USB Communication Between PC and i.MX53 Board
mujeebshaik
I am working on i.MX53 OS:WinCE700
I want to establish communication between PC and i.MX53 Board please suggest me how to make it.
Thanks & Regards
Shaik.
qiang_li-mpu_se
If your PC is Windows XP, you need install Microsoft ActiveSync on it; if your PC is Windows Vista or Windows 7, you need install Windows Mobile Device Centor on it.
Then when you connected the WinCE device with PC by USB, it will be connected automatically.
mujeebshaik
Hi Qiang Li,
Thanks for your reply,
I can make the thing which you said it is working good,
but i want to transfer some data from Board to PC on USB bus,like how we will transfer data using Serial Driver(UART),if you have any idea please let me know
qiang_li-mpu_se
After connected the WinCE with PC, you can use WIndows Explorer on PC side to explorer the files on WinCE device, of course, you can also copy files.
For UART transfer, it can only work in ActiveSync, and the WinCE registry should also be changed to support serial ActiveSync.
