Resolution shift app using init script run on boot in wayland weston imx8mp
ankitpanchal167
we are try to run QT app using init script it's running successfully but QT app not in full screen.
Qt app ui shifted right side and and bottom side and some gap left and top.
after  boot we run manually run QT app it's wokring fine no issue on screen it's showing in full screen.
How to fix this in wayland weston ?
ankitpanchal167
Sorry I can't share script.
Now it's resolve my issue thanks,
Zhiming_Liu
Where do you put the init script?Can you share the init scripts?
ankitpanchal167
