do you know if there is a plan to extend this excellent article done by xinyu_chen
Run Zephyr on A55 with FRDM-IMX93 and FRDM-IMX91
adding support to FRDM-IMX91S?
Yes thank you Daniel: do you have any advice about how to manage the spi nand?
Hi aspin:
Zephyr has built-in support for SPI NOR flash via the jedec, spi-nor compatible. But SPI NAND is not directly supported in the same way.
I found one NAND Flash project in Zephyr as below, it includes SPI communication logic and example handle implementation. maybe you can take it for reference
https://github.com/D-Buckingham/NAND_flash
https://docs.zephyrproject.org/latest/hardware/porting/board_porting.html
Hi Daniel,
I was thinking about the tool to write the Zephyr fw to the spi nand in the FRDM-IMX91S to be able to boot Zephyr.
Hi Daniel,
I agree with you, I was just thinking about some few minor difference like the spi nand and the pmic.
please feel free to reach out us if you experience any issues or need further assistance.
