Re: Adding a Sound CODEC To IMX6
1,556 次查看
saurabh206
Senior Contributor III
Dave
You also need to add interface file between iMX6 and Coded.
You can refer wm8962 for more reference.
Saurabh
1,385 次查看
freewaymad
Thank you for your reply. This leads me in the right direction. I found the i.MX_6Dual6Quad_BSP_Porting_Guide.pdf. Chapter 8 "Porting Audio Codecs to a Custom Board" referenced this.
Thanks again,
