Random reboot observed with imx6 3.14 linux kernel
atreyamit
Random reboot observed with imx6 3.14 linux kernel, custom board based on wandboard, any help shall be useful. full logs attached.
[2018-05-29 16:08:31] Device status command received
[2018-05-29 16:08:31] Stream URL: [all]
[2018-05-29 16:08:31] strcmp sucess for All module
[2018-05-29 16:08:31] sent sigusr2 to connmand
[2018-05-29 16:08:31] check Nwapp
[2018-05-29 16:08:31] buffer received is 68
[2018-05-29 16:08:31] LCD Event is updating
[2018-05-29 16:08:31] [AccessServiceApp] Access Message Type = 107
[2018-05-29 16:08:31] [Access Service App] [send registration status]:Sent data on StatusQueue
[2018-05-29 16:08:31] message received in statusmonitor
[2018-05-29 16:08:31] message Receive in sttaus response VOIP
[2018-05-29 16:08:31] message send all from rabbit-mq client
[2018-05-29 16:08:31] ......Before calling amqp_maybe_release_buffers........
[2018-05-29 16:08:31] .........Calling amqp_consume_message..........
[2018-05-29 16:08:31] [LCDManager] Received Message D
[2018-05-29 16:08:31] [LCDManager] bytes_read >= 0: Resource temporarily unavailable
[2018-05-29 16:08:31] type - 107
[2018-05-29 16:08:31] all n/wapp request process
[2018-05-29 16:08:31] [NwNotify-app][CELL] [NwNotifyThread]:Sent data allstatus cell on Intermediate app
[2018-05-29 16:08:31] message Receive in status response cell
[2018-05-29 16:08:31] [NwNotify-app][Wifi] [NwNotifyThread]:Sent data allstatus wifi on Intermediate app
[2018-05-29 16:08:31] message Receive in sttaus response wifi
[2018-05-29 16:08:31] [NwNotify-app] [Eth] [NwNotifyThread]:Sent data allstatus Ethernet on Intermediate app
[2018-05-29 16:08:31] message Receive in sttaus response ethernet
[2018-05-29 16:08:33] [NwNotify-app] [Eth] [AllstatusThread]:Sent data on EventQueue
[2018-05-29 16:08:34] Debug: Message with token value 146 delivery confirmed
[2018-05-29 16:08:34] entry nfc all
[2018-05-29 16:08:34] Invalid File
[2018-05-29 16:08:34] nfc details:
[2018-05-29 16:08:34] eventid=410
[2018-05-29 16:08:34] Timestamp=4294967295
[2018-05-29 16:08:34] Status = 0
[2018-05-29 16:08:35] Debug: Message with token value 147 delivery confirmed
[2018-05-29 16:08:35] Debug: Message with token value 148 delivery confirmed
[2018-05-29 16:08:42] Debug: Message with token value 149 delivery confirmed
[2018-05-29 16:08:50] Debug: Message with token value 150 delivery confirmed
[2018-05-29 16:08:50] Debug: Message with token value 151 delivery confirmed
[2018-05-29 16:08:58] Debug: Message with token value 152 delivery confirmed
[2018-05-29 16:09:05] Debug: Message with token value 153 delivery confirmed
[2018-05-29 16:09:05] Debug: Message with token value 154 delivery confirmed
[2018-05-29 16:09:13] Debug: Message with token value 155 delivery confirmed
[2018-05-29 16:09:13] Debug: Message with token value 156 delivery confirmed
[2018-05-29 16:09:21] Debug: Message with token value 157 delivery confirmed
[2018-05-29 16:09:28] Debug: Message with token value 158 delivery confirmed
[2018-05-29 16:09:28] Debug: Message with token value 159 delivery confirmed
[2018-05-29 16:09:36] Debug: Message with token value 160 delivery confirmed
[2018-05-29 16:09:43] Debug: Message with token value 161 delivery confirmed
[2018-05-29 16:09:44] Debug: Message with token value 162 delivery confirmed
[2018-05-29 16:09:51] Debug: Message with token value 163 delivery confirmed
[2018-05-29 16:09:52] WD Manager Initialization sucessfull
[2018-05-29 16:09:58] Debug: Message with token value 164 delivery confirmed
[2018-05-29 16:09:59] Debug: Message with token value 165 delivery confirmed
[2018-05-29 16:10:03]
U-Boot eliuaccs-1.0.3 (May 05 2018 - 01:10:24)
CPU: Freescale i.MX6SOLO rev1.3 996 MHz (running at 792 MHz)
Reset cause: WDOG [2018-05-29 16:10:03]
Board: eliu_accs [2018-05-29 16:10:03]
I2C: ready [2018-05-29 16:10:03]
DRAM: 512 MiB018-05-29 16:10:03]
MMC: USDHC4 Clock: 0x19800000003]
FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2-05-29 16:10:03]
board_mmc_getcd; USDHC3_BASE_ADDR [2018-05-29 16:10:03]
No panel detected: default to HDMI[2018-05-29 16:10:03]
Display: HDMI (1024x768) [2018-05-29 16:10:03]
Bio_TICFSL
Hi Amit,
You need to program it again, and if see it is booting, is the problem persist try it with another nfc, it said that invalid file.
