Title: i.MX8MP V4L2 H.264 Encoder Fails on Dynamic Runtime Update (Bitrate Mode / Resolution) — poll
VishnuSidda
IMX8MPLUS
Platform Details:
  • SoC: i.MX8MP
  • BSP: (Linux imx8mpevk 6.12.20-lts-next-gdfaf2136deb2)
  • GStreamer: 1.26.0 (NXP plugins)
  • Encoder: v4l2h264enc
  • Source: v4l2src (camera)
  • OS: Linux (Yocto-based)
Use Case:
We are building a dynamic multi-stream video pipeline using GStreamer with the following architecture:
v4l2src → capsfilter → imxvideoconvert_g2d → tee
                                         ├── RTSP branch (v4l2h264enc)
We dynamically create/remove encoder branches from a tee (using request pads) and support runtime configuration updates via API.
Problem Description:
We are attempting to dynamically update encoder parameters at runtime (pipeline in PLAYING state), specifically:
  • Bitrate mode (CBR / VBR)
  • Bitrate
  • Resolution (caps change)
This is done using:
  • g_object_set() on encoder (extra-controls)
  • Updating caps on downstream capsfilter
  • Updating videorate (max-rate)
Relevant Code (Simplified):
enc_el.set_property("extra-controls", Gst.Structure.new_from_string(
    "controls,video_bitrate_mode=1,video_gop_size=25"))
rate_el.set_property("max-rate", fps)
res_el.set_property("caps", Gst.Caps.from_string(
    f"video/x-raw,width={w},height={h},format=BGRx"))
Observed Behavior:
Immediately after applying dynamic update (especially bitrate mode change), pipeline fails with:
gstvideoencoder.c:2506:
Can't copy metadata because input frame disappeared
v4l2object.c:6524: gst_v4l2_object_poll:
poll error 1: Invalid argument (22)
GST_ERROR:
Could not read from resource.
gstbasesrc.c:3187:
Internal data stream error.
streaming stopped, reason error (-5)
This results in:
  • Encoder failure (v4l2h264enc)
  • Queue failure
  • Source (v4l2src) stopping
  • Entire pipeline going to error state
Full Error Logs (Excerpt):
gst_v4l2_object_poll:<v4l2h264enc> error: poll error 1: Invalid argument (22)
gst_element_message_full_with_details: Could not read from resource
gst_base_src_loop:<v4l2src> error: Internal data stream error
Key Observations:
  1. Issue is reproducible when changing:
    • video_bitrate_mode (CBR ↔ VBR)
    • bitrate
  2. Sometimes encoder accepts property but:
    • no visible effect OR
    • fails shortly after
  3. FPS changes using videorate work fine
  4. Resolution changes sometimes work but are unstable
Questions:
  1. Is runtime update of v4l2h264enc controls supported?
    • Specifically:
      • video_bitrate
      • video_gop_size
  2. Are these controls required to be set only in:
    • NULL / READY state?
  3. Does the i.MX8MP VPU driver support:
    • dynamic bitrate adjustment in PLAYING state?
  4. For resolution change:
    • Is dynamic caps renegotiation supported with imxvideoconvert_g2d + encoder?
    • Or is pipeline restart required?
  5. What is the recommended approach for:
    • changing bitrate mode (CBR/VBR)
    • changing resolution
    • in a live streaming pipeline?
Additional Context:
In commercial IP cameras, bitrate appears to change dynamically without stream interruption.
We would like to understand whether:
  • This is supported at driver level, or
  • Requires encoder restart / pipeline rebuild.
Expected Guidance:
  • Official recommendation from NXP for runtime encoder reconfiguration
  • Supported vs unsupported controls in PLAYING state
  • Best practice for dynamic streaming pipelines
Summary:
Dynamic updates to v4l2h264enc (especially bitrate mode) result in:
  • V4L2 poll errors (EINVAL)
  • Encoder failure
  • Pipeline crash
We want to confirm whether this is expected behavior and how to correctly implement dynamic reconfiguration.
Thank you.
joanxie
I've already mailed to you for enabling VBR, then you can control it dynamically, pls check my mail
%3CLINGO-SUB%20id%3D%22lingo-sub-2333932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ETitle%3A%20i.MX8MP%20V4L2%20H.264%20Encoder%20Fails%20on%20Dynamic%20Runtime%20Update%20(Bitrate%20Mode%20%2F%20Resolution)%20%E2%80%94%20poll%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2333932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FIMX8MPLUS%2Fpd-p%2FIMX8MPLUS%22%20class%3D%22lia-product-mention%22%20data-product%3D%2221-1%22%20target%3D%22_blank%22%3EIMX8MPLUS%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EPlatform%20Details%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3ESoC%3A%20i.MX8MP%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EBSP%3A%20(Linux%20imx8mpevk%206.12.20-lts-next-gdfaf2136deb2)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EGStreamer%3A%201.26.0%20(NXP%20plugins)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EEncoder%3A%20v4l2h264enc%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ESource%3A%20v4l2src%20(camera)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EOS%3A%20Linux%20(Yocto-based)%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CHR%20%2F%3E%3CP%3E%3CSTRONG%3EUse%20Case%3A%3C%2FSTRONG%3E%3CBR%20%2F%3EWe%20are%20building%20a%20%3CSTRONG%3Edynamic%20multi-stream%20video%20pipeline%3C%2FSTRONG%3E%20using%20GStreamer%20with%20the%20following%20architecture%3A%3C%2FP%3E%3CPRE%3Ev4l2src%20%E2%86%92%20capsfilter%20%E2%86%92%20imxvideoconvert_g2d%20%E2%86%92%20tee%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E2%94%9C%E2%94%80%E2%94%80%20RTSP%20branch%20(v4l2h264enc)%0A%0A%3C%2FPRE%3E%3CP%3EWe%20dynamically%20create%2Fremove%20encoder%20branches%20from%20a%20tee%20(using%20request%20pads)%20and%20support%20runtime%20configuration%20updates%20via%20API.%3C%2FP%3E%3CHR%20%2F%3E%3CP%3E%3CSTRONG%3EProblem%20Description%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EWe%20are%20attempting%20to%20%3CSTRONG%3Edynamically%20update%20encoder%20parameters%20at%20runtime%3C%2FSTRONG%3E%20(pipeline%20in%20PLAYING%20state)%2C%20specifically%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EBitrate%20mode%20(CBR%20%2F%20VBR)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EBitrate%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EResolution%20(caps%20change)%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EThis%20is%20done%20using%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3Eg_object_set()%20on%20encoder%20(extra-controls)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EUpdating%20caps%20on%20downstream%20capsfilter%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EUpdating%20videorate%20(max-rate)%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CHR%20%2F%3E%3CP%3E%3CSTRONG%3ERelevant%20Code%20(Simplified)%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CPRE%3Eenc_el.set_property(%22extra-controls%22%2C%20Gst.Structure.new_from_string(%0A%20%20%20%20%22controls%2Cvideo_bitrate_mode%3D1%2Cvideo_gop_size%3D25%22))%0A%0Arate_el.set_property(%22max-rate%22%2C%20fps)%0A%0Ares_el.set_property(%22caps%22%2C%20Gst.Caps.from_string(%0A%20%20%20%20f%22video%2Fx-raw%2Cwidth%3D%7Bw%7D%2Cheight%3D%7Bh%7D%2Cformat%3DBGRx%22))%3C%2FPRE%3E%3CHR%20%2F%3E%3CP%3E%3CSTRONG%3EObserved%20Behavior%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EImmediately%20after%20applying%20dynamic%20update%20(especially%20bitrate%20mode%20change)%2C%20pipeline%20fails%20with%3A%3C%2FP%3E%3CPRE%3Egstvideoencoder.c%3A2506%3A%0ACan't%20copy%20metadata%20because%20input%20frame%20disappeared%0A%0Av4l2object.c%3A6524%3A%20gst_v4l2_object_poll%3A%0Apoll%20error%201%3A%20Invalid%20argument%20(22)%0A%0AGST_ERROR%3A%0ACould%20not%20read%20from%20resource.%0A%0Agstbasesrc.c%3A3187%3A%0AInternal%20data%20stream%20error.%0Astreaming%20stopped%2C%20reason%20error%20(-5)%3C%2FPRE%3E%3CP%3EThis%20results%20in%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EEncoder%20failure%20(v4l2h264enc)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EQueue%20failure%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ESource%20(v4l2src)%20stopping%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EEntire%20pipeline%20going%20to%20error%20state%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CHR%20%2F%3E%3CP%3E%3CSTRONG%3EFull%20Error%20Logs%20(Excerpt)%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CPRE%3Egst_v4l2_object_poll%3A%3CV4L2H264ENC%3E%20error%3A%20poll%20error%201%3A%20Invalid%20argument%20(22)%0Agst_element_message_full_with_details%3A%20Could%20not%20read%20from%20resource%0Agst_base_src_loop%3A%3CV4L2SRC%3E%20error%3A%20Internal%20data%20stream%20error%0Astreaming%20stopped%2C%20reason%20error%20(-5)%3C%2FV4L2SRC%3E%3C%2FV4L2H264ENC%3E%3C%2FPRE%3E%3CHR%20%2F%3E%3CP%3E%3CSTRONG%3EKey%20Observations%3A%3C%2FSTRONG%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3EIssue%20is%20reproducible%20when%20changing%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3Evideo_bitrate_mode%20(CBR%20%E2%86%94%20VBR)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3Ebitrate%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3ESometimes%20encoder%20accepts%20property%20but%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3Eno%20visible%20effect%20OR%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3Efails%20shortly%20after%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3EFPS%20changes%20using%20videorate%20work%20fine%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EResolution%20changes%20sometimes%20work%20but%20are%20unstable%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CHR%20%2F%3E%3CP%3E%3CSTRONG%3EQuestions%3A%3C%2FSTRONG%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3E%3CSTRONG%3EIs%20runtime%20update%20of%20v4l2h264enc%20controls%20supported%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3ESpecifically%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3Evideo_bitrate_mode%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3Evideo_bitrate%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3Evideo_gop_size%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3EAre%20these%20controls%20required%20to%20be%20set%20only%20in%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3ENULL%20%2F%20READY%20state%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3EDoes%20the%20i.MX8MP%20VPU%20driver%20support%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3Edynamic%20bitrate%20adjustment%20in%20PLAYING%20state%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3EFor%20resolution%20change%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EIs%20dynamic%20caps%20renegotiation%20supported%20with%20imxvideoconvert_g2d%20%2B%20encoder%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EOr%20is%20pipeline%20restart%20required%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3EWhat%20is%20the%20%3CSTRONG%3Erecommended%20approach%3C%2FSTRONG%3E%20for%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3Echanging%20bitrate%20mode%20(CBR%2FVBR)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3Echanging%20resolution%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3Ein%20a%20live%20streaming%20pipeline%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FOL%3E%3CHR%20%2F%3E%3CP%3E%3CSTRONG%3EAdditional%20Context%3A%3C%2FSTRONG%3E%3CBR%20%2F%3EIn%20commercial%20IP%20cameras%2C%20bitrate%20appears%20to%20change%20dynamically%20without%20stream%20interruption.%3CBR%20%2F%3EWe%20would%20like%20to%20understand%20whether%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EThis%20is%20supported%20at%20driver%20level%2C%20or%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ERequires%20encoder%20restart%20%2F%20pipeline%20rebuild.%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CHR%20%2F%3E%3CP%3E%3CSTRONG%3EExpected%20Guidance%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EOfficial%20recommendation%20from%20NXP%20for%20runtime%20encoder%20reconfiguration%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ESupported%20vs%20unsupported%20controls%20in%20PLAYING%20state%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EBest%20practice%20for%20dynamic%20streaming%20pipelines%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CHR%20%2F%3E%3CP%3E%3CSTRONG%3ESummary%3A%3C%2FSTRONG%3E%3CBR%20%2F%3EDynamic%20updates%20to%20v4l2h264enc%20(especially%20bitrate%20mode)%20result%20in%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EV4L2%20poll%20errors%20(EINVAL)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EEncoder%20failure%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EPipeline%20crash%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EWe%20want%20to%20confirm%20whether%20this%20is%20expected%20behavior%20and%20how%20to%20correctly%20implement%20dynamic%20reconfiguration.%3C%2FP%3E%3CHR%20%2F%3E%3CP%3EThank%20you.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2333932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20Family%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2334434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Title%3A%20i.MX8MP%20V4L2%20H.264%20Encoder%20Fails%20on%20Dynamic%20Runtime%20Update%20(Bitrate%20Mode%20%2F%20Resolution)%20%E2%80%94%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2334434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI've%20already%20mailed%20to%20you%20for%20enabling%20VBR%2C%20then%20you%20can%20control%20it%20dynamically%2C%20pls%20check%20my%20mail%3C%2FP%3E%3C%2FLINGO-BODY%3E
