Hello All,
This is my first time playing with spsdk tool for i.mx93 and getting following error:
(spsdk-venv) [10/18/24 10:27:01] -> spsdk -> nxpimage otfad export -i 1 -c mx93_otfad.yaml
ERROR:SPSDK: The UID:otfad1_key is not found in loaded registers for mx93 device.
I don't see any field "otfad1_key" in YAML file, here is my YAML template:
(spsdk-venv) [10/18/24 10:02:31] -> spsdk -> cat mx93_otfad.yaml
# ============================ On-The-Fly AES decryption Configuration template for mx93. ============================
# -------------------------------------------------------- Note --------------------------------------------------------
# Is important to use physical addresses (non-secure) in settings of OTFAD to proper run the decryption on device.
# For example:
# In case of using FlexSPI2 the secure base address address is 0x1400_0000. But in setting of the OTFAD use
# 0x0400_0000 as a base address.
# The code must be still linked on secure base address 0x1400_0000 to proper run of OTFAD hardware.
# Same is for FlexSPI1, but instead of 0x3800_0000 base address, the 0x2800_0000 must be used in OTFAD configuration.
# == Basic Settings ==
# ------------------------------------------===== MCU family [Required] =====-------------------------------------------
# Description: MCU family name.
# Possible options: <mx93, rt1010, rt116x, rt117x, rt118x, rt5xx, rt6xx>
family: mx93
# --------------------------------------===== OTFAD output folder [Required] =====--------------------------------------
# Description: Path to directory where the OTFAD output will be generated
output_folder: otfad_output
# ---------------------------------===== Output binary image file name [Optional] =====---------------------------------
# Description: Filename of the output image containing keyblobs and encrypted data blobs without file extension (.bin
# will be appended)
output_name: otfad_whole_image
# ---------------------------------------===== Keyblob file name [Optional] =====---------------------------------------
# Description: Filename of the keyblob without file extension (.bin will be appended)
keyblob_name: OTFAD_Table
# ----------------------------------------===== Encrypted name [Optional] =====-----------------------------------------
# Description: filename of the encrypted datablobs without file extension (.bin will be appended)
encrypted_name: encrypted_blob
# --------------------------------------===== Generate readme.txt [Optional] =====--------------------------------------
# Description: Readme file contains information about image layout
generate_readme: true
# == OTFAD Settings ==
# ----------------------------------------------===== KEK [Required] =====----------------------------------------------
# Description: OTFAD Key Encryption Key to encrypt OTFAD table. Might be provided as a path to binary file containing
# KEK or as a string or number
# kek: my_secret_kek.bin
kek: '3b910ece1b46502e0039d4deedcdee5e'
# ---------------------------------===== OTFAD key blobs table address [Required] =====---------------------------------
# Description: The base address of key blob table, it should be aligned to 1 KB (1024 B)
otfad_table_address: '0x08000000'
# ----------------------------------------===== Data blobs list [Optional] =====----------------------------------------
# Description: List of all data blobs included in this key blob
data_blobs:
# -----------------------------------===== Plain Text data blob [Required] =====------------------------------------
# Description: Path to binary file with plain text data to be encrypted if desired
# data: my_data.bin
data: imx-boot--fspi.bin-flash_singleboot
# -------------------------------------===== Data blob address [Required] =====-------------------------------------
# Description: Data blob address, it could be omitted if data blob starts at start_address
address: '0x08001000'
# --------------------------------===== List of Key Blobs used by OTFAD [Required] =====--------------------------------
# Description: The list of definition of individual key blobs including plain data. Add other array items as you need
# and device allows
key_blobs:
# ------------------------------------------===== AES key [Required] =====------------------------------------------
# Description: AES key for the key blob
aes_key: '0xB1A0C56AF31E98CD6936A79D9E6F829D'
# -------------------------------------===== AES Counter value [Required] =====-------------------------------------
# Description: AES counter value for the key blob
aes_ctr: '0x5689fab8b4bfb264'
# ------------------------------===== Start address of key blob data [Required] =====-------------------------------
# Description: Start address of key blob data, it should be aligned to 1 KB (1024 B)
start_address: '0x08001000'
# -------------------------------===== End address of key blob data [Required] =====--------------------------------
# Description: End address of key blob data, it should be aligned to 1 KB (1024 B)
end_address: '0x08010000'
# --------------------------------===== AES decryption enable flag [Optional] =====---------------------------------
# Description: For accesses hitting in a valid context, this bit indicates if the fetched data is to be decrypted or
# simply bypassed
aes_decryption_enable: true
# ----------------------------------------===== Valid flag [Optional] =====-----------------------------------------
# Description: This field signals if the context is valid or not
valid: true
# --------------------------------------===== Read Only flag [Optional] =====---------------------------------------
# Description: This field signals if the context is Read only or not
read_only: true
Any help will be highly appreciated.
Cheers,
