USB Enumeration failed while communicating with mimxrt1170 with quectel EC200U
Khanajkmal
 i am running usb demo example with some changes i am able to communicate with quectel EC200U, but while restarting the same program in IDE iam getting enumeration failed if i done again it is working properly few below such cases
1st time run -> working fine
2nd restart->enumaration failed
3rd restart -> working fine
4th restart->enumaration failed
5th restart -> working fine
this thing repeat again and again
may i know the what is the problem
Thank you and Regards
akmal
vicentegomez
What happens if you test it just resetting the imx rt without the debuger? do you have the same problem?
