Reg: Kernel Crash
Reg: Kernel Crash
2,351 次查看
vishvapathi
Contributor V
    Sometimes my kernel crashes while booting.
arm-none-linux-gnueabi-gcc (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08)
root filesystem built on Mon, 05 Aug 2013 12:26:13 +0530
Freescale Semiconductor, Inc.
freescale login: Unable to handle kernel NULL pointer dereference at virtual ad8
pgd = 80004000
[000000f8] *pgd=00000000
Internal error: Oops: 17 [#1] PREEMPT SMP
Modules linked in:
CPU: 0Tainted: G    W(3.0.35-2508-g54750ff #1)
PC is at dapm_find_widget+0x8/0x70
LR is at snd_soc_dapm_set_pin+0x18/0x64
pc : [<803b6968>]lr : [<803b8bc4>]psr: 80000013
sp : bfd1ff10  ip : 00000000  fp : 80a853c8
r10: 803c7540  r9 : 8c00c305  r8 : 00000000
r7 : bfd1e000  r6 : 000000ac  r5 : 809d5c24  r4 : 00000000
r3 : 00000001  r2 : 00000001  r1 : 809d5c24  r0 : 000000ac
Flags: Nzcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 10c53c7d  Table: 4a33404a  DAC: 00000015
Process kworker/0:1 (pid: 372, stack limit = 0xbfd1e2f0)
Stack: (0xbfd1ff10 to 0xbfd20000)
ff00:                                 00000001 00000000 809d5c24 000000ac
ff20: bfd1e000 00000000 803c7540 803b8bc4 80ab2e28 80a57ff8 80a58870 803c757c
ff40: 00000000 8007d9bc 00000064 bfd0c9c0 bfd0c9c0 8c0082e0 8c00c300 8007e6fc
ff60: 8c0082e8 00000001 bfd1e000 bfd0c9c0 8c0082e0 8c0082e8 bfd0c9d0 bfd1e000
ff80: 80038400 80038400 00000009 8007ef34 00000013 00000000 80038400 80038400
ffa0: bfd1ffc4 bff9bf00 bfd0c9c0 8007edc4 00000013 00000000 00000000 00000000
ffc0: 00000000 800833d4 8003faa4 00000000 bfd0c9c0 00000000 00000000 00000000
ffe0: bfd1ffe0 bfd1ffe0 bff9bf00 80083354 8003faa4 8003faa4 ffffffff ffffffff
[<803b6968>] (dapm_find_widget+0x8/0x70) from [<803b8bc4>] (snd_soc_dapm_set_pi)
[<803b8bc4>] (snd_soc_dapm_set_pin+0x18/0x64) from [<803c757c>] (amic_detect_ha)
[<803c757c>] (amic_detect_handler+0x3c/0xf4) from [<8007e6fc>] (process_one_wor)
[<8007e6fc>] (process_one_work+0x10c/0x38c) from [<8007ef34>] (worker_thread+0x)
[<8007ef34>] (worker_thread+0x170/0x37c) from [<800833d4>] (kthread+0x80/0x88)
[<800833d4>] (kthread+0x80/0x88) from [<8003faa4>] (kernel_thread_exit+0x0/0x8)
Code: e8bd8ff8 80a812d4 e92d45f8 e1a06000 (e590404c)
---[ end trace 1b75b31a2719ed1f ]---
Unable to handle kernel paging request at virtual address fffffffc
pgd = 80004000
[fffffffc] *pgd=4fffe821, *pte=00000000, *ppte=00000000
Internal error: Oops: 17 [#2] PREEMPT SMP
Modules linked in:
CPU: 0Tainted: G  D W(3.0.35-2508-g54750ff #1)
PC is at kthread_data+0x4/0xc
LR is at wq_worker_sleeping+0xc/0xec
pc : [<80083594>]lr : [<8007fab4>]psr: 00000193
sp : bfd1fc28  ip : 8c008f90  fp : bfd1fcdc
r10: bfcf7b1c  r9 : bfcf7b1c  r8 : bfcf7b98
r7 : 00000000  r6 : bfd1e000  r5 : bfcf7a00  r4 : 00000000
r3 : 00000000  r2 : 00000000  r1 : 00000000  r0 : bfcf7a00
Flags: nzcv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
Stack: (0xbfd1fc28 to 0xbfd20000)
fc20:               8c008f40 804c39f4 80986384 bfff8740 00000001 800df68c
fc40: 8bffa400 bfff2300 20000193 804c0c50 80a45cc0 8bff7e80 80037f40 80037f40
fc60: 800371b4 80037f40 0bfd1000 800e0bd8 0cbbe1d9 8006bcc0 bfd22900 bfcf7a00
fc80: bfe35980 bfd22e04 80a90938 bfd22900 00000000 80037260 bfcf7a00 8006bcd4
fca0: bfcf7a00 80037260 803b696a 800ae598 ffffff52 bfcf7d6c 8c008750 bfcf7a00
fcc0: ffffffff bfcf79f8 bff8c000 bfcf7b1c bfcf7b1c bfcf7b1c 8098003c 8006cf58
fce0: 00000000 bfd1fcf4 bfd1e000 00000001 80a59f3c bfd1fcf4 bfd1fcf4 bfcf7b64
fd00: 00000000 bfd1e000 00000000 00000001 803b696a 00000000 803b696c bfd1fd6a
fd20: 8098003c 80042724 bfd1e2f0 0000000b 00000008 00000000 65000001 38646238
fd40: 20386666 38613038 34643231 32396520 66353464 31652038 30363061 28203030
fd60: 30393565 63343034 00002029 803c7540 80a853c8 00000000 000000f8 00000017
fd80: bfd1fec8 bfcf7a00 00000017 803c7540 80a853c8 804bf928 bfd1fec8 8004848c
fda0: 00000000 80a47db8 bfcf7b94 80a3401c bfcf7a00 bfd1e000 80a47db8 8008898c
fdc0: 8c008f40 bfcf7a00 bfd1fe7c 804c38e0 bfd1fe54 00000000 000d648c 00000000
fde0: 0007f48a 00000000 1fc6211e 00000000 1fc88131 00000008 80037f40 80037f40
fe00: 800371b4 00000017 80a491f0 000000f8 bfd1fec8 00000000 00000113 803c7540
fe20: 80a853c8 80039384 00000000 00000001 80037f40 bfd1ff64 bfcf7a00 bfd1fe84
fe40: bfd1fe64 bfd1fe8c bfd1fe6c 80075080 00000000 bfd1fe80 bfd1fe80 ffff9869
fe60: 80a36080 80075590 000061a8 00000000 bfcf7a38 8c008f90 1fc91ebe bfd1fea4
fe80: 80039e34 ffffffff 00000000 00000000 00000002 800888e8 80a8f8ec ffffffff
fea0: 80a34000 00000002 00000000 80088968 00000000 0000040f 00000007 000000ac
fec0: bfd1e000 8003e990 000000ac 809d5c24 00000001 00000001 00000000 809d5c24
fee0: 000000ac bfd1e000 00000000 8c00c305 803c7540 80a853c8 00000000 bfd1ff10
ff00: 803b8bc4 803b6968 80000013 ffffffff 00000001 00000000 809d5c24 000000ac
ffc0: 00000000 800833d4 8003faa4 00000000 bfd0c9c0 00000001 00000000 00000000
[<80083594>] (kthread_data+0x4/0xc) from [<8007fab4>] (wq_worker_sleeping+0xc/0)
[<8007fab4>] (wq_worker_sleeping+0xc/0xec) from [<804c39f4>] (__schedule+0x390/)
[<804c39f4>] (__schedule+0x390/0x6c0) from [<8006cf58>] (do_exit+0x450/0x6e8)
[<8006cf58>] (do_exit+0x450/0x6e8) from [<80042724>] (die+0x228/0x284)
[<80042724>] (die+0x228/0x284) from [<804bf928>] (__do_kernel_fault.part.4+0x54)
[<804bf928>] (__do_kernel_fault.part.4+0x54/0x74) from [<8004848c>] (do_page_fa)
[<8004848c>] (do_page_fault+0x2b4/0x31c) from [<80039384>] (do_DataAbort+0x34/0)
[<80039384>] (do_DataAbort+0x34/0x9c) from [<8003e990>] (__dabt_svc+0x70/0xa0)
Exception stack(0xbfd1fec8 to 0xbfd1ff10)
fec0:               000000ac 809d5c24 00000001 00000001 00000000 809d5c24
[<8003e990>] (__dabt_svc+0x70/0xa0) from [<803b6968>] (dapm_find_widget+0x8/0x7)
Code: eaff9868 804c7c98 80988818 e590316c (e5130004)
Has anyone faced this??? How can i avoid this??
DaianeAngolini
标签 (2)
2 回复数
1,684 次查看
daiane_angolini
What kernel are you using? Have you built it or it is a pre-build from some FSL release? Which release?
What is your hardware? Is it a custom board? Or is it an old version of some FSL board?
1,684 次查看
AnsonHuang
Hi, Vishvapathi
     If you are not using audio, you can build out audio driver to try.
