Simultaneously use SPI Blocking/NonBlocking and SDMA Transfer
2,776件の閲覧回数
vaparikh
I was wondering if it is possible to have SPIBlockingTransfer, SPINonBlockingTransfer (Interrupt Based) and SPISdmaTransfer all 3 working at the same time? I am using an i.MX8. Would I continuously have to Enable and Disable SPI SDMA constantly to achieve this? I would like to have some operations to happen over DMA while others to happen directly. I am not sure if this is even possible. Has anyone tried this?
3 返答(返信)
2,612件の閲覧回数
jimmychan
May I ask which product are you using? which BSP are you using?
2,612件の閲覧回数
vaparikh
I am trying to get this to work on an IMX8MQ on the Cortex M4 side. I have an EVK-MIMX8MQ board and trying to get this to work on that. I downloaded the SDK from the NXP website for the eval board.
2,612件の閲覧回数
jimmychan
What is the use case that all three (SPIBlockingTransfer, SPINonBlockingTransfer and SPISdmaTransfer) will be using at the same time?
