SDKs supported development boards
2,094件の閲覧回数
frdisc
I'm going to select a development board such as the i.MX 7ULP (Cortex-M4) because 2 ADC and 2 DAC are required. But the SDKs don't support this board. Are there any similar development boards available? SDKs support is necessary. I can't figure out.
Techdisc
3 返答(返信)
2,029件の閲覧回数
frdisc
Hi! Jamesbone,
Thanks for your information. The kE128 includes 6 bit DACs but I require 12 bit resolution. Are there any other development boards available?
Adam
2,029件の閲覧回数
jamesbone
The i.MX7ULP it is a Cortex A + Cortex M device we have an SDK support for the Cortex M4 that can be used as another peripheral for the Cortex A CPU,   For the Cortex A, we have support for Linux and Android BSP.  If you want to use a  Cortex M4 with ADC and DAC we suggest that you check the Kinetis Family we suggest the KE128 As an Example the  Kinetis E family has  ADC and DAC support, we provide SDK for the programming and it is a very nice device for Measurement purposes
2,029件の閲覧回数
frdisc
Hi! Jamesbone,
I appreciate your reply. I'll select.
Adam
