SDRAM
SDRAM
Shealtiel
I want to reserve 4 bytes in SDRAM , How can i reserve the 4 byte into SDRAM
Board - MXRT1020
Shealtiel
Omar_Anguiano
You can use the "MCU settings" menu on the project properties of MCUXpresso so you create a RAM area with the directions you want to reserve from your SDRAM.
Properties -> C/C++ Build -> MCU settings
Omar
