USB CDC stopped working when I got the NOR_Flash working...
1,000 次查看
tom_porter
Using an RT1021, I started with the FeeRTOS hello project, using the 1020 dev kit as my HW board, I added in the USB CDC libraries no probs, and got the CDC USB functions and talking fine. I need NVM, so I added in the flexspi_nor_flash example, after searching finally found that the HW was crashing since the linker scripts were not there. So I brought over the linker scripts, containing
*(EXCLUDE_FILE(*flexspi_nor_flash_ops.o *fsl_flexspi.o) .text*)
and
<#if memory.name=="SRAM_ITC">
*flexspi_nor_flash_ops.o(.text*)
*fsl_flexspi.o(.text*)
</#if>
and
<#if memory.name=="BOARD_SDRAM">
*(.bss*)
</#if>
However once I do this, the USB CDC stops working, in device manager it
complains code 43, a request for the USB descriptor failed. Has anyone
else run into this? The UART on this board still works fine.
If I remove the linker scripts and comment out calling the nor_flash
functions, the USB starts working again.
Thanks and much appreciated.
955 次查看
mayliu1
Hi @tom_porter ,
If SEMC(the external SDRAM controller) is not initialized, operations on the .bss section may fail. This may cause  crashes, and USB CDC initialization may fail as well.
Please try below:
1: Set .bss in internal SRAM (Do not use SDRAM).
2: If you need use SDRAM  , enable XIP_BOOT_HEADER_DCD_ENABLE = 1
Wish it helps you
Best Regards
MayLiu
887 次查看
tom_porter
Worked great, thanks for the help
956 次查看
mayliu1
Hi @tom_porter ,
Please try below:
Wish it helps you
Best Regards
MayLiu
%3CLINGO-SUB%20id%3D%22lingo-sub-2305576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%BD%93%E6%88%91%E8%AE%A9%20NOR_Flash%20%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E6%97%B6%EF%BC%8CUSB%20CDC%20%E5%81%9C%E6%AD%A2%E5%B7%A5%E4%BD%9C...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2305576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%BF%E7%94%A8%20RT1021%EF%BC%8C%E6%88%91%E4%BB%8E%20FeerTOS%20%E4%BD%A0%E5%A5%BD%E9%A1%B9%E7%9B%AE%E5%BC%80%E5%A7%8B%EF%BC%8C%E4%BD%BF%E7%94%A8%201020%20%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E4%BD%9C%E4%B8%BA%E6%88%91%E7%9A%84%E7%A1%AC%E4%BB%B6%E6%9D%BF%EF%BC%8C%E6%88%91%E5%9C%A8%20USB%20CDC%20%E5%BA%93%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BA%86%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%EF%BC%8C%E5%BE%97%E5%88%B0%E4%BA%86%20CDC%20%E7%9A%84%20USB%20%E5%8A%9F%E8%83%BD%EF%BC%8C%E8%80%8C%E4%B8%94%E8%AF%B4%E8%AF%9D%E8%BF%98%E4%B8%8D%E9%94%99%E3%80%82%E6%88%91%E9%9C%80%E8%A6%81%20NVM%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E6%B7%BB%E5%8A%A0%E4%BA%86%20flexspi_nor_flash%20%E7%A4%BA%E4%BE%8B%EF%BC%8C%E7%BB%8F%E8%BF%87%E6%90%9C%E7%B4%A2%E7%BB%88%E4%BA%8E%E5%8F%91%E7%8E%B0%EF%BC%8C%E7%94%B1%E4%BA%8E%E9%93%BE%E6%8E%A5%E5%99%A8%E8%84%9A%E6%9C%AC%E4%B8%8D%E5%AD%98%E5%9C%A8%EF%BC%8C%E5%AF%BC%E8%87%B4%E7%A1%AC%E4%BB%B6%E5%B4%A9%E6%BA%83%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E6%8B%BF%E6%9D%A5%E4%BA%86%E9%93%BE%E6%8E%A5%E5%99%A8%E8%84%9A%E6%9C%AC%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%8C%85%E5%90%AB%3C%2FP%3E%3CP%3E%3CSPAN%3E*(EXCLUDE_FILE(*flexspi_nor_flash_ops.o%20*fsl_flexspi.o).text*)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BB%A5%E5%8F%8A%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%26lt%3B%23if%3C%2FSPAN%3Ememory.name%3D%3D%3CSPAN%3E%22SRAM_ITC%22%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3Eflexspi_nor_flash_ops.o%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E.%E6%96%87%E6%9C%AC%3C%2FSPAN%3E%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3Efsl_flexspi.o%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E.text%3C%2FSPAN%3E%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%A5%E5%8F%8A%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%26lt%3B%23if%3C%2FSPAN%3Ememory.name%3D%3D%3CSPAN%3E%22BOARD_SDRAM%22%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E.bss%3C%2FSPAN%3E%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E4%B8%80%E6%97%A6%E6%88%91%E8%BF%99%E6%A0%B7%E5%81%9A%EF%BC%8CUSB%20CDC%20%E5%B0%B1%E4%BC%9A%E5%81%9C%E6%AD%A2%E5%B7%A5%E4%BD%9C%EF%BC%8C%E5%9C%A8%E8%AE%BE%E5%A4%87%E7%AE%A1%E7%90%86%E5%99%A8%E4%B8%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%8A%B1%E6%80%A8%E4%BB%A3%E7%A0%81%2043%EF%BC%8C%E8%AF%B7%E6%B1%82%20USB%20%E6%8F%8F%E8%BF%B0%E7%AC%A6%E5%A4%B1%E8%B4%A5%E3%80%82%E6%98%AF%E5%90%A6%E6%9C%89%E4%BA%BA%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%BF%98%E6%9C%89%E4%BA%BA%E9%81%87%E5%88%B0%E8%BF%87%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E5%90%97%EF%BC%9F%E8%BF%99%E4%B8%AA%E6%9D%BF%E4%B8%8A%E7%9A%84%20UART%20%E4%BB%8D%E7%84%B6%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%88%A0%E9%99%A4%E9%93%BE%E6%8E%A5%E5%99%A8%E8%84%9A%E6%9C%AC%E5%B9%B6%E6%B3%A8%E9%87%8A%E6%8E%89%E8%B0%83%E7%94%A8%20nor_flash%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%8A%9F%E8%83%BD%EF%BC%8CUSB%20%E5%B0%B1%E4%BC%9A%E9%87%8D%E6%96%B0%E5%BC%80%E5%A7%8B%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2312530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20USB%20CDC%20stopped%20working%20when%20I%20got%20the%20NOR_Flash%20working...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2312530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F156668%22%20target%3D%22_blank%22%3E%EF%BC%8C%40tom_porter%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%AF%B9%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%E4%BA%A7%E5%93%81%E7%9A%84%E5%85%B3%E6%B3%A8%E5%B9%B6%E6%9C%89%E6%9C%BA%E4%BC%9A%E4%B8%BA%E6%82%A8%E6%9C%8D%E5%8A%A1%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%0A%3CDIV%3E%E5%A6%82%E6%9E%9C%20SEMC%EF%BC%88%E5%A4%96%E9%83%A8%20%E5%90%8C%E6%AD%A5%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8%20%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%89%E6%9C%AA%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%8C%E5%88%99%E5%9C%A8%20.bss%20%E4%B8%8A%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%E9%83%A8%E5%88%86%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%A4%B1%E8%B4%A5%E3%80%82%E8%BF%99%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%AF%BC%E8%87%B4%E5%B4%A9%E6%BA%83%EF%BC%8CUSB%20CDC%20%E5%88%9D%E5%A7%8B%E5%8C%96%E4%B9%9F%E5%8F%AF%E8%83%BD%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E4%BB%A5%E4%B8%8B%E6%96%B9%E6%B3%95%EF%BC%9A%3C%2FP%3E%0A%3CP%3E1%EF%BC%9A%E5%9C%A8%E5%86%85%E9%83%A8%20SRAM%20%E4%B8%AD%E8%AE%BE%E7%BD%AE%20.bss%EF%BC%88%E8%AF%B7%E5%8B%BF%E4%BD%BF%E7%94%A8%20%E5%90%8C%E6%AD%A5%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(SDRAM)%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E2%EF%BC%9A%E5%A6%82%E6%9E%9C%E4%BD%A0%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20%E5%90%8C%E6%AD%A5%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(SDRAM)%EF%BC%8C%E8%AF%B7%E5%90%AF%E7%94%A8%20XIP_BOOT_HEADER_DCD_ENABLE%20%3D%201%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_0-1770261412523.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_0-1770261412523.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_0-1770261412523.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375592iEB983CD1BE2C1205%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_0-1770261412523.png%22%20alt%3D%22mayliu1_0-1770261412523.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EMayLiu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2317378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20USB%20CDC%20stopped%20working%20when%20I%20got%20the%20NOR_Flash%20working...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2317378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%95%88%E6%9E%9C%E5%BE%88%E5%A5%BD%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E
