Tamper Pin in IMX6
Tamper Pin in IMX6
5,335件の閲覧回数
koperapune
We are developing a product using imx6-sl. We want to add support to detect tampering whenever case/box is unauthorizedly opened.
I have seen Pin named Tamper. however I haven't seen any instruction on interrupt handling for the Tamper Pin in the reference-manual. Would you please help me to add support for the driver?
ラベル(2)
タグ(1)
3 返答(返信)
2,969件の閲覧回数
Yuri
2,969件の閲覧回数
koperapune
YuriMuhin_ng
Hi Yuri,
The document helped , thanks a lot for that ...
I now know the registers that can be used to handle the tamper functionality.
But the problem is that , quite some registers are marked "Privileged Write access" .... They say that, only privileged software can write to these registers .... but i didn't quite get as to what is meant by privileged software ....
Can you pls point me to what could the document mean by privileged software .... ?? i.e. how can I get an access to these privileged registers ... ??
Thanks in advance !!
2,969件の閲覧回数
Yuri
Please take a look at the following :
ARM Information Center
