Request for Audio Command Assistance for Mercury DAC on i.MX6SX SABRE-SD Board
Joseph_Chiristopher_N
I am currently working with the i.MX6SX SABRE-SD board integrated with Mercury and Radion tuner chips. I am pleased to inform you that both tuner chips have been successfully booted. However, I am encountering an issue with the audio output, which is currently not functioning.
Upon reviewing the schematic, I noted that the Mercury DAC is connected to the X7 output. To proceed further, I would appreciate it if you could kindly share the appropriate audio commands or configuration steps necessary to enable and troubleshoot audio output through this DAC.
Your assistance in this matter would be greatly valuable and highly appreciated.
Thank you very much for your support.
Joseph Chiristopher
JorgeCas
Could you please share the schematic connections?
Best regards.
hi @JorgeCas
Thank you for your response.
I've attached the schematics to this message—please have a look when you get a chance.
Joseph Chiristopher
JorgeCas
Since these products are not mass market, I suggest you put in contact with your local FAE since we do not have access to the information of those part numbers.
Best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2137938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERequest%20for%20Audio%20Command%20Assistance%20for%20Mercury%20DAC%20on%20i.MX6SX%20SABRE-SD%20Board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3EI%20am%20currently%20working%20with%20the%20i.MX6SX%20SABRE-SD%20board%20integrated%20with%20Mercury%20and%20Radion%20tuner%20chips.%20I%20am%20pleased%20to%20inform%20you%20that%20both%20tuner%20chips%20have%20been%20successfully%20booted.%20However%2C%20I%20am%20encountering%20an%20issue%20with%20the%20audio%20output%2C%20which%20is%20currently%20not%20functioning.%3C%2FP%3E%3CP%3EUpon%20reviewing%20the%20schematic%2C%20I%20noted%20that%20the%20Mercury%20DAC%20is%20connected%20to%20the%20X7%20output.%20To%20proceed%20further%2C%20I%20would%20appreciate%20it%20if%20you%20could%20kindly%20share%20the%20appropriate%20audio%20commands%20or%20configuration%20steps%20necessary%20to%20enable%20and%20troubleshoot%20audio%20output%20through%20this%20DAC.%3C%2FP%3E%3CP%3EYour%20assistance%20in%20this%20matter%20would%20be%20greatly%20valuable%20and%20highly%20appreciated.%3C%2FP%3E%3CP%3EThank%20you%20very%20much%20for%20your%20support.%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20regards%2C%3CBR%20%2F%3EJoseph%20Chiristopher%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Request%20for%20Audio%20Command%20Assistance%20for%20Mercury%20DAC%20on%20i.MX6SX%20SABRE-SD%20Board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3ESince%20these%20products%20are%20not%20mass%20market%2C%20I%20suggest%20you%20put%20in%20contact%20with%20your%20local%20FAE%20since%20we%20do%20not%20have%20access%20to%20the%20information%20of%20those%20part%20numbers.%3C%2FP%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Request%20for%20Audio%20Command%20Assistance%20for%20Mercury%20DAC%20on%20i.MX6SX%20SABRE-SD%20Board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203308%22%20target%3D%22_blank%22%3E%40JorgeCas%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20response.%3CBR%20%2F%3EI've%20attached%20the%20schematics%20to%20this%20message%E2%80%94please%20have%20a%20look%20when%20you%20get%20a%20chance.%3C%2FP%3E%3CP%3EBest%20regards%2C%3CBR%20%2F%3EJoseph%20Chiristopher%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Request%20for%20Audio%20Command%20Assistance%20for%20Mercury%20DAC%20on%20i.MX6SX%20SABRE-SD%20Board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3ECould%20you%20please%20share%20the%20schematic%20connections%3F%3C%2FP%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E
