Regarding vpu codec test application
srilakshmikanag
Atpresent I am testing vpu codec test application given by freescale,
while testing with 720p file(below attached file). 1st and 2nd decoded frame is in output index 0
General procedure described in "i.MX_6Dual6Quad_VPU_API.pdf" is index used by vpu has to be cleared by
"VPUDEC_CLEAR_DISPLAY_FLAG" then vpu can reuse the outpu index. In this scenario how can it
reuse index 0 for second decoded frame.
Is it a bug in vpu test application please let me know.
Thanks in advance.
Srilakshmi
Labels (4)
juangutierrez
Can you specify which vpu codec test application are you  running? Is on linux or SDK?
I guess you forgot the attachment. Can you share it?
