GiB
tcpc_init: Can't find device id=0x50
setup_typec: tcpc port2 init failed, err=-19
setup_typec: tcpc port1 init failed, err=-19
Core:  284 devices, 36 uclasses, devicetree: separate
MMC:   FSL_SDHC: 1, FSL_SDHC: 2
Loading Environment from nowhere... OK
[*]-Video Link 0adv7535_mipi2hdmi adv7535@3d: Can't find cec device id=0x3c
fail to probe panel device adv7535@3d
fail to get display timings
probe video device failed, ret -19
        [0] lcd-controller@32e80000, video
        [1] mipi_dsi@32e60000, video_bridge
        [2] adv7535@3d, panel
In:    serial
Out:   serial
Err:   serial
MMC: no card present
Detect USB boot. Will enter fastboot mode!
Net:   Could not get PHY for FEC0: addr 1
eth1: ethernet@30bf0000 [PRIME]
Fastboot: Normal
Boot from USB for mfgtools
*** Warning - Use default environment for                                mfgtools
, using default environment
Run fastboot ...
u-boot=>
%3CLINGO-SUB%20id%3D%22lingo-sub-2412396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUSB%20init%20failed%3A%20-22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2412396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%2C%3C%2FP%3E%3CP%3EI%20have%20been%20trying%20to%20flash%20my%20wic.b2z%20image%20to%20an%20emmc%20using%20uuc%20tool%20through%20a%20usb%20port.While%20flashing%20an%26nbsp%3BUSB%20init%20failed%3A%20-22%20error%20occured.I%20am%20using%20an%20imx8mp%20porcessor.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ERun%20bootcmd_mfg%3A%20run%20mfgtool_args%3Bif%20iminfo%20%24%7Binitrd_addr%7D%3B%20then%20if%20test%20%24%7Btee%7D%20%3D%20yes%3B%20then%20bootm%20%24%7Btee_addr%7D%20%24%7Binitrd_addr%7D%20%24%7Bfdt_addr%7D%3B%20else%20booti%20%24%7Bloadaddr%7D%20%24%7Binitrd_addr%7D%20%24%7Bfdt_addr%7D%3B%20fi%3B%20else%20echo%20%22Run%20fastboot%20...%22%3B%20fastboot%200%3B%20fi%3B%3CBR%20%2F%3EHit%20any%20key%20to%20stop%20autoboot%3A%200%3C%2FP%3E%3CP%3E%23%23%20Checking%20Image%20at%2043800000%20...%3CBR%20%2F%3EUnknown%20image%20format!%3CBR%20%2F%3ERun%20fastboot%20...%3CBR%20%2F%3EUSB%20init%20failed%3A%20-22%3CBR%20%2F%3Eu-boot%3D%26gt%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2412396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20Family%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2412779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20USB%20init%20failed%3A%20-22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2412779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPlease%20share%20the%20complete%20process%20and%20the%20boot%20config%20of%20your%20board%20to%20analyze%20what%20can%20cause%20the%20issue.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2412906%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20USB%20init%20failed%3A%20-22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2412906%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3EU-Boot%20SPL%202024.04-lf_v2024.04%2Bg6c4545203d1%2Bp0%20(Nov%2015%202024%20-%2004%3A02%3A13%20%2B0000)%3CBR%20%2F%3EDDRINFO%3A%20start%20DRAM%20init%3CBR%20%2F%3EDDRINFO%3A%20DRAM%20rate%204000MTS%3CBR%20%2F%3EDDRINFO%3Addrphy%20calibration%20done%3CBR%20%2F%3EDDRINFO%3A%20ddrmix%20config%20done%3CBR%20%2F%3ESEC0%3A%20%26nbsp%3BRNG%20instantiated%3CBR%20%2F%3ENormal%20Boot%3CBR%20%2F%3ETrying%20to%20boot%20from%20BOOTROM%3CBR%20%2F%3EBoot%20Stage%3A%20USB%20boot%3CBR%20%2F%3EFind%20img%20info%200x48022fa0%2C%20size%201064%3CBR%20%2F%3ENeed%20continue%20download%201024%3CBR%20%2F%3ENOTICE%3A%20%26nbsp%3BDo%20not%20release%20JR0%20to%20NS%20as%20it%20can%20be%20used%20by%20HAB%3CBR%20%2F%3ENOTICE%3A%20%26nbsp%3BBL31%3A%20v2.10.0%20%26nbsp%3B(release)%3Aautomotive-15.0.0_1.1.0%3CBR%20%2F%3ENOTICE%3A%20%26nbsp%3BBL31%3A%20Built%20%3A%2008%3A52%3A12%2C%20Nov%20%26nbsp%3B4%202024%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EU-Boot%202024.04-lf_v2024.04%2Bg6c4545203d1%2Bp0%20(Nov%2015%202024%20-%2004%3A02%3A13%20%2B0000)%3CBR%20%2F%3E%3CBR%20%2F%3ECPU%3A%20%26nbsp%3B%20i.MX8MP%20Lite%5B4%5D%20rev1.1%201600%20MHz%20(running%20at%201200%20MHz)%3CBR%20%2F%3ECPU%3A%20%26nbsp%3B%20Industrial%20temperature%20grade%20(-40C%20to%20105C)%20at%2035C%3CBR%20%2F%3EReset%20cause%3A%20POR%3CBR%20%2F%3EModel%3A%20NXP%20i.MX8MPlus%20LPDDR4%20EVK%20board%3CBR%20%2F%3EDRAM%3A%20%26nbsp%3B6%20GiB%3CBR%20%2F%3Etcpc_init%3A%20Can't%20find%20device%20id%3D0x50%3CBR%20%2F%3Esetup_typec%3A%20tcpc%20port2%20init%20failed%2C%20err%3D-19%3CBR%20%2F%3Etcpc_init%3A%20Can't%20find%20device%20id%3D0x50%3CBR%20%2F%3Esetup_typec%3A%20tcpc%20port1%20init%20failed%2C%20err%3D-19%3CBR%20%2F%3ECore%3A%20%26nbsp%3B284%20devices%2C%2036%20uclasses%2C%20devicetree%3A%20separate%3CBR%20%2F%3EMMC%3A%20%26nbsp%3B%20FSL_SDHC%3A%201%2C%20FSL_SDHC%3A%202%3CBR%20%2F%3ELoading%20Environment%20from%20nowhere...%20OK%3CBR%20%2F%3E%5B*%5D-Video%20Link%200adv7535_mipi2hdmi%20adv7535%403d%3A%20Can't%20find%20cec%20device%20id%3D0x3c%3CBR%20%2F%3Efail%20to%20probe%20panel%20device%20adv7535%403d%3CBR%20%2F%3Efail%20to%20get%20display%20timings%3CBR%20%2F%3Eprobe%20video%20device%20failed%2C%20ret%20-19%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%5B0%5D%20lcd-controller%4032e80000%2C%20video%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%5B1%5D%20mipi_dsi%4032e60000%2C%20video_bridge%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%5B2%5D%20adv7535%403d%2C%20panel%3CBR%20%2F%3Eadv7535_mipi2hdmi%20adv7535%403d%3A%20Can't%20find%20cec%20device%20id%3D0x3c%3CBR%20%2F%3Efail%20to%20probe%20panel%20device%20adv7535%403d%3CBR%20%2F%3Efail%20to%20get%20display%20timings%3CBR%20%2F%3Eprobe%20video%20device%20failed%2C%20ret%20-19%3CBR%20%2F%3EIn%3A%20%26nbsp%3B%20%26nbsp%3Bserial%3CBR%20%2F%3EOut%3A%20%26nbsp%3B%20serial%3CBR%20%2F%3EErr%3A%20%26nbsp%3B%20serial%3CBR%20%2F%3ESEC0%3A%20%26nbsp%3BRNG%20instantiated%3CBR%20%2F%3EMMC%3A%20no%20card%20present%3CBR%20%2F%3EDetect%20USB%20boot.%20Will%20enter%20fastboot%20mode!%3CBR%20%2F%3ENet%3A%20%26nbsp%3B%20Could%20not%20get%20PHY%20for%20FEC0%3A%20addr%201%3CBR%20%2F%3ECould%20not%20get%20PHY%20for%20FEC0%3A%20addr%201%3CBR%20%2F%3Eeth1%3A%20ethernet%4030bf0000%20%5BPRIME%5D%3CBR%20%2F%3EFastboot%3A%20Normal%3CBR%20%2F%3EBoot%20from%20USB%20for%20mfgtools%3CBR%20%2F%3E***%20Warning%20-%20Use%20default%20environment%20for%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bmfgtools%3CBR%20%2F%3E%2C%20using%20default%20environment%3CBR%20%2F%3E%3CBR%20%2F%3ERun%20bootcmd_mfg%3A%20run%20mfgtool_args%3Bif%20iminfo%20%24%7Binitrd_addr%7D%3B%20then%20if%20test%20%24%7Btee%7D%20%3D%20yes%3B%20then%20bootm%20%24%7Btee_addr%7D%20%24%7Binitrd_addr%7D%20%24%7Bfdt_addr%7D%3B%20else%20booti%20%24%7Bloadaddr%7D%20%24%7Binitrd_addr%7D%20%24%7Bfdt_addr%7D%3B%20fi%3B%20else%20echo%20%22Run%20fastboot%20...%22%3B%20fastboot%200%3B%20fi%3B%3CBR%20%2F%3EHit%20any%20key%20to%20stop%20autoboot%3A%20%26nbsp%3B0%3CBR%20%2F%3E%3CBR%20%2F%3E%23%23%20Checking%20Image%20at%2043800000%20...%3CBR%20%2F%3EUnknown%20image%20format!%3CBR%20%2F%3ERun%20fastboot%20...%3CBR%20%2F%3EUSB%20init%20failed%3A%20-22%3CBR%20%2F%3Eu-boot%3D%26gt%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20USB%20init%20failed%3A%20-22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPlease%20try%20again%20flashing%20the%20last%20pre-build%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fembedded-software%2Fi-mx-software%2Fembedded-linux-for-i-mx-applications-processors%3AIMXLINUX%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eimage%3C%2FA%3E%26nbsp%3B(%3CSTRONG%3ELinux%206.18.20_2.0.0%3C%2FSTRONG%3E)%20and%20the%20last%20version%20of%20the%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fmfgtools%2Freleases%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Euuu%3C%2FA%3E%20tool.%26nbsp%3B%3C%2FP%3E%0A%3CP%3ERegards.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
