Software Support for iMX95 Evaluation kit
Harish_V
Hi team. I am currently working on bringup of YUV cameras and RAW sensors for Verdin imx95 EVK containing the NXP BSP. I have a query regarding the longetivity, is there a cutoff or a certain deadline only until which the NXP will be providing support for the iMX95 Verdin Evaluation Kit. Can you please confirm on the same. Thanks
Tags (3)
Rita_Wang
Hi @Harish_V
If you are using the board Toradex i.MX95 Verdin Evaluation Board, I am afraid that we would not support the Toradex Board BSP soon, you can consider our FRDM i.MX 95 Development Board | NXP Semiconductors, i.MX 95 19mm x 19mm Evaluation Kit | NXP SemiconductorsYou do not worry about the BSP longetivity problem.
Hope this can do help for you
Any questions contact me freely
Best Regards
Rita
Harish_V
Hi can you please update us on this, Thanks
Harish_V
Thank you for your response. Currently we are using the iMX95 EVK kit and have supported YUV cameras, we faced issues with RAW camera support while pushing in display. The following is the link to forum query,
https://community.nxp.com/t5/Other-NXP-Products/How-to-push-stream-to-display-in-iMX95-Verdin-EVK-wi...
If we procure the board which you are suggesting (https://www.nxp.com/design/design-center/development-boards-and-designs/FRDM-IMX95?_gl=1*1b1ogb5*_ga....) will we be able to perform ISP tuning and get stream from RAW camera and push it to display. Can you please confirm on this.
Rita_Wang
Are you using the Verdin imx95 EVK board?
