USB CDC VCOM - Enable / Disable Flow Control (RTS/CTS)
variable_andrew
Senior Contributor I
I've seen some brief mentions but no specific guide of what to change in the MCUXpresso SDK (USB CDC Vcom example) to enable / disable flow control.
Could someone point me in the right direction?
Tags (4)
variable_andrew
anyone worked with this?
specifically - i dont' see any flow control settings in the usb_device_descriptor.c/h files - so how does the device tell the opponent if it expects flow control?
