USB WiFi dongles
USB WiFi dongles
1,824 次查看
PeteSwenson
Has anyone tested or know of any working USB WiFi dongles with the QSB?  There appears to be support for Atheros, but I don't know to what extent.
I've plugged in the following, but they didn't come up:
Linksys WUSB300N
Rosewill RNX-G1
TP-LINK TL-WN321G
Thanks.
1,629 次查看
CraigPetku
I enabled the dlink DWA-160A2 (under $20 on ebay) under Android a couple weeks back on an EVK derivative.  Should work on the QSB as well.  The biggest trick is WPA supplicant.  If I have some time I'll try to post a clean patch for the QSB Ubuntu as well, but you may find the attached a little helpful.  The driver is compiled as a .ko as part of the kernel build then manually copied to a prebuilt folder along with the firmware files.
