Trying to develop linux application to perfom inference on ethosu65
4,098件の閲覧回数
phanichinimilli
On imx93, my Goal is to comeup with an application that can run a vela model on ethosu65. I am able to build a linux image with ML examples and run the same(label_image) on A55 and on ethosu65.
im interested in finding source code for label_image application but not able to find any source code in yocto build directory
ラベル(2)
3 返答(返信)
4,058件の閲覧回数
phanichinimilli
Thanks for the prompt response.
 github points to the python code, I'm more interested in finding c/c++ source code that invokes ethos driver.
so that I can experiment, modify and recompile and copy it to rootfs
I'm following build procedure mentioned in
4,081件の閲覧回数
Chavira
Hi @phanichinimilli!
Thank you for contacting NXP Support!
The examples can be found in our github.
Best Regards!
Chavira
4,009件の閲覧回数
phanichinimilli
Is there a way I can find c++ code for the label_image application, I think it is modified version of tensorflow's label_image i.e. https://github.com/tensorflow/tensorflow/blob/master/tensorflow/lite/examples/label_image/label_imag...
