Streaming Problem in MX53 -blog archive
711 次查看
Bhavana
I am Using MX53qsb board.Successfully builted Ltib.
Now i am facing a problem with streaming video using gst-launch.
Using this commands
Server pipeline: gst-launch -v v4l2src device=/dev/video0 ! video/x-raw-yuv,width=320,height=240 !  mfw_ipucsc ! mfw_vpuencoder width=320 height=240 codec-type=std_mjpg ! rtpjpegpay ! udpsink host=192.168.255.1 auto-multicast=true port=5000 sync=false
Client pipeline: gst-launch -vvv  udpsrc port=5000 ! 'application/x-rtp, media=video, payload=96, clock-rate=90000, encoding-name=JPEG' ! rtpjpegdepay ! ffdec_mjpeg ! xvimagesink
It is working but Incorrect...
host linux i run this command:
gst-launch v4l2src ! 'video/x-raw-yuv, format=(fourcc)YUY2, width=640, height=480, framerate=(fraction)25/1' ! ffmpegcolorspace ! ximagesink
This command is working fine.
What i will do?
Can some one post solution...
-Thank you
标记 (1)
0 回复数
