There are some errors about android imx7d
3,683 次查看
zhghua1103
Dear All,
Thanks very much about the product imx7,
I have some errors,
Would you please help me ?
such as:
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver usb_ehset_test
30b10200.usbmisc supply vbus-wakeup not found, using dummy regulator
30b20200.usbmisc supply vbus-wakeup not found, using dummy regulator
30b30200.usbmisc supply vbus-wakeup not found, using dummy regulator
mousedev: PS/2 mouse device common for all mice
input: 30370000.snvs:snvs-powerkey as /devices/platform/soc/30000000.aips-bus/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
usbcore: registered new interface driver xpad
usbcore: registered new interface driver usb_acecad
usbcore: registered new interface driver aiptek
usbcore: registered new interface driver gtco
usbcore: registered new interface driver hanwang
usbcore: registered new interface driver kbtab
[FTS_DBG] #####file=fts_init,line=862
howard hanvon_emp_init
snvs_rtc 30370000.snvs:snvs-rtc-lp: rtc core: registered 30370000.snvs:snvs- as rtc0
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x/sz) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR SANYO protocol handler initialized
IR Sharp protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR XMP protocol handler initialized
mxc_mipi-csi 30750000.mipi-csi: mipi csi v4l2 device registered
mxc_mipi-csi 30750000.mipi-csi: lanes: 2, hs_settle: 13, clk_settle: 2, wclk: 1, freq: 240000000
pxp-v4l2 pxp_v4l2_out: initialized
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
1-001c supply vdd not found, using dummy regulator
1-001c supply vddio not found, using dummy regulator
input: FreescaleAccelerometer as /devices/virtual/input/input1
mma8x5x device driver probe successfully
imx2-wdt 30280000.wdog: use WDOG_B to reboot.
imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.31.0-ioctl (2015-3-12) initialised: [email protected]
Bluetooth: HCI UART driver ver 2.3
Bluetooth: HCI UART protocol H4 registered
Bluetooth: HCI UART protocol BCSP registered
Bluetooth: HCI UART protocol ATH3K registered
usbcore: registered new interface driver btusb
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
/soc/aips-bus@30800000/usdhc@30b40000: voltage-ranges unspecified
sdhci-esdhc-imx 30b40000.usdhc: Got CD GPIO
sdhci-esdhc-imx 30b40000.usdhc: Got WP GPIO
sdhci-esdhc-imx 30b40000.usdhc: No vqmmc regulator found
mmc0: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
/soc/aips-bus@30800000/usdhc@30b50000: voltage-ranges unspecified
sdhci-esdhc-imx 30b50000.usdhc: assigned as wifi host
sdhci-esdhc-imx 30b50000.usdhc: No vmmc regulator found
sdhci-esdhc-imx 30b50000.usdhc: No vqmmc regulator found
mmc1: SDHCI controller on 30b50000.usdhc [30b50000.usdhc] using ADMA
/soc/aips-bus@30800000/usdhc@30b60000: voltage-ranges unspecified
sdhci-esdhc-imx 30b60000.usdhc: No vmmc regulator found
sdhci-esdhc-imx 30b60000.usdhc: No vqmmc regulator found
mmc2: SDHCI controller on 30b60000.usdhc [30b60000.usdhc] using ADMA
caam 30900000.caam: Entropy delay = 3200
caam 30900000.caam: Instantiated RNG4 SH0
caam 30900000.caam: Instantiated RNG4 SH1
caam 30900000.caam: device ID = 0x0a16030000000000 (Era -524)
caam 30900000.caam: job rings = 3, qi = 0
mmc2: MAN_BKOPS_EN bit is not set
mmc2: mmc_select_hs200 failed, error -74
: switch to mmc2 failed
mmc2: new MMC card at address 0001
mmcblk2: mmc2:0001 DL2032 29.1 GiB
mmcblk2boot0: mmc2:0001 DL2032 partition 1 4.00 MiB
mmcblk2boot1: mmc2:0001 DL2032 partition 2 4.00 MiB
mmcblk2rpmb: mmc2:0001 DL2032 partition 3 4.00 MiB
 mmcblk2: p1 p2 p3 < p5 p6 p7 p8 p9 > p4
caam algorithms registered in /proc/crypto
caam_jr 30901000.jr0: registering rng-caam
platform caam_sm: blkkey_ex: 8 keystore units available
platform caam_sm: 64-bit clear key:
platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
platform caam_sm: 64-bit black key:
platform caam_sm: [0000] 36 63 d0 82 35 58 ab 54
platform caam_sm: [0008] 39 6d 23 4f 1f 70 7b 7b
platform caam_sm: 128-bit clear key:
platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
platform caam_sm: 128-bit black key:
platform caam_sm: [0000] 13 73 61 49 42 4d c3 6a
platform caam_sm: [0008] 23 88 15 2f 48 19 ef be
platform caam_sm: 192-bit clear key:
platform caam_sm: [0016] 10 11 12 13 14 15 16 17
platform caam_sm: 192-bit black key:
platform caam_sm: [0000] 76 7a 80 b0 46 8e 18 3c
platform caam_sm: [0008] a4 5e 4b d2 7b 5e a5 e5
platform caam_sm: [0016] 9c 06 c6 1e a9 c9 c8 6e
platform caam_sm: [0024] 9e 48 c6 3e bd af f7 a1
platform caam_sm: 256-bit clear key:
platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
platform caam_sm: 256-bit black key:
platform caam_sm: [0000] 49 8d 8f 13 2f a9 80 91
platform caam_sm: [0008] 64 ce d7 99 32 bd a8 16
platform caam_sm: [0016] b6 d5 e5 7c 5f 32 1b d3
platform caam_sm: [0024] b6 b7 b7 de 3e 44 5d bc
platform caam_sm: 64-bit unwritten blob:
platform caam_sm: [0000] 00 00 00 00 00 00 00 00
platform caam_sm: [0008] 00 00 00 00 00 00 00 00
platform caam_sm: [0016] 00 00 00 00 00 00 00 00
platform caam_sm: [0024] 00 00 00 00 00 00 00 00
platform caam_sm: [0032] 00 00 00 00 00 00 00 00
platform caam_sm: [0040] 00 00 00 00 00 00 00 00
platform caam_sm: [0048] 00 00 00 00 00 00 00 00
platform caam_sm: [0056] 00 00 00 00 00 00 00 00
platform caam_sm: [0064] 00 00 00 00 00 00 00 00
platform caam_sm: [0072] 00 00 00 00 00 00 00 00
platform caam_sm: [0080] 00 00 00 00 00 00 00 00
platform caam_sm: [0088] 00 00 00 00 00 00 00 00
platform caam_sm: 128-bit unwritten blob:
platform caam_sm: 196-bit unwritten blob:
platform caam_sm: 256-bit unwritten blob:
platform caam_sm: 64-bit black key in blob:
platform caam_sm: [0000] b5 40 9f f0 16 ce 1e d2
platform caam_sm: [0008] 73 22 64 45 ee 45 89 04
platform caam_sm: [0016] 95 ff d7 74 25 3d 4e 2c
platform caam_sm: [0024] 3b 1d f0 f5 cc 46 01 14
platform caam_sm: [0032] c4 79 71 b0 04 9e 7b ae
platform caam_sm: [0040] 24 76 20 c7 1d 34 72 07
platform caam_sm: [0048] 3b c8 d6 5a 3a fc 6e 97
platform caam_sm: 128-bit black key in blob:
platform caam_sm: [0000] a4 dd fa fa cb d5 8c b2
platform caam_sm: [0008] 98 e0 42 2b b7 98 72 29
platform caam_sm: [0016] e7 62 07 ff 69 cc ff 2b
platform caam_sm: [0024] 34 90 aa 6c 11 31 2e 74
platform caam_sm: [0032] 95 8a 24 fb 5d 5f 38 d3
platform caam_sm: [0040] 03 ec 74 ef e0 0c 58 80
platform caam_sm: [0048] cc a0 33 b1 61 f4 c9 f8
platform caam_sm: [0056] 0d 02 07 8a 86 ec 22 ab
platform caam_sm: 192-bit black key in blob:
platform caam_sm: [0000] 93 57 de 28 17 f2 00 c9
platform caam_sm: [0008] f5 99 87 ce 20 7a bf 23
platform caam_sm: [0016] 16 47 e3 8c 80 40 04 58
platform caam_sm: [0024] 19 b4 64 8e a5 68 8e ae
platform caam_sm: [0032] 83 13 4f 70 3a 3a 0b d5
platform caam_sm: [0040] 6c 2d 48 28 8d a7 69 43
platform caam_sm: [0048] 70 58 61 3a e7 a6 48 51
platform caam_sm: [0056] 38 90 d7 4a aa 3f 84 09
platform caam_sm: [0064] 30 b5 79 49 12 d3 3c 97
platform caam_sm: 256-bit black key in blob:
platform caam_sm: [0000] a6 7e 0a f4 c7 cd 30 03
platform caam_sm: [0008] b7 20 b8 e0 8e c1 ca a5
platform caam_sm: [0016] b6 fe 93 2f 7e 11 1f 4a
platform caam_sm: [0024] c3 43 cb 73 fb fb f1 3f
platform caam_sm: [0032] 2f 6e 13 3b 8b ac 0f 61
platform caam_sm: [0040] 2f 71 31 b9 63 8e ef 42
platform caam_sm: [0048] e0 96 92 93 31 0c 38 28
platform caam_sm: [0056] b7 f1 13 05 75 8f ef 61
platform caam_sm: [0064] 36 70 1c 42 0e c9 b9 e5
platform caam_sm: [0072] d5 15 7b 26 60 89 43 de
platform caam_sm: restored 64-bit black key:
platform caam_sm: [0000] 44 6d 82 50 88 78 50 af
platform caam_sm: [0008] 2f 2c 44 0b 68 ef 89 25
platform caam_sm: restored 128-bit black key:
platform caam_sm: restored 192-bit black key:
platform caam_sm: [0016] 56 14 b9 2c 96 e9 0f f3
platform caam_sm: [0024] f6 56 73 a1 fb f4 f5 9c
platform caam_sm: restored 256-bit black key:
snvs-secvio 30370000.caam-snvs: can't get snvs clock
snvs-secvio 30370000.caam-snvs: violation handlers armed - non-secure state
hidraw: raw HID events driver (C) Jiri Kosina
usbhid: USB HID core driver
ashmem: initialized
usbcore: registered new interface driver snd-usb-audio
imx-wm8960 sound: wm8960-hifi <-> 308a0000.sai mapping ok
NET: Registered protocol family 26
u32 classifier
    Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (15930 buckets, 63720 max)
ctnetlink v0.93: registering with nfnetlink.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: (C) 2002 David S. Miller
Initializing XFRM netlink socket
NET: Registered protocol family 10
mip6: Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 15
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
Console: switching to colour frame buffer device 150x51
dhd_module_init in
Power-up adapter 'DHD generic adapter'
wifi_platform_bus_enumerate device present 1
failed to power up DHD generic adapter, 3 retry left
wifi_platform_bus_enumerate device present 0
failed to power up DHD generic adapter, 2 retry left
failed to power up DHD generic adapter, 1 retry left
failed to power up DHD generic adapter, 0 retry left
failed to power up DHD generic adapter, max retry reached**
input: gpio-keys as /devices/platform/gpio-keys/input/input3
snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:09 UTC (9)
VPOS: disabling
VNEG: disabling
HVINP: disabling
HVINN: disabling
GVEE: disabling
GVDD: disabling
wlreg_on: disabling
VDD_SD1: disabling
usb_otg1_vbus: disabling
ALSA device list:
  #0: wm8960-audio
Freeing unused kernel memory: 1024K (c1000000 - c1100000)
init: init started!
init: init second stage started!
init: waitpid failed: No child processes
init: property_set("ro.zygote", "zygote32") failed
init: (Loading properties from /default.prop took 0.00s.)
init: (Parsing /init.environ.rc took 0.00s.)
init: (Parsing /init.usb.rc took 0.00s.)
init: (Parsing init.freescale.usb.rc took 0.00s.)
init: (Parsing /init.freescale.rc took 0.01s.)
init: (Parsing /init.usb.configfs.rc took 0.00s.)
init: (Parsing /init.zygote32.rc took 0.00s.)
init: (Parsing /init.trace.rc took 0.00s.)
init: (Parsing /init.rc took 0.03s.)
init: Starting service 'ueventd'...
init: Waiting for /dev/.coldboot_done...
ueventd: ueventd started!
ueventd: C�F�. שּׁ�*�3���+�/��/ɝ/F����f�init: write_file: Unable to open '/proc/sys/kernel/sched_compat_yield': No such file or directory
init: write_file: Unable to write to '/dev/cpuctl/cpu.shares': Invalid argument
init: write_file: Unable to open '/proc/sys/abi/swp': No such file or directory
Console: switching to colour dummy device 80x30
EXT4-fs (mmcblk2p5): mounted filesystem with ordered data mode. Opts: barrier=1
fs_mgr: __mount(source=/dev/block/mmcblk2p5,target=/system,type=ext4)=0
EXT4-fs (mmcblk2p4): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk2p4): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
fs_mgr: __mount(source=/dev/block/mmcblk2p4,target=/data,type=ext4)=0
EXT4-fs (mmcblk2p6): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk2p6): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
fs_mgr: __mount(source=/dev/block/mmcblk2p6,target=/cache,type=ext4)=0
EXT4-fs (mmcblk2p7): mounted filesystem with ordered data mode. Opts: (null)
fs_mgr: __mount(source=/dev/block/mmcblk2p7,target=/device,type=ext4)=0
file system registered
init: Starting service 'logd'...binder: release 1165:1165 transaction 7115 out, still active
binder: 500:635 transaction failed 29189, size 4-0
binder: send failed reply for transaction 7115, target dead
zram0: detected capacity change from 0 to 314572800
logd.auditd: start
logd.klogd: 12601712000
Adding 307196k swap on /dev/block/zram0.  Priority:-1 extents:1 across:307196k SS
init: (Loading properties from /system/build.prop took 0.01s.)
init: (Loading properties from /vendor/build.prop took 0.00s.)
init: (Loading properties from /factory/factory.prop took 0.00s.)
init: Starting service 'vold'...
init: Not bootcharting.
init: Failed to reload policy
init: Starting service 'exec 0 (/system/bin/tzdatacheck)'...
init: Service 'exec 0 (/system/bin/tzdatacheck)' (pid 188) exited with status 0
init: Starting service 'logd-reinit'...
init: Starting service 'healthd'...
init: Starting service 'console'...
init: Starting service 'lmkd'...
init: Starting service 'servicemanager'...
binder: 190:190 transaction failed 29189, size 0-0
init: Starting service 'surfaceflinger'...
logd.daemon: reinit
init: Service 'logd-reinit' (pid 189) exited with status 0
init: write_file: Unable to open '/sys/block/mmcblk0/queue/read_ahead_kb': No such file or directory
init: write_file: Unable to open '/sys/block/mmcblk1/queue/read_ahead_kb': No such file or directory
rfkill: BT RF going to : off
random: init urandom read with 32 bits of entropy available
root@sabresd_7d:/ # init: write_file: Unable to open '/sys/bus/platform/drivers/galcore/gpu3DMinClock': Permission denied
init: property_set("ro.ril.wake_lock_timeout", "300") failed
init: Starting service 'netd'...
init: Starting service 'debuggerd'...
init: cannot find '/system/bin/debuggerd64', disabling 'debuggerd64'
init: Starting service 'drm'...
init: Starting service 'media'...
init: Starting service 'installd'...
init: cannot find '/system/bin/install-recovery.sh', disabling 'flash_recovery'
init: Starting service 'keystore'...
init: Starting service 'ril-daemon'...
init: Starting service 'zygote'...
init: Starting service 'gatekeeperd'...
init: cannot find '/system/xbin/perfprofd', disabling 'perfprofd'
init: Starting service 'sensor_fusion'...
init: Service 'sensor_fusion' (pid 209) exited with status 255
android_work: sent uevent USB_STATE=CONNECTED
android_work: sent uevent USB_STATE=DISCONNECTED
configfs-gadget gadget: high-speed config #1: b
android_work: sent uevent USB_STATE=CONFIGURED
healthd: No charger supplies found
healthd: No battery devices found
init: Starting service 'bootanim'...
pxp-v4l2 pxp_v4l2_out: failed to call pxp_set_fbinfo
capability: warning: `main' uses 32-bit capabilities (legacy support in use)
zram: 500 (system_server) Attribute mem_used_total (and others) will be removed. See zram documentation.
random: nonblocking pool is initialized
lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
lowmemorykiller: oom_adj 0 => oom_score_adj 0
lowmemorykiller: oom_adj 1 => oom_score_adj 58
lowmemorykiller: oom_adj 2 => oom_score_adj 117
lowmemorykiller: oom_adj 3 => oom_score_adj 176
lowmemorykiller: oom_adj 9 => oom_score_adj 529
lowmemorykiller: oom_adj 15 => oom_score_adj 1000
acc_open
acc_release
init: Service 'bootanim' (pid 240) exited with status 0
mtp_open
标记 (1)
4 回复数
3,166 次查看
raghurambn
I am facing the same issue mentioned above for IMX7 sabre D board
Logs:init: write_file: Unable to open '/sys/bus/platform/drivers/galcore/gpu3DMinClock': Permission denied
init: property 'ro.product.manufacturer' doesn't exist while expanding '${ro.product.manufacturer}'
init: write: cannot expand '${ro.product.manufacturer}'
init: property 'ro.product.model' doesn't exist while expanding '${ro.product.model}'
init: write: cannot expand '${ro.product.model}'
configfs-gadget gadget: unbind function 'mtp'/d898ce00
android_work: did not send uevent (0 0 (null))
binder: 175:175 transaction failed 29189, size 0-0
Please help me with the solution for the above issue
3,166 次查看
jimmychan
could you show the logcat ?
3,166 次查看
zhghua1103
Dear jimmychan,
Thanks very much for your  help.
I am thanks
The problem is ok.
With Best Regards
Joshua
3,166 次查看
eric_kang
Hi Joshua Zhu,
Did you solve this problem?
Could you share the solution if you solve this issue?
You can share the solution by sending a mail to me.
Eric.
