USB Enumeration failed while communicating with mimxrt1170 with quectel EC200U
1,527 次查看
Khanajkmal
 i am running usb demo example with some changes i am able to communicate with quectel EC200U, but while restarting the same program in IDE iam getting enumeration failed if i done again it is working properly few below such cases
1st time run -> working fine
2nd restart->enumaration failed
3rd restart -> working fine
4th restart->enumaration failed
5th restart -> working fine
this thing repeat again and again
may i know the what is the problem
Thank you and Regards
akmal
1 回复
1,491 次查看
vicentegomez
What happens if you test it just resetting the imx rt without the debuger? do you have the same problem?
