Some WinCE NAND driver testbench code -blog archive
StanleyLee
Here is a testbench file, one can embed it into Fmd to do a test:
PVOID FMD_Init(LPCTSTR lpActiveReg, PPCI_REG_INFO pRegIn, PPCI_REG_INFO pRegOut)
    DWORD i;
    PVOID pResult;
    UNREFERENCED_PARAMETER(lpActiveReg);
    UNREFERENCED_PARAMETER(pRegIn);
    UNREFERENCED_PARAMETER(pRegOut);
    // 0. Setup global variables. Also may add more software logic here in future
    memset(&g_FlashInfoExt, 0, sizeof(g_FlashInfoExt));
    BSPNAND_GetFlashInfo(&g_FlashInfoExt);
    // 1. initial NFC hardware
    pResult = CSPNAND_Init(&g_FlashInfoExt);
    if(pResult == NULL)
        goto cleanUp;
    // 2. initial nand chip and verify nand id
    for(i = 0; i < g_FlashInfoExt.NumberOfChip; i++)
        CSPNAND_Reset(i);
        if(CSPNAND_ReadID(i) != g_FlashInfoExt.NANDIDCode)
            pResult = NULL;
            goto cleanUp;
    if(g_FlashInfoExt.ILSupport && CSPNAND_ILSupport())
        //silicon supports interleave mode & bsp needs interleave mode
        g_bInterLeaveMode = TRUE;
    NANDOperationTest();
    if(!BBT_Init())
        RETAILMSG(TRUE, (TEXT("InitializeBBT Fail\r\n")));
cleanUp:
    return pResult;
nandtest.cpp
