SEC tool Connection Error
2,307件の閲覧回数
Vishwajeetlohar
Hii,
I am trying to use SEC tool for IMXRT1064 but it I am not able to establish the connection properly.
Please let me know if any changes or settings are required
2,285件の閲覧回数
diego_charles
Hi @Vishwajeetlohar
I see that the tool is not being able to establish communication with the RT1064's USB port. Do you need to use USB? or you could also use UART?
I recommend first checking if the MCU is on serial downloader mode. A simple way to do this is by reading the program counter with SWD debug, you must see and address like 0x2xxxx.
Diego
