Threre is no /sys/class/gpio folder
dskim2
I build imx8mp yocto version 6.1.22_2.0.0 and write to device.
but there is no /sys/class/gpio folder in device file system.
How can I solve it.
The version 5.10.72_2.2.0 is ok.
joanxie
did you use demo images or your own built images? change anything?
dskim2
I used LF_v6.1.22-2.0.0_images_IMX8MPEVK.zip
below is ls command log
root@imx8mpevk:~# ls /sys/class/
ata_device hnae phy spidev
ata_link hwmon power_supply tee
ata_port i2c-adapter pps thermal
backlight i2c-dev ptp tpm
bdi ieee80211 pwm tpmrm
block input regulator tty
bluetooth iommu remoteproc typec
bsg leds retimer typec_mux
chromeos mdio_bus rpmsg ubi
devcoredump mem rtc udc
devfreq misc sas_device uio
devlink mmc_host sas_end_device usb_power_delivery
dma mtd sas_expander usb_role
dma_heap mux sas_host vc
drm mxc_hantro_845 sas_phy vfio
dvb mxc_hantro_vc8000e sas_port vfio-dev
ethosu net scsi_device video4linux
extcon nvme scsi_disk virtio-ports
firmware nvme-generic scsi_host vsi_class
fpga_manager nvme-subsystem sound vtconsole
gpu_class pci_bus spi_master wakeup
graphics pci_epc spi_slave watchdog
root@imx8mpevk:~#
joanxie
you can try to add  CONFIG_GPIO_SYSFS in the config file to enable it
dskim2
Where can I find the config file?
It's already set y in tmp/work-shared/imx8mp-lpddr4-evk/kernel-source/arch/arm64/configs/defconfig file.
joanxie
https://github.com/nxp-imx/linux-imx/blob/lf-6.1.y/arch/arm64/configs/imx_v8_defconfig
you also can enable in the menuconfig,  CONFIG_EXPERT = y, then CONFIG_GPIO_SYSFS=Y
dskim2
There is no CONFIG_GPIO_SYSFS at tmp/work-shared/imx8mp-lpddr4-evk/kernel-source/arch/arm64/configs/imx_v8_defconfig file.
below is the file's contents
CONFIG_SYSVIPC=y
CONFIG_POSIX_MQUEUE=y
CONFIG_AUDIT=y
CONFIG_NO_HZ_IDLE=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_BPF_SYSCALL=y
CONFIG_BPF_JIT=y
CONFIG_PREEMPT=y
CONFIG_IRQ_TIME_ACCOUNTING=y
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_BSD_PROCESS_ACCT_V3=y
CONFIG_TASKSTATS=y
CONFIG_TASK_XACCT=y
CONFIG_TASK_IO_ACCOUNTING=y
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_NUMA_BALANCING=y
CONFIG_MEMCG=y
CONFIG_BLK_CGROUP=y
CONFIG_CGROUP_PIDS=y
CONFIG_CGROUP_FREEZER=y
CONFIG_CGROUP_HUGETLB=y
CONFIG_CPUSETS=y
CONFIG_CGROUP_DEVICE=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_CGROUP_PERF=y
CONFIG_CGROUP_BPF=y
CONFIG_USER_NS=y
CONFIG_SCHED_AUTOGROUP=y
CONFIG_RELAY=y
CONFIG_BLK_DEV_INITRD=y
CONFIG_KALLSYMS_ALL=y
CONFIG_PROFILING=y
CONFIG_ARCH_KEEMBAY=y
CONFIG_ARCH_NXP=y
CONFIG_ARCH_LAYERSCAPE=y
CONFIG_ARCH_MXC=y
CONFIG_ARCH_S32=y
CONFIG_SOC_S32V234=y
CONFIG_ARM64_VA_BITS_48=y
CONFIG_SCHED_MC=y
CONFIG_SCHED_SMT=y
CONFIG_NUMA=y
CONFIG_KEXEC=y
CONFIG_KEXEC_FILE=y
CONFIG_CRASH_DUMP=y
CONFIG_XEN=y
CONFIG_ARCH_FORCE_MAX_ORDER=14
CONFIG_COMPAT=y
CONFIG_RANDOMIZE_BASE=y
CONFIG_PM_DEBUG=y
CONFIG_PM_TEST_SUSPEND=y
CONFIG_WQ_POWER_EFFICIENT_DEFAULT=y
CONFIG_ENERGY_MODEL=y
CONFIG_ARM_PSCI_CPUIDLE=y
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_STAT=y
CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
CONFIG_CPUFREQ_DT=y
CONFIG_ACPI_CPPC_CPUFREQ=m
CONFIG_ARM_SCPI_CPUFREQ=y
CONFIG_ARM_IMX_CPUFREQ_DT=y
CONFIG_ARM_SCMI_CPUFREQ=y
CONFIG_QORIQ_CPUFREQ=y
CONFIG_ACPI=y
CONFIG_ACPI_APEI=y
CONFIG_ACPI_APEI_GHES=y
CONFIG_ACPI_APEI_MEMORY_FAILURE=y
CONFIG_ACPI_APEI_EINJ=y
CONFIG_VIRTUALIZATION=y
CONFIG_KVM=y
CONFIG_JUMP_LABEL=y
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODVERSIONS=y
# CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
# CONFIG_COMPAT_BRK is not set
CONFIG_KSM=y
CONFIG_MEMORY_FAILURE=y
CONFIG_TRANSPARENT_HUGEPAGE=y
CONFIG_NET=y
CONFIG_PACKET=y
CONFIG_UNIX=y
CONFIG_TLS=y
CONFIG_TLS_DEVICE=y
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
CONFIG_IPV6_SIT=m
CONFIG_NETFILTER=y
CONFIG_BRIDGE_NETFILTER=m
CONFIG_NETFILTER_NETLINK_OSF=m
CONFIG_NF_CONNTRACK=m
CONFIG_NF_CONNTRACK_EVENTS=y
CONFIG_NF_TABLES=y
CONFIG_NF_TABLES_INET=y
CONFIG_NF_TABLES_NETDEV=y
CONFIG_NFT_CT=m
CONFIG_NFT_MASQ=m
CONFIG_NFT_NAT=m
CONFIG_NFT_COMPAT=m
CONFIG_NFT_DUP_NETDEV=m
CONFIG_NFT_FWD_NETDEV=m
CONFIG_NF_FLOW_TABLE=m
CONFIG_NETFILTER_XT_MARK=m
CONFIG_NETFILTER_XT_TARGET_CHECKSUM=m
CONFIG_NETFILTER_XT_TARGET_LOG=m
CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
CONFIG_NETFILTER_XT_MATCH_IPVS=m
CONFIG_IP_VS=m
CONFIG_NF_SOCKET_IPV4=m
CONFIG_NF_TPROXY_IPV4=m
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
CONFIG_IP_NF_NAT=m
CONFIG_IP_NF_TARGET_MASQUERADE=m
CONFIG_IP_NF_MANGLE=m
CONFIG_NF_SOCKET_IPV6=m
CONFIG_NF_TPROXY_IPV6=m
CONFIG_IP6_NF_IPTABLES=m
CONFIG_IP6_NF_FILTER=m
CONFIG_IP6_NF_TARGET_REJECT=m
CONFIG_IP6_NF_MANGLE=m
CONFIG_IP6_NF_NAT=m
CONFIG_IP6_NF_TARGET_MASQUERADE=m
CONFIG_NF_TABLES_BRIDGE=m
CONFIG_BRIDGE_NF_EBTABLES=m
CONFIG_BRIDGE=y
CONFIG_BRIDGE_VLAN_FILTERING=y
CONFIG_NET_DSA=m
CONFIG_VLAN_8021Q_GVRP=y
CONFIG_VLAN_8021Q_MVRP=y
CONFIG_LLC2=y
CONFIG_NET_SCHED=y
CONFIG_NET_SCH_MULTIQ=m
CONFIG_NET_SCH_CBS=m
CONFIG_NET_SCH_ETF=m
CONFIG_NET_SCH_TAPRIO=m
CONFIG_NET_SCH_MQPRIO=m
CONFIG_NET_SCH_INGRESS=m
CONFIG_NET_CLS_BASIC=m
CONFIG_NET_CLS_U32=m
CONFIG_NET_CLS_FLOWER=m
CONFIG_NET_CLS_ACT=y
CONFIG_NET_ACT_GACT=m
CONFIG_NET_ACT_MIRRED=m
CONFIG_NET_ACT_SKBEDIT=m
CONFIG_NET_ACT_GATE=m
CONFIG_TSN=y
CONFIG_QRTR=m
CONFIG_QRTR_SMD=m
CONFIG_QRTR_TUN=m
CONFIG_NET_PKTGEN=m
CONFIG_CAN=m
CONFIG_BT=y
CONFIG_BT_RFCOMM=y
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=y
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_HIDP=y
CONFIG_BT_LEDS=y
# CONFIG_BT_DEBUGFS is not set
CONFIG_BT_HCIBTUSB=m
CONFIG_BT_HCIUART=y
CONFIG_BT_HCIUART_BCSP=y
CONFIG_BT_HCIUART_ATH3K=y
CONFIG_BT_HCIUART_LL=y
CONFIG_BT_HCIUART_3WIRE=y
CONFIG_BT_HCIUART_BCM=y
CONFIG_BT_HCIUART_QCA=y
CONFIG_BT_HCIVHCI=y
CONFIG_BT_NXPUART=m
CONFIG_CFG80211=y
CONFIG_NL80211_TESTMODE=y
CONFIG_CFG80211_WEXT=y
CONFIG_MAC80211=y
CONFIG_MAC80211_LEDS=y
CONFIG_NET_9P=y
CONFIG_NET_9P_VIRTIO=y
CONFIG_NFC=m
CONFIG_NFC_NCI=m
CONFIG_NFC_S3FWRN5_I2C=m
CONFIG_PCI=y
CONFIG_PCIEPORTBUS=y
CONFIG_PCI_IOV=y
CONFIG_PCI_PASID=y
CONFIG_HOTPLUG_PCI=y
CONFIG_HOTPLUG_PCI_ACPI=y
CONFIG_PCI_HOST_GENERIC=y
CONFIG_PCI_XGENE=y
CONFIG_PCIE_ALTERA=y
CONFIG_PCIE_ALTERA_MSI=y
CONFIG_PCI_HOST_THUNDER_PEM=y
CONFIG_PCI_HOST_THUNDER_ECAM=y
CONFIG_PCI_IMX6_HOST=y
CONFIG_PCI_IMX6_EP=y
CONFIG_PCI_LAYERSCAPE=y
CONFIG_PCI_HISI=y
CONFIG_PCIE_KIRIN=y
CONFIG_PCI_MESON=m
CONFIG_PCIE_LAYERSCAPE_GEN4=y
CONFIG_PCI_ENDPOINT=y
CONFIG_PCI_ENDPOINT_CONFIGFS=y
CONFIG_PCI_EPF_TEST=y
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_FW_LOADER_USER_HELPER=y
CONFIG_FW_LOADER_USER_HELPER_FALLBACK=y
CONFIG_BRCMSTB_GISB_ARB=y
CONFIG_VEXPRESS_CONFIG=y
CONFIG_FSL_MC_UAPI_SUPPORT=y
CONFIG_ARM_SCMI_PROTOCOL=y
CONFIG_ARM_SCPI_PROTOCOL=y
CONFIG_EFI_CAPSULE_LOADER=y
CONFIG_IMX_DSP=y
CONFIG_IMX_SCU=y
CONFIG_IMX_SCU_PD=y
CONFIG_GNSS=m
CONFIG_GNSS_MTK_SERIAL=m
CONFIG_MTD=y
CONFIG_MTD_CMDLINE_PARTS=y
CONFIG_MTD_BLOCK=y
CONFIG_MTD_CFI=y
CONFIG_MTD_CFI_ADV_OPTIONS=y
CONFIG_MTD_CFI_INTELEXT=y
CONFIG_MTD_CFI_AMDSTD=y
CONFIG_MTD_CFI_STAA=y
CONFIG_MTD_PHYSMAP=y
CONFIG_MTD_PHYSMAP_OF=y
CONFIG_MTD_DATAFLASH=y
CONFIG_MTD_SST25L=y
CONFIG_MTD_RAW_NAND=y
CONFIG_MTD_NAND_DENALI_DT=y
CONFIG_MTD_NAND_GPMI_NAND=y
CONFIG_MTD_NAND_FSL_IFC=y
CONFIG_MTD_SPI_NOR=y
# CONFIG_MTD_SPI_NOR_USE_4K_SECTORS is not set
CONFIG_MTD_UBI=y
CONFIG_BLK_DEV_LOOP=y
CONFIG_BLK_DEV_NBD=m
CONFIG_XEN_BLKDEV_BACKEND=m
CONFIG_VIRTIO_BLK=y
CONFIG_BLK_DEV_NVME=y
CONFIG_SRAM=y
CONFIG_PCI_ENDPOINT_TEST=y
CONFIG_EEPROM_AT24=m
CONFIG_EEPROM_AT25=m
CONFIG_UACCE=m
# CONFIG_SCSI_PROC_FS is not set
CONFIG_BLK_DEV_SD=y
CONFIG_SCSI_SAS_ATA=y
CONFIG_SCSI_HISI_SAS=y
CONFIG_SCSI_HISI_SAS_PCI=y
CONFIG_MEGARAID_SAS=y
CONFIG_SCSI_MPT3SAS=m
CONFIG_ATA=y
CONFIG_SATA_AHCI=y
CONFIG_SATA_AHCI_PLATFORM=y
CONFIG_AHCI_IMX=y
CONFIG_AHCI_CEVA=y
CONFIG_AHCI_XGENE=y
CONFIG_AHCI_QORIQ=y
CONFIG_SATA_SIL24=y
CONFIG_PATA_OF_PLATFORM=y
CONFIG_MD=y
CONFIG_BLK_DEV_MD=m
CONFIG_BLK_DEV_DM=m
CONFIG_DM_CRYPT=m
CONFIG_DM_MIRROR=m
CONFIG_DM_ZERO=m
CONFIG_NETDEVICES=y
CONFIG_MACVLAN=m
CONFIG_MACVTAP=m
CONFIG_TUN=y
CONFIG_VETH=m
CONFIG_VIRTIO_NET=y
CONFIG_NET_DSA_MSCC_FELIX=m
CONFIG_AMD_XGBE=y
CONFIG_ATL1C=m
CONFIG_BCMGENET=m
CONFIG_BNX2X=m
CONFIG_SYSTEMPORT=m
CONFIG_MACB=y
CONFIG_THUNDER_NIC_PF=y
CONFIG_FEC=y
CONFIG_FEC_UIO=y
CONFIG_FSL_FMAN=y
CONFIG_FSL_DPAA_ETH=y
CONFIG_FSL_DPAA2_ETH=y
CONFIG_FSL_DPAA2_MAC=y
CONFIG_FSL_DPAA2_SWITCH=y
CONFIG_FSL_ENETC=y
CONFIG_FSL_ENETC_VF=y
CONFIG_FSL_ENETC_QOS=y
CONFIG_ENETC_TSN=y
CONFIG_HIX5HD2_GMAC=y
CONFIG_HNS_DSAF=y
CONFIG_HNS_ENET=y
CONFIG_HNS3=y
CONFIG_HNS3_HCLGE=y
CONFIG_HNS3_ENET=y
CONFIG_E1000=y
CONFIG_E1000E=y
CONFIG_IGB=y
CONFIG_IGBVF=y
CONFIG_MVMDIO=y
CONFIG_SKY2=y
CONFIG_MLX4_EN=m
CONFIG_MLX5_CORE=m
CONFIG_MLX5_CORE_EN=y
CONFIG_MSCC_OCELOT_SWITCH=y
CONFIG_QCOM_EMAC=m
CONFIG_RMNET=m
CONFIG_SMC91X=y
CONFIG_SMSC911X=y
CONFIG_STMMAC_ETH=y
CONFIG_DWMAC_GENERIC=m
CONFIG_AQUANTIA_PHY=y
CONFIG_BROADCOM_PHY=m
CONFIG_BCM54140_PHY=m
CONFIG_INPHI_PHY=y
CONFIG_MARVELL_PHY=m
CONFIG_MARVELL_10G_PHY=m
CONFIG_MICREL_PHY=y
CONFIG_MICROSEMI_PHY=y
CONFIG_NXP_C45_TJA11XX_PHY=y
CONFIG_NXP_TJA11XX_PHY=y
CONFIG_AT803X_PHY=y
CONFIG_REALTEK_PHY=y
CONFIG_ROCKCHIP_PHY=y
CONFIG_VITESSE_PHY=y
CONFIG_CAN_FLEXCAN=m
CONFIG_MDIO_BITBANG=y
CONFIG_MDIO_BUS_MUX_MULTIPLEXER=y
CONFIG_MDIO_BUS_MUX_MMIOREG=y
CONFIG_USB_PEGASUS=m
CONFIG_USB_RTL8150=m
CONFIG_USB_RTL8152=y
CONFIG_USB_LAN78XX=m
CONFIG_USB_USBNET=y
CONFIG_USB_NET_AX8817X=m
CONFIG_USB_NET_AX88179_178A=m
CONFIG_USB_NET_CDCETHER=m
CONFIG_USB_NET_CDC_NCM=m
CONFIG_USB_NET_DM9601=m
CONFIG_USB_NET_SR9800=m
CONFIG_USB_NET_SMSC75XX=m
CONFIG_USB_NET_SMSC95XX=m
CONFIG_USB_NET_NET1080=m
CONFIG_USB_NET_PLUSB=m
CONFIG_USB_NET_MCS7830=m
CONFIG_USB_NET_CDC_SUBSET=m
CONFIG_USB_NET_ZAURUS=m
CONFIG_HOSTAP=y
CONFIG_WL18XX=m
CONFIG_WLCORE_SDIO=m
CONFIG_XEN_NETDEV_BACKEND=m
CONFIG_IVSHMEM_NET=y
CONFIG_INPUT_EVDEV=y
CONFIG_KEYBOARD_ADC=m
CONFIG_KEYBOARD_GPIO=y
CONFIG_KEYBOARD_RPMSG=y
CONFIG_KEYBOARD_SNVS_PWRKEY=y
CONFIG_KEYBOARD_BBNSM_PWRKEY=y
CONFIG_KEYBOARD_IMX_SC_KEY=y
CONFIG_KEYBOARD_CROS_EC=y
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_ATMEL_MXT=m
CONFIG_TOUCHSCREEN_EXC3000=m
CONFIG_TOUCHSCREEN_GOODIX=m
CONFIG_TOUCHSCREEN_EDT_FT5X06=m
CONFIG_TOUCHSCREEN_SYNAPTICS_DSX_I2C=m
CONFIG_INPUT_MISC=y
CONFIG_INPUT_PWM_BEEPER=m
CONFIG_INPUT_PWM_VIBRA=m
# CONFIG_SERIO_SERPORT is not set
CONFIG_SERIO_AMBAKMI=y
CONFIG_LEGACY_PTY_COUNT=16
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_EXTENDED=y
CONFIG_SERIAL_8250_SHARE_IRQ=y
CONFIG_SERIAL_8250_DW=y
CONFIG_SERIAL_OF_PLATFORM=y
CONFIG_SERIAL_AMBA_PL011=y
CONFIG_SERIAL_AMBA_PL011_CONSOLE=y
CONFIG_SERIAL_IMX=y
CONFIG_SERIAL_IMX_CONSOLE=y
CONFIG_SERIAL_XILINX_PS_UART=y
CONFIG_SERIAL_XILINX_PS_UART_CONSOLE=y
CONFIG_SERIAL_FSL_LPUART=y
CONFIG_SERIAL_FSL_LPUART_CONSOLE=y
CONFIG_SERIAL_FSL_LINFLEXUART=y
CONFIG_SERIAL_FSL_LINFLEXUART_CONSOLE=y
CONFIG_SERIAL_DEV_BUS=y
CONFIG_VIRTIO_CONSOLE=y
CONFIG_IPMI_HANDLER=m
CONFIG_IPMI_DEVICE_INTERFACE=m
CONFIG_IPMI_SI=m
CONFIG_TCG_TPM=y
CONFIG_TCG_TIS_I2C_INFINEON=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_MUX=y
CONFIG_I2C_MUX_PCA954x=y
CONFIG_I2C_DESIGNWARE_PLATFORM=y
CONFIG_I2C_GPIO=m
CONFIG_I2C_IMX=y
CONFIG_I2C_IMX_LPI2C=y
CONFIG_I2C_IMX_FLEXIO=y
CONFIG_I2C_RK3X=y
CONFIG_I2C_RPBUS=y
CONFIG_I2C_CROS_EC_TUNNEL=y
CONFIG_I2C_SLAVE_EEPROM=y
CONFIG_I3C=y
CONFIG_SVC_I3C_MASTER=y
CONFIG_SPI=y
CONFIG_SPI_CADENCE_QUADSPI=y
CONFIG_SPI_DESIGNWARE=m
CONFIG_SPI_DW_DMA=y
CONFIG_SPI_DW_MMIO=m
CONFIG_SPI_FSL_LPSPI=y
CONFIG_SPI_FSL_QUADSPI=y
CONFIG_SPI_NXP_FLEXSPI=y
CONFIG_SPI_IMX=y
CONFIG_SPI_FSL_DSPI=y
CONFIG_SPI_PL022=y
CONFIG_SPI_ROCKCHIP=y
CONFIG_SPI_SPIDEV=y
CONFIG_SPI_SLAVE=y
CONFIG_SPI_SLAVE_TIME=y
CONFIG_SPI_SLAVE_SYSTEM_CONTROL=y
CONFIG_SPMI=y
CONFIG_PPS_CLIENT_GPIO=y
CONFIG_PINCTRL_MAX77620=y
CONFIG_PINCTRL_SINGLE=y
CONFIG_PINCTRL_IMX8MM=y
CONFIG_PINCTRL_IMX8MN=y
CONFIG_PINCTRL_IMX8MP=y
CONFIG_PINCTRL_IMX8MQ=y
CONFIG_PINCTRL_IMX8QM=y
CONFIG_PINCTRL_IMX8QXP=y
CONFIG_PINCTRL_IMX8DXL=y
CONFIG_PINCTRL_IMX8ULP=y
CONFIG_PINCTRL_IMX93=y
CONFIG_PINCTRL_S32V234=y
CONFIG_GPIO_ALTERA=m
CONFIG_GPIO_DWAPB=y
CONFIG_GPIO_IMX_RPMSG=y
CONFIG_GPIO_MB86S7X=y
CONFIG_GPIO_MPC8XXX=y
CONFIG_GPIO_MXC=y
CONFIG_GPIO_PL061=y
CONFIG_GPIO_WCD934X=m
CONFIG_GPIO_XGENE=y
CONFIG_GPIO_MAX732X=y
CONFIG_GPIO_PCA953X=y
CONFIG_GPIO_PCA953X_IRQ=y
CONFIG_GPIO_ADP5585=y
CONFIG_GPIO_BD9571MWV=m
CONFIG_GPIO_MAX77620=y
CONFIG_GPIO_SL28CPLD=m
CONFIG_POWER_RESET_BRCMSTB=y
CONFIG_POWER_RESET_XGENE=y
CONFIG_POWER_RESET_SYSCON=y
CONFIG_SYSCON_REBOOT_MODE=y
CONFIG_BATTERY_SBS=m
CONFIG_BATTERY_BQ27XXX=y
CONFIG_BATTERY_MAX17042=m
CONFIG_CHARGER_BQ25890=m
CONFIG_CHARGER_BQ25980=m
CONFIG_SENSORS_ARM_SCMI=y
CONFIG_SENSORS_ARM_SCPI=y
CONFIG_SENSORS_FP9931=y
CONFIG_SENSORS_LM90=m
CONFIG_SENSORS_PWM_FAN=m
CONFIG_SENSORS_SL28CPLD=m
CONFIG_SENSORS_INA2XX=m
CONFIG_SENSORS_INA3221=m
CONFIG_THERMAL_WRITABLE_TRIPS=y
CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y
CONFIG_CPU_THERMAL=y
CONFIG_THERMAL_EMULATION=y
CONFIG_IMX_SC_THERMAL=y
CONFIG_IMX8MM_THERMAL=y
CONFIG_DEVICE_THERMAL=y
CONFIG_QORIQ_THERMAL=y
CONFIG_WATCHDOG=y
CONFIG_SL28CPLD_WATCHDOG=m
CONFIG_ARM_SP805_WATCHDOG=y
CONFIG_ARM_SBSA_WATCHDOG=y
CONFIG_DW_WATCHDOG=y
CONFIG_IMX2_WDT=y
CONFIG_IMX_SC_WDT=y
CONFIG_IMX7ULP_WDT=y
CONFIG_ARM_SMC_WATCHDOG=y
CONFIG_XEN_WDT=y
CONFIG_MFD_ADP5585=y
CONFIG_MFD_BD9571MWV=y
CONFIG_MFD_AXP20X_I2C=y
CONFIG_MFD_IMX_FLEXIO=y
CONFIG_MFD_HI6421_PMIC=y
CONFIG_MFD_FP9931=y
CONFIG_MFD_MAX77620=y
CONFIG_MFD_MT6397=y
CONFIG_MFD_RK808=y
CONFIG_MFD_SEC_CORE=y
CONFIG_MFD_SL28CPLD=y
CONFIG_MFD_ROHM_BD718XX=y
CONFIG_MFD_WCD934X=m
CONFIG_REGULATOR_FIXED_VOLTAGE=y
CONFIG_REGULATOR_AXP20X=y
CONFIG_REGULATOR_BD718XX=y
CONFIG_REGULATOR_BD9571MWV=y
CONFIG_REGULATOR_FAN53555=y
CONFIG_REGULATOR_GPIO=y
CONFIG_REGULATOR_HI6421V530=y
CONFIG_REGULATOR_MAX77620=y
CONFIG_REGULATOR_MAX8973=y
CONFIG_REGULATOR_FP9931=y
CONFIG_REGULATOR_MP8859=y
CONFIG_REGULATOR_MT6358=y
CONFIG_REGULATOR_MT6397=y
CONFIG_REGULATOR_PCA9450=y
CONFIG_REGULATOR_PF8X00=y
CONFIG_REGULATOR_PFUZE100=y
CONFIG_REGULATOR_PWM=y
CONFIG_REGULATOR_QCOM_SPMI=y
CONFIG_REGULATOR_RK808=y
CONFIG_REGULATOR_S2MPS11=y
CONFIG_REGULATOR_TPS65132=m
CONFIG_REGULATOR_VCTRL=m
CONFIG_RC_CORE=m
CONFIG_RC_DECODERS=y
CONFIG_IR_IMON_DECODER=m
CONFIG_IR_JVC_DECODER=m
CONFIG_IR_MCE_KBD_DECODER=m
CONFIG_IR_NEC_DECODER=m
CONFIG_IR_RC5_DECODER=m
CONFIG_IR_RC6_DECODER=m
CONFIG_IR_RCMM_DECODER=m
CONFIG_IR_SANYO_DECODER=m
CONFIG_IR_SHARP_DECODER=m
CONFIG_IR_SONY_DECODER=m
CONFIG_IR_XMP_DECODER=m
CONFIG_RC_DEVICES=y
CONFIG_IR_GPIO_CIR=m
CONFIG_MEDIA_SUPPORT=y
CONFIG_MEDIA_CAMERA_SUPPORT=y
CONFIG_MEDIA_ANALOG_TV_SUPPORT=y
CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y
CONFIG_MEDIA_SDR_SUPPORT=y
CONFIG_MEDIA_PLATFORM_SUPPORT=y
# CONFIG_DVB_NET is not set
CONFIG_MEDIA_USB_SUPPORT=y
CONFIG_USB_VIDEO_CLASS=m
CONFIG_V4L_PLATFORM_DRIVERS=y
CONFIG_SDR_PLATFORM_DRIVERS=y
CONFIG_V4L_MEM2MEM_DRIVERS=y
CONFIG_VIDEO_MX8_CAPTURE=y
CONFIG_VIDEO_MXC_CAPTURE=y
CONFIG_VIDEO_MXC_CSI_CAMERA=y
CONFIG_MXC_MIPI_CSI=y
CONFIG_MXC_CAMERA_OV5640_MIPI_V2=y
CONFIG_VIDEO_AMPHION_VPU=y
CONFIG_VIDEO_IMX8_JPEG=m
CONFIG_VIDEO_HANTRO=m
CONFIG_VIDEO_IMX219=m
CONFIG_VIDEO_OV5640=y
CONFIG_VIDEO_OV5645=m
CONFIG_VIDEO_AP1302=y
CONFIG_VIDEO_MT9M114=y
CONFIG_IMX_DPU_CORE=y
CONFIG_IMX8MM_LCDIF_CORE=y
CONFIG_IMX_LCDIFV3_CORE=y
CONFIG_DRM=y
CONFIG_DRM_I2C_NXP_TDA998X=m
CONFIG_DRM_MALI_DISPLAY=m
CONFIG_DRM_NOUVEAU=m
CONFIG_DRM_RCAR_DW_HDMI=m
CONFIG_DRM_PANEL_BOE_TV101WUM_NL6=m
CONFIG_DRM_PANEL_LVDS=m
CONFIG_DRM_PANEL_SIMPLE=y
CONFIG_DRM_PANEL_MANTIX_MLAF057WE51=m
CONFIG_DRM_PANEL_ONTAT_KD50G21_40NT_A1=y
CONFIG_DRM_PANEL_RAYDIUM_RM67191=y
CONFIG_DRM_PANEL_RAYDIUM_RM68200=y
CONFIG_DRM_PANEL_ROCKTECK_HIMAX8394F=y
CONFIG_DRM_PANEL_SEIKO_43WVF1G=y
CONFIG_DRM_PANEL_SITRONIX_ST7703=m
CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA=m
CONFIG_DRM_PANEL_WKS_101WX001=y
CONFIG_DRM_DISPLAY_CONNECTOR=m
CONFIG_DRM_LONTIUM_LT8912B=m
CONFIG_DRM_LONTIUM_LT9611=m
CONFIG_DRM_LONTIUM_LT9611UXC=m
CONFIG_DRM_FSL_IMX_LVDS_BRIDGE=y
CONFIG_DRM_NWL_MIPI_DSI=y
CONFIG_DRM_NXP_SEIKO_43WVFIG=y
CONFIG_DRM_PARADE_PS8640=m
CONFIG_DRM_SII902X=m
CONFIG_DRM_SIMPLE_BRIDGE=m
CONFIG_DRM_THINE_THC63LVD1024=m
CONFIG_DRM_TI_SN65DSI86=m
CONFIG_DRM_I2C_ADV7511=y
CONFIG_DRM_I2C_ADV7511_AUDIO=y
CONFIG_DRM_DW_HDMI_AHB_AUDIO=m
CONFIG_DRM_DW_HDMI_I2S_AUDIO=m
CONFIG_DRM_DW_HDMI_GP_AUDIO=y
CONFIG_DRM_DW_HDMI_CEC=m
CONFIG_DRM_ITE_IT6263=y
CONFIG_DRM_ITE_IT6161=y
CONFIG_DRM_IMX=y
CONFIG_DRM_IMX_LCDIF_MUX_DISPLAY=y
CONFIG_DRM_IMX_PARALLEL_DISPLAY=y
CONFIG_DRM_IMX_TVE=y
CONFIG_DRM_IMX_LDB=y
CONFIG_DRM_IMX8QM_LDB=y
CONFIG_DRM_IMX8QXP_LDB=y
CONFIG_DRM_IMX8MP_LDB=y
CONFIG_DRM_IMX93_LDB=y
CONFIG_DRM_IMX_DW_MIPI_DSI=y
CONFIG_DRM_IMX93_PARALLEL_DISPLAY_FORMAT=y
CONFIG_DRM_IMX_HDMI=y
CONFIG_DRM_IMX_SEC_DSIM=y
CONFIG_DRM_IMX_DCNANO=y
CONFIG_DRM_IMX_DCSS=y
CONFIG_DRM_IMX_CDNS_MHDP=y
CONFIG_DRM_ETNAVIV=m
CONFIG_DRM_HISI_HIBMC=m
CONFIG_DRM_HISI_KIRIN=m
CONFIG_DRM_MXSFB=y
CONFIG_DRM_PL111=m
CONFIG_DRM_LIMA=m
CONFIG_DRM_PANFROST=m
CONFIG_FB=y
CONFIG_FB_ARMCLCD=y
CONFIG_FB_EFI=y
CONFIG_FB_MXC_EINK_V2_PANEL=y
CONFIG_BACKLIGHT_PWM=y
CONFIG_BACKLIGHT_LP855X=m
CONFIG_LOGO=y
# CONFIG_LOGO_LINUX_MONO is not set
# CONFIG_LOGO_LINUX_VGA16 is not set
CONFIG_SOUND=y
CONFIG_SND=y
CONFIG_SND_ALOOP=m
CONFIG_SND_USB_AUDIO=m
CONFIG_SND_SOC=y
CONFIG_SND_SOC_FSL_ASRC=m
CONFIG_SND_SOC_FSL_MQS=m
CONFIG_SND_SOC_FSL_MICFIL=m
CONFIG_SND_SOC_FSL_EASRC=m
CONFIG_SND_SOC_FSL_XCVR=m
CONFIG_SND_SOC_FSL_ESAI_CLIENT=y
CONFIG_SND_SOC_FSL_RPMSG=m
CONFIG_SND_IMX_SOC=m
CONFIG_SND_SOC_IMX_SGTL5000=m
CONFIG_SND_SOC_IMX_SPDIF=m
CONFIG_SND_SOC_FSL_ASOC_CARD=m
CONFIG_SND_SOC_IMX_AUDMIX=m
CONFIG_SND_SOC_IMX_HDMI=m
CONFIG_SND_SOC_IMX_CARD=m
CONFIG_SND_SOC_IMX_PCM512X=m
CONFIG_SND_SOC_SOF_TOPLEVEL=y
CONFIG_SND_SOC_SOF_OF=m
CONFIG_SND_SOC_SOF_IMX_TOPLEVEL=y
CONFIG_SND_SOC_SOF_IMX8=m
CONFIG_SND_SOC_SOF_IMX8M=m
CONFIG_SND_SOC_SOF_IMX8ULP=m
CONFIG_SND_SOC_AK4613=m
CONFIG_SND_SOC_BT_SCO=y
CONFIG_SND_SOC_CROS_EC_CODEC=m
CONFIG_SND_SOC_CS42XX8_I2C=y
CONFIG_SND_SOC_DMIC=m
CONFIG_SND_SOC_ES7134=m
CONFIG_SND_SOC_ES7241=m
CONFIG_SND_SOC_GTM601=m
CONFIG_SND_SOC_MAX98357A=m
CONFIG_SND_SOC_MAX98927=m
CONFIG_SND_SOC_MSM8916_WCD_ANALOG=m
CONFIG_SND_SOC_MSM8916_WCD_DIGITAL=m
CONFIG_SND_SOC_PCM3168A_I2C=m
CONFIG_SND_SOC_RT5659=m
CONFIG_SND_SOC_SIMPLE_AMPLIFIER=m
CONFIG_SND_SOC_SIMPLE_MUX=m
CONFIG_SND_SOC_SPDIF=m
CONFIG_SND_SOC_TAS571X=m
CONFIG_SND_SOC_WCD934X=m
CONFIG_SND_SOC_WM8524=y
CONFIG_SND_SOC_WM8904=m
CONFIG_SND_SOC_WM8960=m
CONFIG_SND_SOC_WM8962=m
CONFIG_SND_SOC_WSA881X=m
CONFIG_SND_SOC_RPMSG_WM8960=m
CONFIG_SND_SOC_RPMSG_AK4497=m
CONFIG_SND_SOC_LPASS_WSA_MACRO=m
CONFIG_SND_SOC_LPASS_VA_MACRO=m
CONFIG_SND_SIMPLE_CARD=y
CONFIG_SND_AUDIO_GRAPH_CARD=y
CONFIG_HID_MULTITOUCH=m
CONFIG_I2C_HID_ACPI=m
CONFIG_I2C_HID_OF=m
CONFIG_USB_CONN_GPIO=y
CONFIG_USB=y
CONFIG_USB_OTG=y
CONFIG_USB_XHCI_HCD=y
CONFIG_USB_XHCI_PCI_RENESAS=m
CONFIG_USB_EHCI_HCD=y
CONFIG_USB_EHCI_HCD_PLATFORM=y
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_OHCI_HCD_PLATFORM=y
CONFIG_USB_HCD_TEST_MODE=y
CONFIG_USB_ACM=m
CONFIG_USB_STORAGE=y
CONFIG_USB_UAS=y
CONFIG_USB_CDNS_SUPPORT=y
CONFIG_USB_CDNS3=y
CONFIG_USB_CDNS3_GADGET=y
CONFIG_USB_CDNS3_HOST=y
CONFIG_USB_MUSB_HDRC=y
CONFIG_USB_DWC3=y
CONFIG_USB_DWC2=y
CONFIG_USB_CHIPIDEA=y
CONFIG_USB_CHIPIDEA_UDC=y
CONFIG_USB_CHIPIDEA_HOST=y
CONFIG_USB_ISP1760=y
CONFIG_USB_SERIAL=y
CONFIG_USB_SERIAL_CONSOLE=y
CONFIG_USB_SERIAL_GENERIC=y
CONFIG_USB_SERIAL_SIMPLE=y
CONFIG_USB_SERIAL_CP210X=m
CONFIG_USB_SERIAL_FTDI_SIO=y
CONFIG_USB_SERIAL_OPTION=m
CONFIG_USB_TEST=m
CONFIG_USB_EHSET_TEST_FIXTURE=y
CONFIG_USB_HSIC_USB3503=y
CONFIG_NOP_USB_XCEIV=y
CONFIG_USB_MXS_PHY=y
CONFIG_USB_ULPI=y
CONFIG_USB_GADGET=y
CONFIG_USB_SNP_UDC_PLAT=y
CONFIG_USB_BDC_UDC=y
CONFIG_USB_CONFIGFS=y
CONFIG_USB_CONFIGFS_SERIAL=y
CONFIG_USB_CONFIGFS_ACM=y
CONFIG_USB_CONFIGFS_OBEX=y
CONFIG_USB_CONFIGFS_NCM=y
CONFIG_USB_CONFIGFS_ECM=y
CONFIG_USB_CONFIGFS_ECM_SUBSET=y
CONFIG_USB_CONFIGFS_RNDIS=y
CONFIG_USB_CONFIGFS_EEM=y
CONFIG_USB_CONFIGFS_MASS_STORAGE=y
CONFIG_USB_CONFIGFS_F_LB_SS=y
CONFIG_USB_CONFIGFS_F_FS=y
CONFIG_USB_CONFIGFS_F_UAC1=y
CONFIG_USB_CONFIGFS_F_UAC1_LEGACY=y
CONFIG_USB_CONFIGFS_F_UAC2=y
CONFIG_USB_CONFIGFS_F_MIDI=y
CONFIG_USB_CONFIGFS_F_HID=y
CONFIG_USB_CONFIGFS_F_UVC=y
CONFIG_USB_ZERO=m
CONFIG_USB_AUDIO=m
CONFIG_USB_ETH=m
CONFIG_USB_MASS_STORAGE=m
CONFIG_USB_G_SERIAL=m
CONFIG_TYPEC=y
CONFIG_TYPEC_TCPM=y
CONFIG_TYPEC_TCPCI=y
CONFIG_TYPEC_FUSB302=m
CONFIG_TYPEC_TPS6598X=m
CONFIG_TYPEC_HD3SS3220=m
CONFIG_TYPEC_SWITCH_GPIO=y
CONFIG_MMC=y
CONFIG_MMC_BLOCK_MINORS=32
CONFIG_MMC_ARMMMCI=y
CONFIG_MMC_SDHCI=y
CONFIG_MMC_SDHCI_ACPI=y
CONFIG_MMC_SDHCI_PLTFM=y
CONFIG_MMC_SDHCI_OF_ARASAN=y
CONFIG_MMC_SDHCI_OF_ESDHC=y
CONFIG_MMC_SDHCI_CADENCE=y
CONFIG_MMC_SDHCI_ESDHC_IMX=y
CONFIG_MMC_SDHCI_F_SDH30=y
CONFIG_MMC_SPI=y
CONFIG_MMC_DW=y
CONFIG_MMC_DW_EXYNOS=y
CONFIG_MMC_DW_HI3798CV200=y
CONFIG_MMC_DW_K3=y
CONFIG_MMC_MTK=y
CONFIG_MMC_SDHCI_XENON=y
CONFIG_MMC_SDHCI_AM654=y
CONFIG_SCSI_UFSHCD=y
CONFIG_SCSI_UFSHCD_PLATFORM=y
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
CONFIG_LEDS_CLASS_MULTICOLOR=m
CONFIG_LEDS_LM3692X=m
CONFIG_LEDS_PCA9532=m
CONFIG_LEDS_GPIO=y
CONFIG_LEDS_PCA995X=m
CONFIG_LEDS_PWM=y
CONFIG_LEDS_SYSCON=y
CONFIG_LEDS_TRIGGER_TIMER=y
CONFIG_LEDS_TRIGGER_DISK=y
CONFIG_LEDS_TRIGGER_HEARTBEAT=y
CONFIG_LEDS_TRIGGER_CPU=y
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
CONFIG_LEDS_TRIGGER_PANIC=y
CONFIG_EDAC=y
CONFIG_EDAC_GHES=y
CONFIG_EDAC_LAYERSCAPE=m
CONFIG_EDAC_SYNOPSYS=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_DRV_DS1307=m
CONFIG_RTC_DRV_HYM8563=m
CONFIG_RTC_DRV_MAX77686=y
CONFIG_RTC_DRV_RK808=m
CONFIG_RTC_DRV_PCF85363=m
CONFIG_RTC_DRV_M41T80=m
CONFIG_RTC_DRV_RX8581=m
CONFIG_RTC_DRV_RV3028=m
CONFIG_RTC_DRV_RV8803=m
CONFIG_RTC_DRV_S5M=y
CONFIG_RTC_DRV_DS3232=y
CONFIG_RTC_DRV_PCF2127=m
CONFIG_RTC_DRV_PCF2131=m
CONFIG_RTC_DRV_EFI=y
CONFIG_RTC_DRV_CROS_EC=y
CONFIG_RTC_DRV_FSL_FTM_ALARM=m
CONFIG_RTC_DRV_PL031=y
CONFIG_RTC_DRV_SNVS=y
CONFIG_RTC_DRV_BBNSM=y
CONFIG_RTC_DRV_IMX_SC=y
CONFIG_RTC_DRV_IMX_RPMSG=y
CONFIG_DMADEVICES=y
CONFIG_BCM_SBA_RAID=m
CONFIG_FSL_EDMA=y
CONFIG_FSL_QDMA=m
CONFIG_FSL_EDMA_V3=y
CONFIG_IMX_SDMA=y
CONFIG_MV_XOR_V2=y
CONFIG_MXS_DMA=y
CONFIG_MXC_PXP_V3=y
CONFIG_PL330_DMA=y
CONFIG_QCOM_HIDMA_MGMT=y
CONFIG_QCOM_HIDMA=y
CONFIG_DW_EDMA=y
CONFIG_DW_EDMA_PCIE=y
CONFIG_FSL_DPAA2_QDMA=m
CONFIG_DMATEST=y
CONFIG_DMABUF_HEAPS=y
CONFIG_DMABUF_HEAPS_SYSTEM=y
CONFIG_DMABUF_HEAPS_CMA=y
CONFIG_DMABUF_HEAPS_DSP=y
CONFIG_UIO_PCI_GENERIC=y
CONFIG_UIO_IVSHMEM=y
CONFIG_VFIO=y
CONFIG_VFIO_PCI=y
CONFIG_VFIO_FSL_MC=y
CONFIG_VIRTIO_PCI=y
CONFIG_VIRTIO_BALLOON=y
CONFIG_VIRTIO_MMIO=y
CONFIG_VIRTIO_IVSHMEM=y
CONFIG_XEN_GNTDEV=y
CONFIG_XEN_GRANT_DEV_ALLOC=y
CONFIG_STAGING=y
CONFIG_STAGING_MEDIA=y
CONFIG_VIDEO_IMX_CAPTURE=y
CONFIG_IMX8_MEDIA_DEVICE=m
CONFIG_MHDP_HDMIRX=y
CONFIG_MHDP_HDMIRX_CEC=y
CONFIG_FSL_DPAA2=y
CONFIG_FSL_PPFE=y
CONFIG_FSL_PPFE_UTIL_DISABLED=y
CONFIG_ETHOSU=y
CONFIG_CHROME_PLATFORMS=y
CONFIG_CROS_EC=y
CONFIG_CROS_EC_I2C=y
CONFIG_CROS_EC_SPI=y
CONFIG_CROS_EC_CHARDEV=m
CONFIG_CLK_VEXPRESS_OSC=y
CONFIG_COMMON_CLK_RK808=y
CONFIG_COMMON_CLK_SCMI=y
CONFIG_COMMON_CLK_SCPI=y
CONFIG_COMMON_CLK_CS2000_CP=y
CONFIG_COMMON_CLK_FSL_SAI=y
CONFIG_COMMON_CLK_S2MPS11=y
CONFIG_COMMON_CLK_XGENE=y
CONFIG_COMMON_CLK_PWM=y
CONFIG_COMMON_CLK_VC5=y
CONFIG_CLK_IMX8MM=y
CONFIG_CLK_IMX8MN=y
CONFIG_CLK_IMX8MP=y
CONFIG_CLK_IMX8MQ=y
CONFIG_CLK_IMX8QXP=y
CONFIG_CLK_IMX8ULP=y
CONFIG_CLK_IMX93=y
CONFIG_HWSPINLOCK=y
CONFIG_ARM_MHU=y
CONFIG_IMX_MBOX=y
CONFIG_PLATFORM_MHU=y
CONFIG_IOMMU_IO_PGTABLE_ARMV7S=y
CONFIG_ARM_SMMU=y
CONFIG_ARM_SMMU_V3=y
CONFIG_REMOTEPROC=y
CONFIG_IMX_REMOTEPROC=y
CONFIG_IMX_DSP_REMOTEPROC=m
CONFIG_RPMSG_CHAR=m
CONFIG_RPMSG_CTRL=m
CONFIG_RPMSG_QCOM_GLINK_RPM=y
CONFIG_SOUNDWIRE=m
CONFIG_SOUNDWIRE_QCOM=m
CONFIG_SOC_BRCMSTB=y
CONFIG_FSL_DPAA=y
CONFIG_FSL_MC_DPIO=y
CONFIG_FSL_RCPM=y
CONFIG_FSL_QIXIS=y
CONFIG_SOC_TI=y
CONFIG_EXTCON_PTN5150=m
CONFIG_EXTCON_USB_GPIO=y
CONFIG_EXTCON_USBC_CROS_EC=y
CONFIG_IIO=y
CONFIG_FXLS8962AF_I2C=m
CONFIG_IMX8QXP_ADC=y
CONFIG_IMX93_ADC=y
CONFIG_MAX9611=m
CONFIG_QCOM_SPMI_VADC=m
CONFIG_QCOM_SPMI_ADC5=m
CONFIG_IIO_CROS_EC_SENSORS_CORE=m
CONFIG_IIO_CROS_EC_SENSORS=m
CONFIG_FXAS21002C=y
CONFIG_FXOS8700_I2C=y
CONFIG_RPMSG_IIO_PEDOMETER=m
CONFIG_IIO_ST_LSM6DSX=y
CONFIG_IIO_CROS_EC_LIGHT_PROX=m
CONFIG_SENSORS_ISL29018=y
CONFIG_VCNL4000=m
CONFIG_IIO_ST_MAGN_3AXIS=m
CONFIG_IIO_CROS_EC_BARO=m
CONFIG_MPL3115=y
CONFIG_PWM=y
CONFIG_PWM_ADP5585=y
CONFIG_PWM_CROS_EC=m
CONFIG_PWM_FSL_FTM=m
CONFIG_PWM_IMX27=y
CONFIG_PWM_RPCHIP=y
CONFIG_PWM_SL28CPLD=m
CONFIG_SL28CPLD_INTC=y
CONFIG_RESET_IMX7=y
CONFIG_RESET_IMX8ULP_SIM=y
CONFIG_PHY_XGENE=y
CONFIG_PHY_MIXEL_LVDS=y
CONFIG_PHY_MIXEL_LVDS_COMBO=y
CONFIG_PHY_CADENCE_SALVO=y
CONFIG_PHY_FSL_IMX8MP_LVDS=y
CONFIG_PHY_FSL_IMX93_MIPI_DPHY=y
CONFIG_PHY_MIXEL_MIPI_DPHY=y
CONFIG_PHY_FSL_IMX8M_PCIE=y
CONFIG_PHY_FSL_IMX8Q_PCIE=y
CONFIG_PHY_SAMSUNG_HDMI_PHY=y
CONFIG_PHY_QCOM_USB_HS=y
CONFIG_PHY_SAMSUNG_USB2=y
CONFIG_ARM_CCI_PMU=m
CONFIG_ARM_CCN=m
CONFIG_ARM_CMN=m
CONFIG_ARM_SMMU_V3_PMU=m
CONFIG_ARM_DSU_PMU=m
CONFIG_FSL_IMX8_DDR_PMU=y
CONFIG_FSL_IMX9_DDR_PMU=y
CONFIG_ARM_SPE_PMU=m
CONFIG_ARM_DMC620_PMU=m
CONFIG_HISI_PMU=y
CONFIG_NVMEM_IMX_OCOTP=y
CONFIG_NVMEM_IMX_OCOTP_SCU=y
CONFIG_NVMEM_RMEM=m
CONFIG_FPGA=y
CONFIG_FPGA_BRIDGE=m
CONFIG_ALTERA_FREEZE_BRIDGE=m
CONFIG_FPGA_REGION=m
CONFIG_OF_FPGA_REGION=m
CONFIG_TEE=y
CONFIG_OPTEE=y
CONFIG_MUX_MMIO=y
CONFIG_SLIM_QCOM_CTRL=m
CONFIG_MXC_SIM=y
CONFIG_MXC_GPU_VIV=y
CONFIG_MXC_EMVSIM=y
CONFIG_EXT2_FS=y
CONFIG_EXT3_FS=y
CONFIG_EXT4_FS_POSIX_ACL=y
CONFIG_BTRFS_FS=m
CONFIG_BTRFS_FS_POSIX_ACL=y
CONFIG_FANOTIFY=y
CONFIG_FANOTIFY_ACCESS_PERMISSIONS=y
CONFIG_QUOTA=y
CONFIG_AUTOFS4_FS=y
CONFIG_FUSE_FS=m
CONFIG_CUSE=m
CONFIG_OVERLAY_FS=m
CONFIG_VFAT_FS=y
CONFIG_TMPFS_POSIX_ACL=y
CONFIG_HUGETLBFS=y
CONFIG_EFIVAR_FS=y
CONFIG_JFFS2_FS=y
CONFIG_UBIFS_FS=y
CONFIG_SQUASHFS=y
CONFIG_SQUASHFS_XZ=y
CONFIG_NFS_FS=y
CONFIG_NFS_V4=y
CONFIG_NFS_V4_1=y
CONFIG_NFS_V4_2=y
CONFIG_ROOT_NFS=y
CONFIG_9P_FS=y
CONFIG_NLS_CODEPAGE_437=y
CONFIG_NLS_ISO8859_1=y
CONFIG_TRUSTED_KEYS=m
# CONFIG_TRUSTED_KEYS_TPM is not set
# CONFIG_TRUSTED_KEYS_TEE is not set
CONFIG_SECURITY=y
CONFIG_CRYPTO_USER=y
CONFIG_CRYPTO_TEST=m
CONFIG_CRYPTO_ANUBIS=m
CONFIG_CRYPTO_ARIA=m
CONFIG_CRYPTO_BLOWFISH=m
CONFIG_CRYPTO_CAMELLIA=m
CONFIG_CRYPTO_CAST5=m
CONFIG_CRYPTO_CAST6=m
CONFIG_CRYPTO_FCRYPT=m
CONFIG_CRYPTO_KHAZAD=m
CONFIG_CRYPTO_SEED=m
CONFIG_CRYPTO_SERPENT=m
CONFIG_CRYPTO_TEA=m
CONFIG_CRYPTO_TWOFISH=m
CONFIG_CRYPTO_ARC4=m
CONFIG_CRYPTO_CFB=m
CONFIG_CRYPTO_CTS=m
CONFIG_CRYPTO_LRW=m
CONFIG_CRYPTO_OFB=m
CONFIG_CRYPTO_PCBC=m
CONFIG_CRYPTO_CHACHA20POLY1305=m
CONFIG_CRYPTO_ECHAINIV=y
CONFIG_CRYPTO_TLS=m
CONFIG_CRYPTO_MD4=m
CONFIG_CRYPTO_RMD160=m
CONFIG_CRYPTO_STREEBOG=m
CONFIG_CRYPTO_VMAC=m
CONFIG_CRYPTO_WP512=m
CONFIG_CRYPTO_XCBC=m
CONFIG_CRYPTO_ANSI_CPRNG=y
CONFIG_CRYPTO_USER_API_HASH=m
CONFIG_CRYPTO_USER_API_SKCIPHER=m
CONFIG_CRYPTO_USER_API_RNG=m
CONFIG_CRYPTO_USER_API_AEAD=m
CONFIG_CRYPTO_CHACHA20_NEON=m
CONFIG_CRYPTO_GHASH_ARM64_CE=y
CONFIG_CRYPTO_SHA1_ARM64_CE=y
CONFIG_CRYPTO_SHA2_ARM64_CE=y
CONFIG_CRYPTO_SHA512_ARM64_CE=m
CONFIG_CRYPTO_SHA3_ARM64=m
CONFIG_CRYPTO_SM3_ARM64_CE=m
CONFIG_CRYPTO_POLYVAL_ARM64_CE=m
CONFIG_CRYPTO_AES_ARM64_CE_BLK=y
CONFIG_CRYPTO_AES_ARM64_BS=m
CONFIG_CRYPTO_AES_ARM64_CE_CCM=y
CONFIG_CRYPTO_CRCT10DIF_ARM64_CE=m
CONFIG_CRYPTO_DEV_FSL_CAAM_SECVIO=m
CONFIG_CRYPTO_DEV_FSL_CAAM=m
CONFIG_CRYPTO_DEV_FSL_CAAM_SM_TEST=m
CONFIG_CRYPTO_DEV_FSL_DPAA2_CAAM=m
CONFIG_CRYPTO_DEV_CCREE=m
CONFIG_CRYPTO_DEV_HISI_SEC2=m
CONFIG_CRYPTO_DEV_HISI_ZIP=m
CONFIG_CRYPTO_DEV_HISI_HPRE=m
CONFIG_CRYPTO_DEV_HISI_TRNG=m
CONFIG_CRYPTO_DEV_AMLOGIC_GXL=m
CONFIG_INDIRECT_PIO=y
CONFIG_CRC_CCITT=m
CONFIG_CRC8=y
CONFIG_CMA_SIZE_MBYTES=32
CONFIG_PRINTK_TIME=y
CONFIG_DEBUG_KERNEL=y
CONFIG_DEBUG_INFO_DWARF_TOOLCHAIN_DEFAULT=y
CONFIG_DEBUG_INFO_REDUCED=y
CONFIG_MAGIC_SYSRQ=y
CONFIG_DEBUG_FS=y
# CONFIG_SCHED_DEBUG is not set
# CONFIG_DEBUG_PREEMPT is not set
# CONFIG_FTRACE is not set
CONFIG_CORESIGHT=y
CONFIG_CORESIGHT_LINK_AND_SINK_TMC=y
CONFIG_CORESIGHT_CATU=m
CONFIG_CORESIGHT_SINK_TPIU=m
CONFIG_CORESIGHT_SINK_ETBV10=m
CONFIG_CORESIGHT_SOURCE_ETM4X=y
CONFIG_CORESIGHT_STM=m
CONFIG_CORESIGHT_CPU_DEBUG=m
CONFIG_CORESIGHT_CTI=m
CONFIG_MEMTEST=y
joanxie
as I mentioned before, you need add it, or enable it in the menuconfig
dskim2
I added as like below but still no /sys/class/gpio folder
CONFIG_SYSVIPC=y
CONFIG_AUDIT=y
CONFIG_NO_HZ_IDLE=y
CONFIG_BPF_JIT=y
CONFIG_PREEMPT=y
CONFIG_TASKSTATS=y
CONFIG_TASK_XACCT=y
CONFIG_IKCONFIG=y
CONFIG_MEMCG=y
CONFIG_BLK_CGROUP=y
CONFIG_CPUSETS=y
CONFIG_CGROUP_BPF=y
CONFIG_USER_NS=y
CONFIG_RELAY=y
CONFIG_PROFILING=y
CONFIG_ARCH_NXP=y
CONFIG_ARCH_MXC=y
CONFIG_ARCH_S32=y
CONFIG_SCHED_MC=y
CONFIG_SCHED_SMT=y
CONFIG_NUMA=y
CONFIG_KEXEC=y
CONFIG_KEXEC_FILE=y
CONFIG_CRASH_DUMP=y
CONFIG_XEN=y
CONFIG_COMPAT=y
CONFIG_PM_DEBUG=y
CONFIG_CPU_FREQ=y
CONFIG_CPUFREQ_DT=y
CONFIG_ACPI=y
CONFIG_ACPI_APEI=y
CONFIG_KVM=y
CONFIG_JUMP_LABEL=y
CONFIG_MODULES=y
CONFIG_KSM=y
CONFIG_NET=y
CONFIG_PACKET=y
CONFIG_UNIX=y
CONFIG_TLS=y
CONFIG_TLS_DEVICE=y
CONFIG_INET=y
CONFIG_IP_PNP=y
CONFIG_IPV6_SIT=m
CONFIG_NETFILTER=y
CONFIG_NF_TABLES=y
CONFIG_NFT_CT=m
CONFIG_NFT_MASQ=m
CONFIG_NFT_NAT=m
CONFIG_NFT_COMPAT=m
CONFIG_IP_VS=m
CONFIG_IP_NF_NAT=m
CONFIG_IP6_NF_NAT=m
CONFIG_BRIDGE=y
CONFIG_NET_DSA=m
CONFIG_LLC2=y
CONFIG_NET_SCHED=y
CONFIG_TSN=y
CONFIG_QRTR=m
CONFIG_QRTR_SMD=m
CONFIG_QRTR_TUN=m
CONFIG_NET_PKTGEN=m
CONFIG_CAN=m
CONFIG_BT=y
CONFIG_BT_RFCOMM=y
CONFIG_BT_BNEP=y
CONFIG_BT_HIDP=y
CONFIG_BT_LEDS=y
CONFIG_BT_HCIUART=y
CONFIG_BT_HCIVHCI=y
CONFIG_BT_NXPUART=m
CONFIG_CFG80211=y
CONFIG_MAC80211=y
CONFIG_NET_9P=y
CONFIG_NFC=m
CONFIG_NFC_NCI=m
CONFIG_PCI=y
CONFIG_PCI_IOV=y
CONFIG_PCI_PASID=y
CONFIG_PCI_XGENE=y
CONFIG_PCI_HISI=y
CONFIG_PCIE_KIRIN=y
CONFIG_PCI_MESON=m
CONFIG_DEVTMPFS=y
CONFIG_IMX_DSP=y
CONFIG_IMX_SCU=y
CONFIG_IMX_SCU_PD=y
CONFIG_GNSS=m
CONFIG_MTD=y
CONFIG_MTD_BLOCK=y
CONFIG_MTD_CFI=y
CONFIG_MTD_SST25L=y
CONFIG_MTD_UBI=y
CONFIG_VIRTIO_BLK=y
CONFIG_SRAM=y
CONFIG_UACCE=m
CONFIG_BLK_DEV_SD=y
CONFIG_ATA=y
CONFIG_SATA_AHCI=y
CONFIG_AHCI_IMX=y
CONFIG_AHCI_CEVA=y
CONFIG_AHCI_XGENE=y
CONFIG_AHCI_QORIQ=y
CONFIG_SATA_SIL24=y
CONFIG_MD=y
CONFIG_BLK_DEV_MD=m
CONFIG_BLK_DEV_DM=m
CONFIG_DM_CRYPT=m
CONFIG_DM_MIRROR=m
CONFIG_DM_ZERO=m
CONFIG_NETDEVICES=y
CONFIG_MACVLAN=m
CONFIG_MACVTAP=m
CONFIG_TUN=y
CONFIG_VETH=m
CONFIG_VIRTIO_NET=y
CONFIG_AMD_XGBE=y
CONFIG_ATL1C=m
CONFIG_BCMGENET=m
CONFIG_BNX2X=m
CONFIG_SYSTEMPORT=m
CONFIG_MACB=y
CONFIG_FEC=y
CONFIG_FEC_UIO=y
CONFIG_FSL_FMAN=y
CONFIG_FSL_ENETC=y
CONFIG_ENETC_TSN=y
CONFIG_HNS_DSAF=y
CONFIG_HNS_ENET=y
CONFIG_HNS3=y
CONFIG_HNS3_HCLGE=y
CONFIG_HNS3_ENET=y
CONFIG_E1000=y
CONFIG_E1000E=y
CONFIG_IGB=y
CONFIG_IGBVF=y
CONFIG_MVMDIO=y
CONFIG_SKY2=y
CONFIG_MLX4_EN=m
CONFIG_MLX5_CORE=m
CONFIG_QCOM_EMAC=m
CONFIG_RMNET=m
CONFIG_SMC91X=y
CONFIG_SMSC911X=y
CONFIG_STMMAC_ETH=y
CONFIG_INPHI_PHY=y
CONFIG_MICREL_PHY=y
CONFIG_AT803X_PHY=y
CONFIG_USB_USBNET=y
CONFIG_HOSTAP=y
CONFIG_WL18XX=m
CONFIG_INPUT_MISC=y
CONFIG_SERIAL_IMX=y
CONFIG_IPMI_SI=m
CONFIG_TCG_TPM=y
CONFIG_I2C_MUX=y
CONFIG_I2C_GPIO=m
CONFIG_I2C_IMX=y
CONFIG_I2C_RK3X=y
CONFIG_I2C_RPBUS=y
CONFIG_I3C=y
CONFIG_SPI=y
CONFIG_SPI_DW_DMA=y
CONFIG_SPI_IMX=y
CONFIG_SPI_PL022=y
CONFIG_SPI_SPIDEV=y
CONFIG_SPI_SLAVE=y
CONFIG_SPMI=y
CONFIG_EXPERT=y
CONFIG_GPIO_SYSFS=y
CONFIG_GPIO_DWAPB=y
CONFIG_GPIO_MXC=y
CONFIG_GPIO_PL061=y
CONFIG_GPIO_XGENE=y
CONFIG_WATCHDOG=y
CONFIG_IMX2_WDT=y
CONFIG_IMX_SC_WDT=y
CONFIG_XEN_WDT=y
CONFIG_MFD_FP9931=y
CONFIG_MFD_MT6397=y
CONFIG_MFD_RK808=y
CONFIG_RC_CORE=m
CONFIG_RC_DEVICES=y
CONFIG_DRM=y
CONFIG_DRM_IMX=y
CONFIG_DRM_MXSFB=y
CONFIG_DRM_PL111=m
CONFIG_DRM_LIMA=m
CONFIG_FB=y
CONFIG_FB_ARMCLCD=y
CONFIG_FB_EFI=y
CONFIG_LOGO=y
CONFIG_SOUND=y
CONFIG_SND=y
CONFIG_SND_ALOOP=m
CONFIG_SND_SOC=y
CONFIG_I2C_HID_OF=m
CONFIG_USB=y
CONFIG_USB_OTG=y
CONFIG_USB_ACM=m
CONFIG_USB_UAS=y
CONFIG_USB_CDNS3=y
CONFIG_USB_DWC3=y
CONFIG_USB_DWC2=y
CONFIG_USB_SERIAL=y
CONFIG_USB_TEST=m
CONFIG_USB_ULPI=y
CONFIG_USB_GADGET=y
CONFIG_USB_ZERO=m
CONFIG_USB_AUDIO=m
CONFIG_USB_ETH=m
CONFIG_TYPEC=y
CONFIG_TYPEC_TCPM=y
CONFIG_MMC=y
CONFIG_MMC_SDHCI=y
CONFIG_MMC_SPI=y
CONFIG_MMC_DW=y
CONFIG_MMC_DW_K3=y
CONFIG_MMC_MTK=y
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
CONFIG_LEDS_GPIO=y
CONFIG_LEDS_PWM=y
CONFIG_EDAC=y
CONFIG_EDAC_GHES=y
CONFIG_RTC_CLASS=y
CONFIG_DMADEVICES=y
CONFIG_FSL_EDMA=y
CONFIG_FSL_QDMA=m
CONFIG_IMX_SDMA=y
CONFIG_MV_XOR_V2=y
CONFIG_MXS_DMA=y
CONFIG_MXC_PXP_V3=y
CONFIG_PL330_DMA=y
CONFIG_QCOM_HIDMA=y
CONFIG_DW_EDMA=y
CONFIG_DMATEST=y
CONFIG_VFIO=y
CONFIG_VFIO_PCI=y
CONFIG_VIRTIO_PCI=y
CONFIG_XEN_GNTDEV=y
CONFIG_STAGING=y
CONFIG_FSL_DPAA2=y
CONFIG_FSL_PPFE=y
CONFIG_ETHOSU=y
CONFIG_CROS_EC=y
CONFIG_CLK_IMX8MM=y
CONFIG_CLK_IMX8MN=y
CONFIG_CLK_IMX8MP=y
CONFIG_CLK_IMX8MQ=y
CONFIG_CLK_IMX93=y
CONFIG_HWSPINLOCK=y
CONFIG_ARM_MHU=y
CONFIG_IMX_MBOX=y
CONFIG_ARM_SMMU=y
CONFIG_REMOTEPROC=y
CONFIG_RPMSG_CHAR=m
CONFIG_RPMSG_CTRL=m
CONFIG_SOUNDWIRE=m
CONFIG_FSL_DPAA=y
CONFIG_FSL_RCPM=y
CONFIG_FSL_QIXIS=y
CONFIG_SOC_TI=y
CONFIG_IIO=y
CONFIG_IMX93_ADC=y
CONFIG_MAX9611=m
CONFIG_FXAS21002C=y
CONFIG_VCNL4000=m
CONFIG_MPL3115=y
CONFIG_PWM=y
CONFIG_PWM_IMX27=y
CONFIG_PWM_RPCHIP=y
CONFIG_RESET_IMX7=y
CONFIG_PHY_XGENE=y
CONFIG_ARM_CCN=m
CONFIG_ARM_CMN=m
CONFIG_HISI_PMU=y
CONFIG_NVMEM_RMEM=m
CONFIG_FPGA=y
CONFIG_TEE=y
CONFIG_OPTEE=y
CONFIG_MUX_MMIO=y
CONFIG_MXC_SIM=y
CONFIG_MXC_EMVSIM=y
CONFIG_EXT2_FS=y
CONFIG_EXT3_FS=y
CONFIG_BTRFS_FS=m
CONFIG_FANOTIFY=y
CONFIG_QUOTA=y
CONFIG_AUTOFS4_FS=y
CONFIG_FUSE_FS=m
CONFIG_CUSE=m
CONFIG_OVERLAY_FS=m
CONFIG_VFAT_FS=y
CONFIG_HUGETLBFS=y
CONFIG_EFIVAR_FS=y
CONFIG_JFFS2_FS=y
CONFIG_UBIFS_FS=y
CONFIG_SQUASHFS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V4=y
CONFIG_NFS_V4_1=y
CONFIG_NFS_V4_2=y
CONFIG_ROOT_NFS=y
CONFIG_9P_FS=y
CONFIG_SECURITY=y
CONFIG_CRYPTO_TEA=m
CONFIG_CRYPTO_CFB=m
CONFIG_CRYPTO_CTS=m
CONFIG_CRYPTO_LRW=m
CONFIG_CRYPTO_OFB=m
CONFIG_CRYPTO_TLS=m
CONFIG_CRYPTO_MD4=m
CONFIG_CRC_CCITT=m
CONFIG_CRC8=y
CONFIG_DEBUG_FS=y
CONFIG_CORESIGHT=y
CONFIG_MEMTEST=y
joanxie
Pls check menuconfig, could you find these settings there?
dskim2
Where can I find that config in menuconfig?
joanxie
use bitbake linux-imx -c menuconfig
dskim2
My question is, where in the menu config is there a menu to turn on gpio sysfs?
