USB BT support with Bluedroid
ソリューションへジャンプ
2,753件の閲覧回数
amit251291
We are using SaberSd platform running with Nought.
I have heard that USB BT is not supported by Bluedroid. Is it correct ?
If its not supporting by default then are there any patches available to make it work ?
Thanks & Regards
Amit
タグ(3)
2,428件の閲覧回数
jamesbone
Dear Amit,
It is correct BlueDroid does not support  USB Bluetooth dongles.  As you can see in the following article, Returning BlueZ to Android [LWN.net] .   There is an option that BlueZ for Android (BfA), would be a replacement for BlueDroid but at the moment it is not available in our BSP.
Have a nice day sir!
TIC Support Team
2 返答(返信)
2,429件の閲覧回数
jamesbone
Dear Amit,
TIC Support Team
2,428件の閲覧回数
amit251291
Thanks Jamesbone for your reply & for providing supporting information. I will go through it.
Have a wonderful day ahead!
