U-Boot
U-Boot
nadimnadaf
~/var-fslc-yocto$ cp -a tmp/work/imx8mm_var_dart-poky-linux/u-boot-variscite/1.0-r0/git/. ../local_repos/uboot-imx
This command show a following error
cp: cannot stat 'tmp/work/imx8mm_var_dart-poky-linux/u-boot-variscite/1.0-r0/git/.': No such file or directory
How to remove this Error?
Harvey021
Hello nadimnadaf,
I suppose that you run command cp on a host of Ubuntu or Linux-like. Then I would recommend you to check the path for both.
A way like hit Tab key to navigate to the directory for both.
Harvey
