The side effect/impact of SSC(Spectrum Spread) on PLL2.
1,289件の閲覧回数
asou_junichi
SSC(Spectrum Spread) is enabled and only DDR and LVDS use the PLL2 clock.
(PLL2 clock : 396MHz -> 384MHz by 23kHz step)
In the case, are there any side effect/impact to the connected devices to the clock delivered from PLL2?
1,101件の閲覧回数
yes one should consider SSC effect on any devices (modules) using that clock,
in particular for ddr check micron document p.14
http://www.micron.com/~/media/documents/products/data-sheet/dram/ddr3/ddr3l_2gb_graphics_addendum.pd...
1,101件の閲覧回数
asou_junichi
Thank you for an answer.
I got it.
BR,
Jun
1,102件の閲覧回数
