Switching between two codecs
910件の閲覧回数
divyeshmarne0
Hi Team,
Need your help to understand the switching between two different codec.
We are using:
Internal Audio Codec (TI CODEC) - for low frequency (Sub woofer - Notifications like BT,LTE, MSG etc.)
External Audio Codec (20W*2 Speakers) - second one is for high frequency woofer (Music player n all ).
What are the changes required to switching between in these two codecs.
Both the codecs having their own significance.
What are the changes needed in Android 11 code base and kernel with respect to imx8mm board.
Divyesh.
0 返答(返信)
