I'm using an MIMXRT1021 that is required to store USB-HS data (at least 16GB) to NVM storage.
Is there a recommended solution as to what memory and what memory configuration to use? My thoughts are an eMMC part connected to the USDHC2 peripheral using the 8-pin data interface.
Can someone share an application note link on how to make this connection?
